07-02-2009, 02:05 PM | #1 |
Member#: 141949
TXIC
Vehicle:2004 Wrx JBP |
TGV codes and misfire code upon start up
About 2 weeks ago I got a #4 cylinder misfire so I switched coil packs. Couple days later..... #4 cylinder misfire. So then I just switch sparks plugs from #4 and #2. Then.... another solid check engine light. But now the codes are: P0301 Cylinder 1 misfire detected, P1090 Tumble generator valve #1 (RH) malfunction (stuck open), P1092 Tumble generator valve #2 (LH) malfunction (stuck open), P1097 Tumble generator valve circuit #2 (overcurrent)...... Now what???!!!???? The car runs fine after warm up..... Each time I got the check engine light it was only during start up, none while actually driving. When I start it up, it idles rough for about a minute then smooths out the rest of the time. About 5 days ago, I start up and no check engine light. The codes just disappeared. Then a day or 2 passes, then the light comes back on (on start up), stays for a couple days, then today I start up, no light. I thought once the light comes on, it will stay until the problem was fixed or I had it cleared. WTF
I have a set of tgv motors and sensors on the way, so those will be getting replaced. Hopefully the motors are just going bad. My thoughts are when I drive, park, and go to shut the car off, the tgv's don't close, so when I start up they are already open, hence the misfire and tgv codes for them being stuck open. What else do you guys think could be the problem if the new sensors/motors don't fix it?
07-03-2009, 10:41 AM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
That sounds about right for the cause of your issue. You can always try cleaning things, I can't tell you how many times just a simple cleaning has cleared up electrical issues.
And you thought wrong about the ECU codes. When the ecu detects something wrong, it will throw the code, but after a while ( I forget, maybe a couple of driving cycles) if the problem is gone, the cel will go off. The code may still be stored, but it won't be "active". |
07-03-2009, 05:16 PM | #3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
sounds like a tgv is sticking or isnt plugged in properly
try unplugging re-plugging them |
07-03-2009, 05:27 PM | #4 | |
Member#: 141949
TXIC
Thanks, I'll try that. The new motors/sensors should be here by the 9th so that gives me time to see if this re-plugging will work |
utec, speed density, and misfire codes | MRX WRX | UTEC | 240 | 06-16-2009 11:31 AM |
HELP!!! P0021 CEL code and misfires! | xlumberjackx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 01-30-2009 07:08 PM |
codes,codes and more codes | grinch77 | Newbies & FAQs | 8 | 01-07-2009 05:27 PM |
Help. compression #'s and misfire codes. | byroll01 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 43 | 09-10-2005 09:34 PM |
Spark Plug Gap and Misfire Codes, Realtionship? | JayGold | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 05-15-2003 05:02 PM |
