#1 |
Vendor
Vendor Sales Rating: (0)
Member#: 67024
Vehicle:2009 BMW 135 I space grey |
Hey everyone. Our new Progressive controller is pretty cool. It is a real time boost gauge that will show boost from 1-30 PSI. It also is a progressive meth injection controller and with our optional flow sensor it will show your flow rate. For those of you that have a meth injection kit that want a very clean look and want to consolidate gauges this one works great.
there is also a really cool feature that would let you show a voltage source instead of boost. You can even multiply the voltage to show a value. For example, if you wanted to see Throttle position from 0 to 100% and for example 5 volts was 100%, you would set the multiplier at 20 and then it would show you 0-100%. This controller can be programmed to inject based on boost, voltage or boost and voltage at the same time. Regardless of how you are injecting, you can set the unit to display either Boost, voltage (or multiplied voltage value) or the pump dutycycle. If you get our flow sensor it will display flow in addition to one of the previous choices. It has an on/off output that can turn on any device in fixed rate when you reach the MIN setting. It has a 0-5V output that will translate the boost for external datalogger. It has a fault input for things like low level sensors. it is progressive meaning as your boost or voltage signal increases your flow does as well. Programming is simple, just navigate through menus, no computer required. Now you dont need a seperate flow gauge, seperate boost gauge and seperate progressive controller. Integrate them into one! Flow sensor is an option and not required to use. Boost connects to the back of the unit. You can get the led in blue or red and the bezel in black or silver. I have plenty of images below Link to the product is below: http://www.coolingmist.com/pagedispl...ature_key=cmgs Here are some vids to show you how to program it if you wish. there are many programmable features but we did a few below to show you. http://www.coolingmist.com/videos.aspx ![]() ![]() ![]() ![]() ![]()
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Vendor
Member#: 67024
bump! any questions let us know!
__________________
#3 |
Vendor
Member#: 67024
bump! www.coolingmist.com
__________________
#4 |
Vendor
Member#: 67024
www.coolingmist.com! Call us today!
__________________
#5 |
Vendor
Member#: 67024
Any questions? feel free to call us at 888-MORE-HPW or visit us at www.coolingmist.com or post to this thread!
__________________
#6 |
Vendor
Member#: 67024
visit us at www.coolingmist.com!!! We have the best in meth injection and can prove it!
__________________
#8 |
Vendor
Member#: 67024
Let us know if you guys have any questions. If your looking for a meth injection kit we have some really cool products.
Most of us want a boost gauge, a water/meth injection controller, possibily a flow gauge.....what if we had a unit that is all in one? Our CMGS gauge is a full progressive controller..a boost gauge and is a flow gauge (with our optional flow sensor). For those of you that dont want to mount a gauge, there is our VC2. The VC (Vari-Cool II) are the square units on top. If you have a current water/meth system with either a boost switch or a competitors controller you can replace with ours. Lets say you have a boost gauge and a progressive controller from another company. You can replace both with this one unit. Lets say you like your boost gauge alot...you can configure ours to display the pump dutycycle so you know exactly what % the motor is running at. You cant lose! Its a very configurable system. Its compatable with every kit sold from any US based manufacturer (if you want to replace your current controller). For those that dont have a kit we sell the kits on our website at www.coolingmist.com. Here are some pics. ![]()
__________________
#9 |
Vendor
Member#: 67024
bump! Visit our website or call us at 888-MORE-HPW.
__________________
#10 |
Vendor
Member#: 67024
Bump!! feel free to check out our products or call us!
CM
__________________
#11 |
Vendor
Member#: 67024
see our complete line of meth systems at www.coolingmist.com
__________________
#13 |
Vendor
Member#: 67024
Hey everyone, its Monday! Call, PM or Email us with any questions!
__________________
#15 |
Vendor
Member#: 67024
bump! visit us at www.coolingmist.com
__________________
#17 |
Vendor
Member#: 67024
check us out at www.coolingmist.com
__________________
#18 |
Vendor
Member#: 67024
starting today when you order a flow sensor with your CMGS/VC2 kit you get a free brass fluid filter and a free low level fluid switch.
__________________
#19 |
Vendor
Member#: 67024
see us at www.coolingmist.com
__________________
#20 |
Vendor
Member#: 67024
Everyone check us out at www.coolingmist.com for the absolute best in meth injection. Ask any questions here as well!
CM
__________________
#21 |
Vendor
Member#: 67024
call or PM us today for your best deal. Coolingmist water/meth kits are top notch.
888-more hpw
__________________
#22 |
Vendor
Member#: 67024
bump! see us at www.coolingmist.com
__________________
#23 |
Vendor
Member#: 67024
visit us at coolingmist.com for the best in meth injection.
__________________
| Thread Tools | |
| Display Modes | |
| New All in One Gauge. Boost/Meth flow, Meth Controller and FAILSAFE!! and other kits | Coolingmist | Gauges & Electronics | 36 | 07-11-2010 08:52 AM |
| Coolingmist Meth Injection, see our new GAUGE Controller and more! | Coolingmist | Engine/Power/Exhaust | 16 | 10-04-2009 08:47 AM |
| Glowshift 52 mm boost gauge | spinningcain | Interior/Dressup/Audio & Security | 7 | 02-08-2009 03:38 PM |
| FS: MadDad Clarity V2 52 mm Boost Gauge | dannyblaze_07 | SCIC Private Classifieds | 0 | 11-17-2008 03:37 AM |
| WTB: 52mm subaru gauge pod; 52 mm boost gauge | 05slvrWRX | Private 'Wanted' Classifieds | 0 | 04-25-2005 03:40 PM |
