Old 07-02-2009, 12:50 PM   #1
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
Default Overheating problems - tried almost everything.
I can't figure this one out. I've been running my ej22t swap with a TD04 and 16-17psi for about 2 years now with very very few issues. Recently though, it started overheating. That was back in October (perhaps?). If did it randomly and made no sense (I had replaced the thermostat the previous summer.). My radiator was crap, so I thought that was the problem. Anyway, the overheating randomly stopped for several months. And started up again sometime in April (perhaps?). I'd randomly lose heat for a few seconds, the temperature would spike, then I'd keep driving and it would drop down. It would NEVER overheat on the highway. Then one day the radiator started leaking, and I tore everything down, flushed the coolant, replaced the thermostat, gasket, checked out the water pump (still spins, no broken fins, no rust.), and replaced my stock L radiator with a legacy turbo one. I burped the coolant system, and made sure everything was together right, then started driving it. Worked great for about a week, no leaks, no overheating, no issues at all. About a week later it began to overheat after highway drives. I'd get off the freeway and it would start to overheat at lights. My fans work and I can hear them come on all the time. This overheating was a nuisance and could be usually fixed quickly by revving my engine, then the temperature would drop off quickly. When it overheated, the overflow tank would be overflowing and coolant pouring out. It got annoying. Gradually, the overheating got less frequent and sometimes it wouldn't even overheat for several long drives. When it did, I'd be on the highway, driving fast, then hit traffic and drive slow. It never overheated in traffic, but it liked to after this one traffic light... odd. Anyway, the other day I was driving to work and the temperature just wouldn't go down - even on the highway. It kept climbing even with heat on, even with revving. I pulled over and check the oil and coolant - both fine.. In fact, the overflow tank was nearly full. Temp wouldn't go down.
So I've tried a lot, and replaced almost everything aside from the water pump, head gaskets, and heater core. I don't THINK it's the head gaskets for a few reasons:
1. no oil in coolant.
2. no smoke.
3. oil looks fine - not milky.
4. overheating isn't consistent until now.
I don't know what it could be, and I need an experts help. Please?
Thank you in advance.
Daniel
Harenil is offline   Reply With Quote
Old 07-02-2009, 01:02 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Replace the thermostat again with OEM.
Old 07-02-2009, 01:04 PM   #3
Harenil
Member#: 93071
I just did, not more than a month ago, and also a year before that. Why replace it again?
EDIT* that probably sounds rude... I'm curious though, what is your reasoning? If a new thermostat didn't fix the overheating the first time, why would I put another one in?
Old 07-02-2009, 01:21 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Because you will slap yourself silly if thats all it is.
Try running WITHOUT the t-stat completely for a bit and see what happens.
Old 07-02-2009, 02:08 PM   #5
Harenil
Member#: 93071
What do you think about the water pump? If it's not leaking, spins, and has no broken fins, is there any reason to believe it is the cause?
Old 07-02-2009, 02:09 PM   #6
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
maybe the rad cap is bad. have you replaced that recently?
subiidude is offline   Reply With Quote
Old 07-02-2009, 02:19 PM   #7
Harenil
Member#: 93071
Yup, replaced that a couple months back.
Old 07-02-2009, 05:12 PM   #8
front runner
Member#: 121603
2001 legacy BH
blue
kinda sounds like headgaskets. you don't generally see oil in coolant or coolant in oil with subarus. try checking for bubbles with the radiator cap off with the car running. if it is that bad you'll see...
front runner is offline   Reply With Quote
Old 07-02-2009, 06:57 PM   #9
Harenil
Member#: 93071
Damn. I'm going to try reddevil's suggestion and pray my car doesn't overheat any more.
Otherwise, I got an excuse to throw on some ej25 SOHC heads. If I have cash, a new tranny and VF39.
Old 07-02-2009, 09:59 PM   #10
silentt
Member#: 119995
2004 Outback XT
Peachy
Headgaskets. I had a very similar problem and that's what it turned out to be.
http://forums.nasioc.com/forums/show....php?t=1648780
silentt is offline   Reply With Quote
Old 07-03-2009, 12:46 PM   #11
Harenil
Member#: 93071
Hmm... kinda thinking this is a good excuse to do a rebuild with some (much) better heads, new tranny, and new turbo... Since I've pretty much looked at everything, head gaskets seems to be the only thing left.
Thanks for the help everyone.
Looking at swapping ej20g heads and intake and stuff. The problem I'm looking at is that I'm still running the stock ej18 ecu. How do I convert from wasted spark to the ej20g or ej207 ignition coils? I ask because I was also considering sohc ej25 heads, and I am under the impression I don't have to change anything, or I have to change plug wires or something... anyone know?
Old 07-03-2009, 02:10 PM   #12
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
Have you replaced all of the radiator hoses lately? When going up and down in altitude with old hoses they will get soft and expand. This will create a bulg in the lines and will not allow the tstat to open.
ozzy370 is offline   Reply With Quote
35% off on almost everything on eBay BuyItNow Eyeflyistheeye Off-Topic 588 06-09-2010 09:49 AM
Cant read ECU, tried almost everything. ryrules1 Open Source Reflashes 8 06-29-2009 09:50 AM
20g, RA gears, motor, almost everything, feeler... AWD>FWD NWIC Private Classifieds 46 02-03-2008 07:16 PM
WTB: Almost everything OEM for an 2004 WRX Rick Dizzle Private 'Wanted' Classifieds 14 07-13-2007 03:53 PM
This Stuff Makes Almost Everything Better CandyO Off-Topic 32 04-04-2005 02:54 PM
