Old 07-03-2009, 06:51 PM   #1
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Default Element GT52 Powered Bugeye.
It put down 473whp/513wtq on 93 and 50/50 @25lbs. It was tuned by Corey Parrish @ Slow Motion Motorsports in Sunbury, Ohio.
Engine:
-ej257 shortblock with overbore.
-Wiseco 100mm pistons.
-Manley forged rods.
-new oil pump, water pump, oil pan, gaskets, etc.
-ARP studs.
-PE timing belt.
-new knock sensor.
Heads:
-rebuilt stock heads.
-Crower Stg 2 cams.
-Spec C deleted tgvs.
Engine Management:
-Hydra EMS and Hydramist water/alcohol injection.
-Greddy Profec B-spec 2.
Bolt-ons:
-Element GT52 (wastegate permanently closed).
-custon Vishnu up-pipe w/44mm Tial (vented to atmosphere).
-custom catless 3 turboback w/Vibrant Ultra Quiet Resonator.
-Borla wrapped header.
-TurboXS front mount intercooler.
-PE 800s cleaned and flow tested to avg. of 820 (just done for troubleshooting).
-Perrin fuel rails.
-Perrin intake and turbo inlet.
-NGK Laser Platnum spark plugs (one step colder).
Drivetrain:
-JDM 6-speed non-DCCD.
-Exedy twin-plate clutch kit w/flywheel.
-DSS aluminum driveshaft.
-DSS front axles.
-R180 rear-end w/Subaru 2-pots.
-Kartboy short shifter and bushings.
-Group N tranny mounts, dogbone, and motor mounts.
kharris4 is offline   Reply With Quote
Old 07-03-2009, 06:55 PM   #2
Ammata
Member#: 155819
2004 Impreza WRX
Monster....haha
Ammata is offline   Reply With Quote
Old 07-03-2009, 07:32 PM   #3
JDM RA
Member#: 205914
2002 JDM Impreza RA
Sorry to sound dumb, in the UK we have Brake horse power usally measured at the flywheel. How is WHP measured?
Nice power figure whether it be at the fly or the hubs.
JDM RA is offline   Reply With Quote
Old 07-03-2009, 07:42 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
There this cool new website that came out about 3 hours ago that has all sorts of information. Its kinda like an encyclopedia collection, but on teh intraweb.
not really sure how to use it yet, but i managed to find this
http://en.wikipedia.org/wiki/Dyno
i also heard some guy on teh street corner talking about something called google or googoole thats supposed to come out sometime soon too.
Old 07-03-2009, 08:29 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
funny guy!
godforbid67 is offline   Reply With Quote
Old 07-04-2009, 10:59 AM   #6
some dude
Member#: 100300
06 WRX
CGM
Amazing build! Curious, is the redline set to 6500?
some dude is offline   Reply With Quote
Old 07-04-2009, 01:12 PM   #7
kharris4
Member#: 46018
2003 wrx
I usually shift between 6500 and 7000. But to answer your question, I'm not sure what it's set at. I guess I should check sometime soon.
Old 07-04-2009, 03:29 PM   #8
some dude
Member#: 100300
06 WRX
CGM
I was just looking at the graph and saw it stopped at 6500. Huge power out of the 2.0. Did u build it to run the 1/4, or track it?
Old 07-04-2009, 03:35 PM   #9
07wrxwagon
Member#: 165334
2006 WRX stage 1/2
07 6 speed swapped
it is not a 2.0, in the build write up it says the short block is an ej257
07wrxwagon is offline   Reply With Quote
Old 07-04-2009, 04:20 PM   #10
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
Very nice numbers. So you went with the stock WRX heads, no porting at all and made these numbers, WOW!!!
hauntedwrx is offline   Reply With Quote
Old 07-04-2009, 09:28 PM   #11
kharris4
Member#: 46018
2003 wrx
Nope, no porting. They were cleaned up, and rebuilt with some factory replacement parts. The cams are the only things that were upgraded.
Old 07-04-2009, 09:32 PM   #12
kharris4
Member#: 46018
2003 wrx
I wanted it to be an all around fast car that could be driven in any condition and maybe even a 1/4 mile here & there.
Old 07-04-2009, 11:57 PM   #13
some dude
Member#: 100300
06 WRX
CGM
Sorry, I misread earlier.
Element Gt52 tuning notes - great unit Dyno Flash Proven Power Bragging 97 06-07-2007 06:03 PM
Element GT52 Turbo/Hydra/Hydramist 436 whp Element Tuning Proven Power Bragging 60 10-25-2006 11:05 PM
AZ: Element GT52 Turbo, TXS FMIC, Tial 38mm WG hulkmanj99 Engine/Power/Exhaust 5 10-24-2006 09:40 PM
Element GT52 Bolt-on Turbocharger WTillIDIE Proven Power Bragging 11 10-23-2006 01:39 PM
element gt52 redrex2002 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 70 10-19-2006 03:07 PM
