Alaskan Impreza Club
Old 04-28-2002, 06:53 PM   #1
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question boost gauge
how high does everyones boost go up to on their gauges?
mines only going up to 8 PSI max. any ideas on what is causing it to not go any higher, or is that all my car is putting out?
AK_2002_WRX is offline   Reply With Quote
Old 04-28-2002, 09:39 PM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
Maybe leaking boost? The WRX are tuned to run 14 to 16... but I think it would be rather noticeable if you were...
RawCode
RawCode is offline   Reply With Quote
Old 04-29-2002, 05:04 AM   #3
WRXnFX
Alaskan Mafia
Member#: 10398
I've seen my boost run as high as 15psi depending on the gear. You were suppposed to call. What happened?
Winslow
WRXnFX is offline   Reply With Quote
Old 04-29-2002, 06:32 AM   #4
BlackNight
Member#: 16285
2004 VW .:R32
Tornado Red
Do you have the boost gauge installed right? Check the wiring.
Winslow-
My Check engine Light turned off just a few days after the meet. But I would still like to look at the History to find out what it was. Can your OBDII computer read the history?
BlackNight is offline   Reply With Quote
Old 04-29-2002, 08:08 AM   #5
Code-7
Member#: 5077
'97 e39 540i6
Winslow-
Maybe it was your P-Flo again. Or gas cap, bad gas, etc.
Code-7 is offline   Reply With Quote
Old 04-30-2002, 01:44 AM   #6
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question
would the gauge be more accurate if it were teed into the wastegate line?
Old 04-30-2002, 01:41 PM   #7
nano
Member#: 15860
1997 Talon Tsi AWD
11.91 @ 114.4 w/1.75 60ft
YOur boost gauge should be Teed between your manifold and BOV. If you did it between the wastegate and boost controller you would get a different signal since the boost controller reduces the amount of preasure going to the wastegate.
nano is offline   Reply With Quote
Old 04-30-2002, 04:17 PM   #8
WRXnFX
Alaskan Mafia
Member#: 10398
The OEM Subaru boost gauge tees off the BOV.
Winslow
Old 04-30-2002, 04:42 PM   #9
nano
Member#: 15860
1997 Talon Tsi AWD
I've seen up to 28psi from my gauge before!!! That's with my wastegate unpluged!! Don't try this at home... It can easily blow a head gasket..
Old 05-01-2002, 12:06 AM   #10
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Arrow
yeah, i've read about people unplugging their wastegate line, very very dangerous
I got the boost gauge to go up to 10 PSI, then it leveled back down to 8. maybe my car doesn't put out as much boost as everyone elses but its still fast
Old 05-01-2002, 01:31 AM   #11
Getagrip
Member#: 2045
BRZ
My Blitz dual turbo timer records the max boost. I've got as high as 1.26 bar. I don't know what thisis in psi. Anyone know the conversion?
Getagrip is offline   Reply With Quote
Old 05-01-2002, 01:35 AM   #12
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
i think thats somwhere around 17.40 PSI, maybe a little more.
Old 05-01-2002, 01:37 AM   #13
Getagrip
Member#: 2045
BRZ
Wow, and I have no boost control mods.
Old 05-01-2002, 02:46 AM   #14
KapaFool
Member#: 2679
2010 WRX4FD
Uh.....No way!
KapaFool is offline   Reply With Quote
Old 05-01-2002, 03:05 AM   #15
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
Originally posted by KapaFool
Uh.....No way!
i'll have to call b/s on this one too!
SQUAD_907 is offline   Reply With Quote
Old 05-01-2002, 04:04 AM   #16
WRXnFX
Alaskan Mafia
Member#: 10398
Look at this guy. Where did you get your conversion? Depending on your conversion of 14.5 or 14.7, that number is over 18.
When I hit the peak hold button on my gauge, I see the max boost at 18-19. I've never seen the gauge above 15psi, though.
Mike, did you try removing the restrictor and watching for an increase in boost?
Winslow
Old 05-01-2002, 01:21 PM   #17
nano
Member#: 15860
1997 Talon Tsi AWD
Well I'm sure the stock boost control isn't that steady and probably spikes to 17psi a lot. It did on my car at least. I've seen stock wrxs that spike a lot with a mbc. But the ones with a cold air intake seem to be a lot more steady. This obviously shows how much harder the turbo has to work to suck air with the stock air box. Even with my EBC, bigger turbo and bigger intake mine spikes about 1.5psi sometimes. It just happens with turbo cars. But dosen't mean you're running that much boost across the band.
Old 05-01-2002, 03:40 PM   #18
Tusin
Member#: 17074
01 VW Jetta 1.8T
Yall should come over to the Vortex and read some of the "new" N75 vavle threads. Some people are spiking at 1.75bar, but then again it is sending them in to what we call "Limp Mode". I should have the vavle today. But these findings of people going into "Limp Mode" happend after I ordered it. So I am going to wait for awhile before I put it on and see if someone comes out with a "fix" or somthing.
Tusin is offline   Reply With Quote
Old 05-01-2002, 05:11 PM   #19
RallyIt
Member#: 17197
Rally Blue
Winslows right
A boost of 1.26 bar is 18.3 psi
1 bar = 14.5 psi
RallyIt is offline   Reply With Quote
Old 05-01-2002, 10:25 PM   #20
KapaFool
Member#: 2679
2010 WRX4FD
I've seen 12 psi at WOT and then starts to bleed down. I am stock everything.
Old 05-03-2002, 02:52 AM   #21
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
I got it from some conversion table i searched for
Thanks for reminding me about that, forgot i had the extra one. i'm going to do it tonite
did you try it yet?
Old 05-03-2002, 02:54 AM   #22
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
oh yeah, i think i've got a leak somewhere with my windows down i can hear a shhhhhhhhh noise that i've never heard before. i am goin to check all the connections tonite.
Old 05-03-2002, 06:07 AM   #23
WRXnFX
Alaskan Mafia
Member#: 10398
You were supposed to come over tonight. If you want stop by tomorrow and we'll take a look. I'd take a look at all the connections that we oosened up and check the hoses that you messed with. No, I haven't tried the mod yet, because I'm thinking about waiting and doing it all when I order a bunch of BOOSTMONKEYS. Anybody want one?
Winslow
Old 05-03-2002, 02:46 PM   #24
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Exclamation
i did the restrictor mod.
the boost builds much faster. it spiked up to 15 and leveled out to about 8psi.
Old 05-03-2002, 07:07 PM   #25
KapaFool
Member#: 2679
2010 WRX4FD
I don't see a difference in boost after the restrictor mod. Just order the BoostMonkey already.
Mech. Boost Gauge vs. Elec. Boost Gauge YooperWRX Newbies & FAQs 9 07-09-2009 11:37 AM
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2004 11:19 AM
WRX Stock Boost gauge and STI Boost gauge PlayTime Electrical & Lighting 0 06-03-2004 05:31 PM
$17 Boost gauge -vs- $135 Boost gauge Mattr762 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-14-2003 02:05 AM
No boost gauge! Is an EBC with boost gauge good enough madmmt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 05:27 PM
