Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-01-2009, 09:14 PM   #1
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Default Suspension Geometry Discussion - Roll Centers, Rake, and other sweet stuff!
Hey all,
All my measurements are from my 2004 STi, prepped for BSP, so it's all stock lateral links and LCA components. Car is sitting on 17" Rota Boost with 245 Azenis on it.
I was researching roll centers and I was going back and forth with BIGSKYWRX in the Brake and Suspension forum and for me I would have more value from the feedback I'd get from Subaru autocrossers. I know ButtDyno has documented his ride heights quite a bit and I am trying to put science behind the mad-ness or at least talk about it. Rake also comes into play with the discussion. It would be nice if anyone has any CG info on the Subies as well.
Firstly - I am working on some simple Solidworks 2D models of the front and rear suspension. Measurements taken from the front of the front LCA and the rear most lateral links.
14" Front Ride Height
13.5" Rear Ride Height
Firstly I worked out the rear, I still think it needs some tweaks but here's a vid of RC and IC migration. 9.56" on the inner pivot is my rear ride height set to 13.5" hub to fender. I have rolled fenders by the way.
Then I explored the suggested ride heights and this is how I got the RC and ICs to work out. Interesting that the RC's are so close to each other. This is assuming you have camber plates and they are both slammed inward.
Front RC Equation where Ride Height in Inches = X
y = 2.4791x - 31.583
Rear RC Equation where Ride Height in Inches = X
y = 2.1596x - 26.071
Without camber plates slammed I find that you can loose anywhere from 1.2-1.96" of your roll center height depending on your ride height in the front and 0.6-1.4" in the rear dependent on your ride height. With a CG of ~21" this represents up to a 10% increase in distance from the CG to the respective RC.
I am going to try playing around with different ride heights (maybe from ButtDyno's adventures) but if anyone would like to see something specific let me know. I am working on some charts and what not but I want to make sure the models make sense first.
Thanks ahead of time for any feedback, I am hoping to start a good discussion over this. If there's already an awesome thread I didn't find it when I searched. Scattered info was all I found.
Thanks,
Justin
crystalhelix is offline   Reply With Quote
Old 07-01-2009, 09:29 PM   #2
Mykl
Member#: 14311
2010 GTI
I found this today...
http://www.neohio-scca.org/comp_clin...namics2007.pdf
I've been putting some thought into this with the somewhat recent popularity of roll center adjustment kits. Perhaps I can be corrected for being wrong, but my understanding is that raising the force application point in relation to the center of gravity has the effect of stiffening roll resistance due to the reduced length of the moment arm.
Seeing that the rear roll center and the front roll center on these cars is actually relatively close is great information for me to see. Because it potentially confirms my thoughts that only raising the roll center of the front, without changing the rear or increasing rear spring/bar stiffness would make the car more prone to understeer, even if the increased rate in which weight is transfered helps the car to change directions more briskly. However, the effect of slammed camber plates on the FAP may very well mean that raising it via a roll center kit could even things out again. But I don't have the ability to model this like you do.
I'm not great at math, so if my intuition on the subject is incorrect, I welcome a correction.
Mykl is offline   Reply With Quote
Old 07-01-2009, 09:32 PM   #3
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I've read the Mitchell stuff but without the program I am helpless and that's beyond me I think,lol. I have Solidworks so I gave it a shot.
I think the big question is how far are the respective roll centers from the center of gravity on the front of the car vs. the rear. Many people have found that they like matched ride heights in some cases. Say 13.5 all around or 13.6 all around. Most stick to a 0.5" ride height difference front to rear.
13.5 Front and Rear
Old 07-01-2009, 09:44 PM   #4
Mykl
Member#: 14311
2010 GTI
Yeah, that does seem to be the big mystery that needs to be solved before we can go very far with this. The other variable that comes into play that's hard to get around is the amount of cornering force a given tire can generate.
I think as far as ride heights go we have to know what this change has on the length of the moment arm. In my very unscientific "testing" it felt as though lowering the front in relation to the rear increased the car's desire to rotate. Which makes me think that due to the front geometry of the car, the force application point moves down at a faster rate than the center of gravity. Thus having a softening effect on the suspension, making the rear more willing to step out under steady state cornering since it is now relatively more stiff than the front.
*edit* well now I see a picture, and that confirms my thought that the moment arm up front gets longer the more you lower it. But I think this is already common knowledge.
Old 07-01-2009, 09:56 PM   #5
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
some of the better diagrams i've seen on the subject for STI. good job
As you displayed with your last diagram, the even ride height front and rear means a lower roll center up front in relation the back and a raked roll axis (at 13.5 inches f + r). More oversteer/less understeer would be the result, which is what most Subaru driver's are looking for.
This is I think what ButtDyno noticed with his ride height experiements, and IIRC he noticed handling balance differences with minor ride height changes.
Still, as you know there are advantages to having a roll center that isn't too low up front and spring rates, sway bars, the complete picture should be designed accordingly.
Roll center migration is the "next step" in analysis, and not a fun one. Have you seen stretch's thoughts on slamming the camber plates in vs. running more camber at the lower mount instead?
- andrew
AndyRoo is offline   Reply With Quote
Old 07-01-2009, 10:08 PM   #6
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
on stretch's thoughts, I don't think I saw that specific thread..
I had read one thread talking about the subject but I wasn't getting the concept, is the idea to keep the struts at similar angles or maintaining motion ratios? I know my front struts are leaned into the car almost twice as much as the rear.
I actually think there's a lot to the "minimum front ride height of about XX having to do with your roll stiffness and needing enough room in your geometry to handle 3-4 degrees of roll without your roll center traversing the ground plane and encounter strange weight jacking..
Old 07-01-2009, 11:17 PM   #7
AndyRoo
Member#: 20952
RCE Mini Cooper S
BRG LOL BRZ
http://www.iwsti.com/forums/gd-suspe...-analysis.html
Agreed.
- drew
Old 07-01-2009, 11:30 PM   #8
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Fantastic diagrams.
It looks like for the two scenarios you had, dropping the front from 14" to 13.5" (or a 0.5" drop) moved the front RC height from 3.12" to 1.89"... so a 0.5" drop in ride height resulted in a 1.23" drop in RC height. Confirms the non-linearity.
I think that stretch inferred some CG data from NHTSA rollover data - every car is rated a metric for likelihood to rollover, and I think this is based primarily on track widths and CG heights. We know the track widths of the car, and if we so if you know the equation of the metric you can guesstimate the cg heights. Time to go searching...
Mind is offline   Reply With Quote
Old 07-02-2009, 08:43 AM   #9
Mind
Member#: 109216
08 STI DGM
Found the CG post - it looks like a stock height impreza has a CG height of ~21 inches:
Originally Posted by stretch View Post
...The Static Stability Factor (SSF) listed by safecar.gov for Imprezas (not STI specific, which has a wider track, but this should clue us in on Cg heights):
2006: 1.37
2008: 1.44
SSF = track width / (2 * Cg height)
Thus, if we put in the track width of each year (averaged front and rear):
2006 WRX: 1.37 = 58.4 / (2 * Cg), thus Cg = 21.31
2008 WRX: 1.44 = 58.5 / (2 * Cg), thus Cg = 20.31
Thus, comparing non-STI's, the 2008 chassis has a one inch lower Cg. Obviously the STI's will be better than the standard models due to lower ride heights, but the point is the 2008 chassis is far better in this regard. Reportedly the biggest change is a lower engine mount, but clearly there's more working here than just that.
If the 2008 STI has the same Cg, then its SSF = 60.4 / (2 * 20.31) = 1.48 due to its much wider track- but as I said, the STI's Cg will be lower due to its lower ride height plus any weight saving measures (thinner glass, aluminum body work, etc).
For reference, the 2005 Toyota Camry has a SSF of 1.40. That should put things into perspective. 2005 Camry's may be sofas, but will transfer less weight around the car when pushed than a 2006 WRX.
Original post:
http://www.iwsti.com/forums/1769917-post13.html
Old 07-02-2009, 11:15 AM   #10
Mykl
Member#: 14311
2010 GTI
Here's a fun question that I can't figure out the answer to...
Since the length of the moment arm has an effect on the roll stiffness of the front suspension... is there any way to convert changes in length to chanes in effective spring rate?
Basically what I'm asking is... for every inch you decrease it's length, how much spring rate do you need to lose to maintain the same exact roll resistance?
The idea is this... if instead of running forward rake, you raise the front of the car to bring the roll center up to roughly even with the rear.... or if you're not bound to autocross rules you use roll center adjustment ball joints.
By doing this you can run less bar up front and maintain the same roll stiffness you had with a bigger bar and forward rake.
Old 07-02-2009, 11:53 AM   #11
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Mind...that's good info, I will try to add that to my models just so we can see how it works out.
Mykl - It would be nice to relate optimal roll stiffness and moment arms, I am looking at natural frequency relations as well...
I am working on this, I have a excel spreadsheet that I have input all the data into and plotted the curve. There is a relationship between the ride height and the static RC height so that you can just use a simple equation to determine your RC based on ride height. I may even be able to come up with a fudge factor for how much of the camber plate a person is using.
Old 07-02-2009, 12:24 PM   #12
mccanixx
Member#: 60566
2002 WRX Unicorn
2001 Legacy L 2005 XT 5sp
I feel like towlie from southpark.
"I have no idea what's goin' on."
I'm trying to understand........
mccanixx is offline   Reply With Quote
Old 07-02-2009, 12:27 PM   #13
CamaroFS34
Member#: 6850
Lots of ESP cars
'06 IAG WRX & LT1 Z28s :)
You're not the only one.
CamaroFS34 is offline   Reply With Quote
Old 07-02-2009, 12:33 PM   #14
Splash
Member#: 55936
04 WRX STi
The whole using the adjustment at the knuckle more than the plates thing is an attempt to keep more of the camber you dial in. The SAI and included angles are less when done that way. The larger the included angle is, the more camber you lose as you turn the wheel since the caster is never as high as the included angle. If it wasn't for the jacking effect, I'd say there is no such thing as too much caster due to that.
Mine is set so I'm as close to the strut as possible with the bolts, then I set the plates to the target setting (I could get -5 with it all maxed). It's pretty much the best I can do there. I also run similar heights front/rear, and right now I think the front is maybe a tic lower than even, but that's just due to my rear helper springs being a tiny bit too short.
I'm not too worried about the lowness of the front and the strut's camber curve because, at 600lb/in (+ the bar if we are in a corner), I doubt it moves enough to be that big of an issue. I spent the past winter converting from roll stiffness via bars to roll stiffness via springs...
Splash is offline   Reply With Quote
Old 07-02-2009, 01:15 PM   #15
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
mccanixx and Camaro FS34 - I actually blame you two for making me thing about these things, lol, I was thinking damn...those ESP cars are LOW and FAST...how can it be that my car has the suck, it turns out my ride heights front to rear were ****ed on top of other issues..
Old 07-02-2009, 01:17 PM   #16
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I'd agree to a point but I'd also say it would limit the static caster you would run, which is good and bad, it all depends on how much you are turning the wheel to generate the camber needed. I'd rather have most of it there all the time since I spend most of my time turning in auto cross.
Old 07-02-2009, 01:42 PM   #17
mccanixx
Member#: 60566
2002 WRX Unicorn
Damn you, don't ever accuse me of making people think.
I can only tell you that all my car's settings are a 8. It seems best there.
Actually I don't know if there's alot of difference between mine (wrx) and yours (sti) in regards to width and geometry. But I wondered what mine modeled like, my ride heights are currently 13.25 rear and 13.125 front.
I guess these models also don't account for suspension bushings and the like, not that it'd drastically change it.
Old 07-02-2009, 01:45 PM   #18
blueVTsubi
Member#: 181891
2006 Impreza WRX
srr
this stuff is the amazing, finally a tread about something important. instead of my car looks more fly then yours bs that usually comes out of "hella flush" diarea mouthed ricers.
blueVTsubi is offline   Reply With Quote
Old 07-02-2009, 01:50 PM   #19
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
ROFL - that was my goal.
Greg - I will post a image of your ride heights with your permission when I get home, being at work sucks...I'd much rather not be working..
Old 07-02-2009, 01:56 PM   #20
mccanixx
Member#: 60566
2002 WRX Unicorn
Yep yep my permissions ye have.
Work do sucketh so. But hey I assume most of us are looking at a 3-dayer
Old 07-02-2009, 03:38 PM   #21
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Here's a close representation. I need to work out a few things so I can set it closer to your actual numbers.
Your front RC is ~1.6 inches below your rear RC.
Old 07-02-2009, 03:50 PM   #22
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Here's a cool image, did a simple extrusion of the geometry triangles.
Old 07-02-2009, 03:56 PM   #23
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
This is why having a separate auto-x section is stupid...a great discussion like this could be going on and most of us would never even know about it.
boost junkie is offline   Reply With Quote
Old 07-02-2009, 03:56 PM   #24
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
So much info...I don't know what to do....must leave computer..or brain will explode.
Old 07-02-2009, 03:56 PM   #25
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Sorry I am an auto crosser, lol. Welcome!
1G DSM Head and other DSM stuff!!! Also Civic Stuff!!! KassanovaSTi Non-Subaru Stuff 0 06-13-2007 10:57 PM
-=C=- discusses his OT habits and other crap over email as Katrina raged... -=C=- Off-Topic 5 11-03-2005 02:28 PM
Suspension questions about, roll centers, and pollor movment of inertia? wrxsubaru Brakes, Steering & Suspension 3 02-13-2005 12:54 AM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
Hood Scoop and Vents backing plates and other RS stuff 2.5 Blue Roo Private 'For Sale' Classifieds 27 07-10-2004 05:14 PM
Message Board Statistics All times are GMT -4. The time now is 01:44 AM.
