Old 07-04-2009, 03:32 AM   #1
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Default stage 2, vf39 93 oct map on 2.0 2003- Slow car
yesterday and part of july 4th itself so far was used for installing a set of sti pinks, aps tmic, and vf39 into my friends 2003 wrx. We wrapped up about 1am and noticed that with a quick test drive we were hitting only 15.x psi of boost and the car had some stumbling at wot in higher rpms. It just has no pull despite the fact it was still hitting 15psi. Does this sound like a restrictor pill issue? Very late spool too around 4000 rpms.
Dubstar112 is offline   Reply With Quote
Old 07-04-2009, 03:38 AM   #2
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Code:
Engine Load (Calculated) (g/rev)	Engine Speed (rpm)	Ignition Total Timing (degrees)	Manifold Relative Pressure (psi)	Throttle Opening Angle (%)	Primary Wastegate Duty Cycle (%)	Injector Duty Cycle (%)	Target Boost* (psi relative sea level)
0.46	2298	30.5	-5.8	0	0	7.84	-1.37
0.33	2233	29	-9.58	0	0	4.29	-1.35
0.28	2106	16.5	-10.88	0	0	0	-1.28
0.3	1958	11.5	-10.88	0	0	0	-1.14
0.41	1719	11.5	-11.03	6.67	0	0	-1.08
1.11	1776	4.5	-4.79	24.71	2.35	6.44	0.23
0.95	3212	8	-0.73	48.63	9.8	14.39	5.69
1.23	3150	19	0.58	76.86	17.65	18.81	12.61
1.39	3279	14	1.16	99.61	22.35	22.5	17.58
1.52	3358	12.5	2.32	100	29.8	25.96	18.1
1.7	3458	10.5	3.63	100	37.65	28.77	18.1
1.81	3529	9	5.08	100	45.1	33.88	18.1
2.08	3597	7.5	6.67	100	52.55	40.67	18.1
2.33	3669	6	8.71	100	60	46.96	18.1
2.56	3754	6	10.16	100	65.1	54.7	18.1
2.85	3824	6.5	12.48	100	68.63	57.92	18.1
2.94	3937	7	14.07	100	68.63	65.51	18.1
3.06	4028	8	15.09	100	68.24	71.31	18.1
3.08	4092	8.5	15.38	100	68.24	72.45	18.1
3.09	4157	8.5	14.95	100	68.24	72.72	18.1
3.04	4230	9	14.95	100	68.24	72.64	18.1
3.01	4322	9	14.95	50.98	68.24	72.85	18
1.06	4176	9.5	-3.34	0	0	0	-4.95
0.78	4278	9.5	-7.98	0	0	0	-4.95
0.62	3978	9.5	-8.56	0	0	0	-4.95
0.61	3782	12	-8.56	2.35	0	10.85	-3.11
0.7	3351	24.5	-7.4	3.92	0	10.82	-2.84
0.67	2995	18.5	-7.11	4.31	0	8.31	-2.63
0.65	3016	34.5	-7.4	4.71	0	7.08	-2.65
0.67	3038	34	-6.82	9.02	0	7.78	-2.67
0.7	3047	33	-6.24	9.41	0	7.8	-2.67
0.64	3050	34	-6.38	9.8	0	7.78	-2.65
0.57	3045	34	-6.67	9.02	0	7.79	-2.65
0.58	3028	35.5	-7.25	7.84	0	7.1	-2.65
Old 07-04-2009, 01:25 PM   #3
b00stin
Member#: 212898
05 CGM STi
WFC #289
Is it tuned? Changing out the turbo in a rex to and STi is a big dif... Along with bigger injectors. Since you finished around 1 in the morning im assuming you just installed everything and drove off? And was this a 3rd gear pull or 4th?
b00stin is offline   Reply With Quote
Old 07-04-2009, 02:32 PM   #4
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I am using hte appropriate map for this car like the title says. That was a 3rd gear pull. But I found the problem anyways, some old 2003 dry rotted and cracked vac line in combination with a coupling on the intercooler that was possibly leaking. Either way, runs good now and hits 18.x psi just like the map calls for.
to assume.. makes an ass of you and me ...
06 wrx:VF34 but running VF39 93 oct map? iraj AccessPort 2 02-01-2010 09:26 PM
Low boost on OTS 2006 18g 93 Oct Map dangerman3 AccessPort 3 04-10-2007 07:45 PM
91 oct VS 93 oct maps black05STIguy AccessPort 5 10-21-2006 09:05 PM
Using Stg 2 93 oct map. more mods than specified ConstantProject AccessPort 2 07-25-2006 12:13 AM
VF34 turbo with VF39 93 oct map???? Bala AccessPort 2 04-27-2006 10:01 PM
