Old 04-28-2002, 12:53 PM   #1
IMPEZER22
Member#: 12622
95L 2.2T
02 WRX Cobb Stage II
Question hesatation problem
Last weekend I put my custom turbo on my car and im haveing a problem with it hesatating quite a bit from the time it builds boost(around 2K) to about 4K and then it takes off. Any help would be great.
Thanks Chris
IMPEZER22 is offline   Reply With Quote
Old 04-28-2002, 03:59 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
You know, my car does this also, but rarely, and only during the daytime when its really hot. I have not idea what it is, but its almost like there is a HUGE amount of timing retard feeling, then the car just resumes its normal power around 4000 RPM. Doesn't really bother me, I just figured it was from the hot weather.
Graham
Graham is offline   Reply With Quote
Old 04-28-2002, 08:05 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
My car does that in NA form.
I alwasy thought that yes it had to do with the weather.
Brad
STiTuner is offline   Reply With Quote
Old 04-28-2002, 11:36 PM   #4
IMPEZER22
Member#: 12622
95L 2.2T
Now I've noticed that its doing it sometimes around 5K.
Old 04-29-2002, 03:08 PM   #5
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Default Need more info
Are you using a BOV? If you are it needs to be returned to intake pipe(not to atmosphere). I had a problem with the bov open at part throttle and mapping air that the engine never used, ran very rich!
Scoobie Steve is offline   Reply With Quote
Old 04-29-2002, 03:35 PM   #6
Jewbaru
Member#: 1994
2013 Impreza WRX
Graham
Graham, when my car did that, it was because of a MAP spike, and the ECU was cutting fuel. Check your clamp if you're using one.
Jewbaru is offline   Reply With Quote
Old 04-29-2002, 07:05 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
That never even crossed my mind Jewbaru!!??
I don't doubt thats a catalyst for this problem, though its not to too too noticable. I thought fuel cut was when the car started bucking and what not?
Graham
Old 04-29-2002, 08:58 PM   #8
IMPEZER22
Member#: 12622
95L 2.2T
yes i am using a BOV. But im using a pinpong ball to keep it from sucking in air, and i haven't had a problem with it stalling or anything like that.
Chris
Old 04-30-2002, 11:08 AM   #9
Jewbaru
Member#: 1994
2013 Impreza WRX
Graham
If the clamp isn't grabbing hard from the get-go it'll feel like hesitation, or a real sharp drop in spark advance like you described. If you're using a Zener diode, check the soldering job, and hook up a multimeter too it. I eventually broke down and got the SS Voltage Clamp from Tom at Ludespeed.
If the clamp holds, then spikes, the car will stutter, or buck, if the car doesn't even slow the signal from rising, it'll feel like hesitation.
Old 04-30-2002, 11:09 AM   #10
Jewbaru
Member#: 1994
2013 Impreza WRX
Is the BOV is venting to the atmosphere? MAF based cars hate that. Also, what brand are you using? Most good BOVs don't open under vacuum.
Old 05-01-2002, 11:13 PM   #11
IMPEZER22
Member#: 12622
95L 2.2T
Im using a Talon BOV. But its ok, I fixed the problem. When i had my intake off i overlooked the vacuum line that ran to the FPR. I hooked it up and now it runs a lot better but it still has slite misses here and there through out the power band. Thanks for all the help anyway.
Chris
Interesting hesitation problem - Troubleshooters UNITE! IMPREZAmike Normally Aspirated Powertrain 67 12-21-2005 09:28 PM
Hesitation problem... gimpless Normally Aspirated Powertrain 1 09-18-2001 07:56 AM
Hesitation problems......please help! Italiano Technical Forum Archive 6 08-22-2000 10:00 AM
Low RPM hesitation problems.. please help! (cont. ) Orbiter Technical Forum Archive 0 08-18-2000 04:47 AM
Help! is this the "hesitation problem"? fuzzbox Technical Forum Archive 5 05-16-2000 01:44 AM
