Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-04-2009, 06:52 PM   #1
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Lightbulb Build your own sub box for the Baja!
For those of you who might be interested... I finally went and got the dimensions of my sub box I built a year or two ago. I believe - when we built it - at the time I measured it to be approx. 1 cu. foot per chamber - there's a divider down the middle. It's a sealed box, dual 12s. I would have gotten more pics if it wasn't so darned rainy out right now. So much for fireworks tonight I guess. I'll try to post up some more pics later.
For now, I've got some older pics of when it was originally installed. I've added a much larger amp since these were taken:
moonzie is offline   Reply With Quote
Old 07-04-2009, 07:47 PM   #2
texwr1889
Member#: 139147
2004 WRX
Doubles as a back massager for rear passengers, charge em by the mile LOL. That's badass tho nicely done
texwr1889 is offline   Reply With Quote
Old 07-04-2009, 09:53 PM   #3
qmania2
Member#: 215369
'07 STI - Alice
Urban Gray Metallic
damn bro thanks! this helps a lot!
qmania2 is offline   Reply With Quote
Old 07-22-2010, 06:17 PM   #4
Ahzlon
Member#: 45216
2005 Baja Turbo
WOW.. that helps SOOOOO freeking much... Gonna build one of those asap.
Ahzlon is offline   Reply With Quote
Old 07-22-2010, 06:44 PM   #5
BajaSleeper
Member#: 186725
2006 Baja Turbo
Youre amazing!
BajaSleeper is offline   Reply With Quote
Old 07-22-2010, 11:21 PM   #6
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I think I am going to get rid of my bazookas and make a box like this. Once I can finish my other projects with the car, I am jumping on it. I'm in
Baja_Gernaut is offline   Reply With Quote
Old 07-23-2010, 02:54 PM   #7
Emsanon
Member#: 152508
2003 Baja
Good ol' Classic Yellow!
I like the back massager idea.
I get a lot of water in the back in that area so I would love to do something like this but I would need to protect it from the water.
Emsanon is offline   Reply With Quote
Old 07-23-2010, 03:33 PM   #8
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Before I carpetted the back portion that stucks into the bed, I actually slathered up the entire back half with clear silicone calking. I think I went through a tube and a half or maybe 2 tubes - completely sealed and protected from any water/moisture.
Old 07-25-2010, 01:11 AM   #9
Emsanon
Member#: 152508
2003 Baja
Now THAT is perfect!!
Old 07-29-2010, 04:39 PM   #10
BajaSleeper
Member#: 186725
2006 Baja Turbo
Something that was suggested to me for keeping it waterproof was spraying th back of the box with rhino liner.
Old 07-29-2010, 04:43 PM   #11
Emsanon
Member#: 152508
2003 Baja
Well that's a good idea. Hmmmm. I might have to try that with mine. I've been wrapping mine in a large garbage bag.
Old 08-13-2010, 08:35 PM   #12
Ahzlon
Member#: 45216
2005 Baja Turbo
Hey what is the thickenss of the plywood that you used for you box??
Old 08-15-2010, 01:29 AM   #13
WYSubaru
Member#: 154884
2005 Baja turbo
I think it's 3/4" according to the drawing.
WYSubaru is offline   Reply With Quote
Old 08-15-2010, 01:16 PM   #14
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
That's correct.
Old 08-18-2010, 06:27 PM   #15
Ahzlon
Member#: 45216
2005 Baja Turbo
*palmface* sorry should have RTFD
Old 10-16-2011, 12:51 PM   #16
Jungle_44
Member#: 43545
2000 03 Baja
Collision Tech / Painter
I made a fiberglassed version! thanks for the dimensions!
about 1 cubic foot, inner air space, perfect for a 10" !!!
Jungle_44 is offline   Reply With Quote
Old 03-05-2013, 04:09 PM   #17
rsytek
Member#: 348591
Question Did you have to remove the pass-thru door?
To use this Sub design, did you have to remove the pass-thru door? I'm guessing yes.
So my questions are:
* How to remove the pass-thru door and
* How to disable the sensor that complains my pass-thru door is open?
I would appreciate any feedback or assistance.
Cheers!
Robert Sytek
2005 Baja, KnN, custom light/winch bumper
(working on a 4 inch lift)
rsytek is offline   Reply With Quote
Old 05-17-2015, 01:11 PM   #18
Wrench150
Member#: 365099
Default How to remove back pass through door in 05 Baja
I'am also trying to build a double 10 inch speaker box for my Baja,and it seems that the measurements that where posted where slightly off but not a problem when building custom stuff sometimes you need to modify to fit your own vehicle.So with that I also need to know how to remove the pass through door so the box will fit right and seat can be used.
thanks for any help anyone can give me
Wrench150 is offline   Reply With Quote
Old 06-02-2015, 11:04 PM   #19
steven765
Member#: 105920
2006 Baja 5 Speed
4 bolts under the plastic panel that runs across the bottom. It just pops up.
As for the sensor there's a latch at the top where it opens. You'll have to remove most of the rear trim start at the floor of both passenger doors, the storage modules, the headrests, unscrew the tie downs, then finally pop off the long piece of trim across the back to access the switch. You should be able to just disconnect it and it will no longer work.
steven765 is offline   Reply With Quote
Old 06-15-2016, 06:09 PM   #20
Nokturnal1228
Member#: 448952
I wish I had thought of that! I never use my pass-thru. Although I my bed cover does leak just a bit hehe
Nokturnal1228 is offline   Reply With Quote
build-your-own ignition coil for ej22? SubarNoober Service & Maintenance 2 01-06-2010 10:39 PM
Build your own slip plates for alignment? Type2 Brakes, Steering & Suspension 18 10-07-2009 01:59 PM
Build your own gaming computer for under $800 Kenji815 Off-Topic 55 03-17-2009 07:38 PM
Build your own catch can for $25. Here is how: txl146 Service & Maintenance 5 04-10-2006 09:57 AM
Build your own rally car for cheap! B D Off-Topic 25 06-29-2005 11:04 PM
