Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 07-02-2009, 07:10 PM   #1
5lugfish
Member#: 206522
04 WRX Wagon
Default FP68HTA 256/215 mustang
Open source tune on Mustang Dyno. 256 awhp/215 awtq. Tuner said he couldn't run boost over 18psi without knock.
Does this sound right?
'04 WRX Wagon 5MT PSM
PnP'd FP68HTA
800cc injectors
Walbro 255 fuel pump
JE Pistons
Eagle rods
ARP studs
Crower valves +1mm/cams - 272's
PnP heads
Ported TGV's
STI Tmic
Perrin DP/ APS Catback
Catless UP
Grimmspeed BCS
Gimmick silicone inlet
Stock airbox
5lugfish is offline   Reply With Quote
Old 07-02-2009, 07:12 PM   #2
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
Very low even on a mustang. Your cammed as well. should be making a lot more power. Who is your tuner?
ramair18954 is offline   Reply With Quote
Old 07-02-2009, 07:39 PM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That looks extremely unhealthy. Look for leaks, do a compression test, try a different tuner.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 07-02-2009, 08:02 PM   #4
5lugfish
Member#: 206522
04 WRX Wagon
-- Ed
That's what I thought. Compression is good. No vacuum leaks.
Old 07-02-2009, 09:27 PM   #5
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
weird.
just wondering, howcome still on the stock airbox?
maybe a stock turbo... but i think this is just a restriction on this turbo.
even though you apparently have a more serious problem.
penusai is online now   Reply With Quote
Old 07-02-2009, 09:29 PM   #6
5lugfish
Member#: 206522
04 WRX Wagon
Originally Posted by penusai View Post
weird.
maybe a stock turbo stock airbox... but i think this is just a restriction on this turbo.
Good question. Same reason I'm still using a stock location turbo. I'm waiting to do a 6 spd swap before I add any real power.
Old 07-02-2009, 09:49 PM   #7
crashtke
Member#: 120912
2.5 block or 2.0?
crashtke is offline   Reply With Quote
Old 07-02-2009, 09:51 PM   #8
5lugfish
Member#: 206522
04 WRX Wagon
Originally Posted by crashtke View Post
2.5 block or 2.0?
2.0 rebuilt
Old 07-02-2009, 10:00 PM   #9
crashtke
Member#: 120912
Only thing I can possibly think is maybe the knock sensor is doing weird things and getting false knock from the built motor. I have seen it before on 2.5 liter built blocks.
Old 07-02-2009, 10:03 PM   #10
5lugfish
Member#: 206522
04 WRX Wagon
I had the PS pump disconnected and ran a shorter belt to the alternator. Would that cause false knock?
Old 07-02-2009, 10:10 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
to me it looks like your tuner didnt know how to tune your boost, that is a horrible boost plot.
looks like he has your target boost too low until about 5800rpm. Every time the boost peaks then valleys is a sign that you're over target and the turbo dynamics are reducing the wgdc. Then you get low, then the TD's increase the wgdc, over and over.
unless the wg is too small on these turbos and its boost creepin, but i dont think anyone else has reported that.
I really cant believe a tuner would even print that dyno sheet out and give it to you.
I wouldnt let anyone see that if it was a final tune. When you have 40 ft*lb tq spikes ur tune sucks.
Post up your target boost, wgdc and turbo dynamics values. I bet he didnt change your td table and u bet your target boost table loooks really weird.
Old 07-02-2009, 10:14 PM   #12
5lugfish
Member#: 206522
04 WRX Wagon
To be fair, they're 30 ft/lb spikes. It's those crazy fluctuations that bother me more than anything. I would just like to know if this is a tune problem or mechanical problem.
Old 07-02-2009, 10:17 PM   #13
5lugfish
Member#: 206522
04 WRX Wagon
All I got was the hp/tq/boost graph. So... you think the TD is the problem? Would that be the culprit for the knocking too?
Old 07-02-2009, 10:18 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
if you email me your rom i can post the tables. r-j-w@rocketmail.com
i assume you have a tactrix cable, ecuflash and a laptop?
Old 07-02-2009, 10:21 PM   #15
5lugfish
Member#: 206522
04 WRX Wagon
Nope. Just the dynotune.
Old 07-02-2009, 10:24 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
Go here. Download romraider, ecuflash and go buy a tactrix cable for $70. The tactrix cable allow you to plug into the obd2 port and download your rom off the ecu....and even reflash the ecu. Ecuflash is the program that does the saving and flashing. Romraider allows you to log pulls on the street. If you are running opensource you should definately have all these things.
RomRaider/Ecuflash getting started FAQ
Old 07-02-2009, 10:26 PM   #17
5lugfish
Member#: 206522
04 WRX Wagon
I would- but I need a laptop. Mine is locked by the company I work for so I can't install software or run any type of outside hardware.
Old 07-02-2009, 10:27 PM   #18
dinosmash
Member#: 143598
2001 Impreza
blue
Default false knock is a pita
i have an 04 i have had everytune on my motor stage 1 stage 2 vf39,16g 18g.my 04 would not take timing advance at all.my tuner was able to make boost easily but when we added timing it would knock or vise versa.fueling was dead on.now im stage 2 with conservative timing and a small shot of nitrous.i dont know what the deal is with my motor.sounds like your having similar issues.ive leaned to expect grief from my track times before the nitrous.if you work out your issues please pm me and let me know what it is.you may reach me before i kill this pos motor and rebuilt another one with forged internals to handle more nitrous.thanks
dinosmash is offline   Reply With Quote
Old 07-02-2009, 10:30 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
Well, i since the tuner didnt know how to tune the boost....its not unreasonable to assume that he probably did a crap job on the timing too.
There really isnt a good way he could've tuned the timing very well with the boost/torque/load jumping around like that.
It really disgusts me that "pro" tuners can get away with tuning like that and stay in business.
Old 07-02-2009, 11:43 PM   #20
CatfaceType-R
Member#: 81102
download the program and buy the cable that ron's talking about ftw OP
CatfaceType-R is offline   Reply With Quote
Old 07-02-2009, 11:44 PM   #21
5lugfish
Member#: 206522
04 WRX Wagon
I plan on it. Just wanted a tune to get me by for a while. Anyone got a cheap laptop?
Old 07-02-2009, 11:49 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
acer 8.9" $240
Intel Atom N270 1GB RAM 120GB HDD Webcam 802.11BG Wireless 2.19lbs Windows XP
http://www.frys.com/product/5720742?...H:MAIN_RSLT_PG
Old 07-02-2009, 11:56 PM   #23
5lugfish
Member#: 206522
04 WRX Wagon
Thanks, Ron!
Old 07-03-2009, 03:09 PM   #24
crashtke
Member#: 120912
The dyno sheet was so small I did not notice that the yellowish line was boost. Good call.
Old 07-03-2009, 06:25 PM   #25
Davenow
Member#: 23676
Sounds to me like a garbage turbo (big suprise, an FP turbo underperforms..)
for a turbo that is supposed to make "20G numbers" that thing isnt even making 16G numbers.
FS : WI: 93 Mustang GT Black on Black sleeper quick93fox Private Vehicle 'For Sale' Classifieds 21 07-06-2010 11:03 AM
2004 FXT, FP68HTA, E85, PDXTuned Geoff Proven Power Bragging 26 02-03-2010 06:35 PM
MHI TD05 20G 8CM trade for a FP68HTA 16g LT_DAN0690 Engine/Power/Exhaust 11 07-14-2009 11:27 PM
02 wrx Turbo XS Fmic,fp68hta, DW 750 cc aaronzgod Private 'Wanted' Classifieds 7 07-12-2009 02:04 AM
Anyone hear or have any experience with the new FP68HTA turbo? chargerbry Newbies & FAQs 3 04-29-2009 05:35 PM
