07-04-2009, 01:16 PM | #1 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Rear suspension bushing tool
I have the Whiteline Plus bushings for the lateral links and trailing arms and have access to a press.
I would like to know however what tool (brand, PN, etc.) I will need to effectively press out/in the rear trailing arm bushing located in the knuckle. Thanks.
07-04-2009, 03:51 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
a big ass socket would work.
07-05-2009, 07:01 AM | #3 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
The rear trailing arm bushing in the knuckle is very very easy to press out.
I had a harbor freight bushing press kit that I was going to use, but the heavy duty c clamp in the kit couldn't really fit right without taking off the rotor, so I tried to use a normal cheap c clamp, and the bushing popped right off with little force or trouble. didnt even have to use a socket or anything, just put one clamping side on the bushing, the other on the knuckle, and tighten. |
07-05-2009, 11:03 AM | #4 |
Member#: 123843
NESIC
Thanks for the feedback.
I have big sockets so that's not a problem. I thought about a c-clamp fastwrx25 and I have a couple of those. I don't do too much work and did not really want to spend $100 or more on a bushing install/removal kit. Now if it stops raining out here and my friend is around I can whip the entire bushing in/out in a few hours. |
07-07-2009, 03:10 AM | #5 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
good luck. That bushing makes a helluva diference
FS: CA - Group N rear suspension bushing kit | not12listen | Suspension/Brakes/Handling | 5 | 03-18-2010 02:33 PM |
Energy Suspension Rear Shifter bushing?? | Silver04DE | Transmission (AT/MT) & Driveline | 3 | 09-10-2005 07:12 AM |
Anyone have rear suspension bushing experience? | Opie | Brakes, Steering & Suspension | 7 | 12-17-2003 01:45 PM |
Bushings and Rear Suspension Diagram | NewSuby | Brakes, Steering & Suspension | 2 | 03-28-2002 12:05 AM |
Rear Suspension noise/Swaybar bushing lube? | RacerX | Brakes, Steering & Suspension | 9 | 08-29-2001 05:24 PM |
