Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 07-01-2009, 02:16 PM   #1
cumechanic
Member#: 204500
Default Noise from transmission at highway speeds when car is warm?
Hey guys,
i got a 2002 subaru legacy gt wagon 5 speed (with B&M short shifter) and, when i drive around the city normally (or on the highway for less than 20 miles) my car sounds just fine, no weird noises. Whenever i drive over 70mph for extended periods of time, OR when i am going down a steep grade (such as a mountain pass in the colorado mountains), my car begins to make a high pitch whining sound, and no change in speed OR gears changes it (i can shift from any gear into neutral and just coast and the noise still is present, will not stop until the car comes to a stop and immediately comes back again). It sounds like a whine coming from the front of the car, high pitch. does anyone have any ideas??
cumechanic is offline   Reply With Quote
Old 07-01-2009, 03:32 PM   #2
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
check your fluid levels. Mine started whining when the clutch input shaft seal blew out. It sounded like a supercharger whine
Quadsbc is offline   Reply With Quote
Old 07-05-2009, 12:56 PM   #3
cumechanic
Member#: 204500
thanks, i'll try that! it does sort of sound like a supercharger whine. hopefully its not the input shaft seal....
Old 07-08-2009, 01:13 PM   #4
cumechanic
Member#: 204500
hmm, changed the fluid on the tranny and it still makes the noise on the highway (its a little less loud, but still there). the auto manual called for 3.7 quarts and i put in 4. I also read in another thread to try and play with the tire pressure (i changed the pressure to 29 rear, 32 front; the thread said that on wrxs, a 3 psi difference on 16'' rims could cure a sound similar to this). any other recommendations??
gas/fuel smell when car is warm kingman-442 Factory 2.0L Turbo Powertrain 17 07-14-2009 05:58 PM
Car having problems at Highway Speeds pom Factory 2.0L Turbo Powertrain 18 10-26-2007 12:08 PM
car whistles at highway speeds TheBaron862 Normally Aspirated Powertrain 9 08-19-2003 05:30 PM
Slow spool when car is warm amelnikov Factory 2.0L Turbo Powertrain 4 10-04-2002 01:36 AM
MY02 WRX with spinning noise from transmission at idle fumar Transmission (AT/MT) & Driveline 6 09-26-2002 04:23 PM
