Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 07-01-2009, 12:36 PM   #1
viraju
Member#: 193719
1999 Impreza WRX STI
Rally Blue
Default Is it worth changing valves , valve springs and retainers
Iím Rebuilding a EJ207 (in a STI Version 6) engine and planning to put JE-Pistons , Eagle Rods, Coswarth Bearings. Is it worth putting Brian Crower valves , valve springs and retainers . (Iím not planning to change for a High Lift cam ). What other engine parts recommend to be changed , water pump ????
viraju is offline   Reply With Quote
Old 07-01-2009, 01:00 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
water pump and oil pump pending condition and mileage (probably fine).
You can go oversized on the valves if you want but unless you are planning for more RPM or lots of boost (as you said no cam change), you won't need springs. Check valve weights though!!
P.S. BC valves are Supertech valves.
Old 07-01-2009, 02:09 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
What do you mean by that?
Old 07-01-2009, 10:51 PM   #4
viraju
Member#: 193719
Rally Blue
Not gonna go with V high boost, I will run max 1.3bar and I'm realy interested in low/ Mid power for streat racing. What will be the difference in changing the stock values and springs, I know the engine will be more durable and does it increace power ? or perform well in high RPM's, does in worth puting new values ?. I have a JDM WRX STI Version 6 and it has a EJ207 and does STI v7 , v8 values fit my car cause I found out its the same engine block EJ207
Thanks for the Support Guys...
Old 07-04-2009, 12:30 PM   #5
jerry curl
Member#: 155135
03 115k Bugeye
285 AWHP 300 ft lbs torq.
I think if your interested in low to mid range power, You should concentrate on reducing turbo lag and weight of your ride and get to Maximum HP and lb of Torque at the fastest RPM as possible. Are you gonna change for even mild cams??? If your keeping them stock, i would leave the heads alone. Make sure you spend some money on your suspension as well to get the power to the ground. Port and polish the intake manifold and turbo as well clip the turbine wheel. Considering on the steets your gonna be racing to a max of 110 mph from a dig, or atleast i hope youll race from digs and not rolls. (Cause still yet to find a race track that allows roll racing) But if you do decide to change them out, I dont see why it wont give you added sence of security for the heads as well as they are def. gonna flow a bit bitter at the top for you. All really depends on if you want to shell out the extra money.
Pretty sure the STI V6 parts are the same as V7/V8 but dont quote me on that!
jerry curl is offline   Reply With Quote
going vf43 is it worth changing furl rails and lines? Speedster329 Newbies & FAQs 5 06-04-2010 10:10 PM
WRX ej205 heads mild port at seats, +1mm valves, crower valve springs and retainers. NITROS Engine/Power/Exhaust 16 12-02-2009 04:45 PM
Is it worth keeping the stock headunit? and road noise issues Burnall4 Car Audio, Video & Security 6 07-02-2009 03:47 PM
is it worth removing my intercooler piping and heatwrapping it? bradze Water/Methanol Injection, Nitrous & Intercooler Cooling 2 11-15-2008 05:15 PM
Is it worth changing an uppipe on 06 WRX BlackDevil Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-13-2007 12:00 AM
