Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 04-28-2002, 10:40 PM   #1
kid 13
Member#: 17603
Default Bypass Valve vs. Blowoff Valve
which is better..
a bypass valve or a blowoff valve?
kid 13 is offline   Reply With Quote
Old 04-28-2002, 11:17 PM   #2
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
its same thing... only difference is where it goes...
HOK is offline   Reply With Quote
Old 04-29-2002, 04:26 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
they are the same thing except bypass valves are used on supercharged systems and bypass the super charger rotors.
jeremy
Old 04-29-2002, 04:41 PM   #4
giulio
Member#: 16040
1998 Impreza RS
Supercharged
I thought that blowoff valves are only on/off devices... either hold the charge or blow it all out.
Bypass valve is variable. It can reroute all/some/none of the charge. For that reason I think it's more correct to compare it to a wastegate than a BOV. Both maintain the boost you want... WG makes sure you dont get too much, BPV makes sure get enough, up to the SC's max. A SC has a definite limit, where a turbo you can overboost.
I guess you can use a BPV to limit the boost like a WG also... if you want to rig it's butterfly to only close up to a certain amount.
I think it's best to say that a BPV does the job of a WG and a BOV at the same time.
It's controlled totally by manifold pressure.
what controls a WG and a BOV?
g
giulio is offline   Reply With Quote
Old 04-29-2002, 04:53 PM   #5
TerenceT
Member#: 9510
04 FX35
Pearl White
i thought they are all the same except for WG
bov/bpv works when your TB is close and the charged air is released/recirculated
WG should be compared with the Acctuator of the turbo
WG control how much boost you are getting from the turbo
TerenceT is offline   Reply With Quote
Old 04-29-2002, 06:42 PM   #6
giulio
Member#: 16040
1998 Impreza RS
Supercharged
like a WG, BPV controls how much boost you get.
with a turbo, exhaust gases are used to make the turbo spin fast/slower to change boost. a SC is always spinning as much as possible... so the PBV is used to moderate the boost you get. it recirclates the charge. when you open the throttle, vacuum in the intake manifold is gone and the BPV closes, forcing the charge into the motor. when you close the throttle, vacuum is made, and the BPV opens, recirculating the charge again.
what happens with a BOV at partial throttle? a BPV will partially close, recirculating the boost. my understanding was that BOV release it all when you snap the throttle shut... but i dont have any experience with them. I didnt think you can use a BOV to moderate boost... i though it was an emergency release, a safeguard against overboosting/breaking the throttle butterfly.
doesnt a boost controller play with the wastegate? That's why i compared the WG to the BPV... they control boost.
g
Old 04-30-2002, 03:57 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
giulio you are right, i was incorrect before a bypass valve is more accurately compared to a wastegate...they both control the amount of air moving through the compressor.
jermey
Old 04-30-2002, 09:53 AM   #8
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Default Re: Bypass Valve vs. Blowoff Valve
Originally posted by kid 13
which is better..
Well since we shown that they arent really comparable, it's unfair to judge. but if you must... a BPV is 'better' than a BOV since it recylces the charge, making it readily available for the next time you want boost.
And if you want to compate a BPV to a WG, I think the BPV still wins. for the same reason. It's my understanding that a WG just redirects exhaust past the turbine... wasting all that extra energy.
I wonder why turbo systems dont incorporate a BPV. maybe the recycling charge would get too hot to be usable. {shrug}
Someone just told me that there are different types of BOV's... some function just like the BPV. So... who knows.
g
Bad oil control valve vs burnt valves. WANTED!! Newbies & FAQs 3 09-15-2009 04:14 PM
Need to buy stock recirc valve, bypass valve, blowoff valve, whatever u call it!! newbie-subie SCIC Private Classifieds 2 02-12-2009 04:35 AM
centralNJ WTB stock bypass valve/blowoff valve funigui Tri-State Area Private Classifieds 0 06-02-2008 03:32 PM
FS:Stock ByPass Valve/Blowoff Valve White_Rex_02 Private 'For Sale' Classifieds 4 10-09-2005 10:57 PM
