Welcome to the North American Subaru Impreza Owners Club Sunday October 4, 2015
Old 07-04-2009, 10:22 PM   #1
Member#: 169017
02 Bugeye
Default Best way to get front Rotors off
Replacing my pads and rotors today using Kastle's insturctions from the brake sticky. Had no issues changing the rear rotors, but can't even get the fronts to budge, tried smaking them with a rubber hammer a bunch of times to no avail. Is there something I'm missing that needs to be loosened/removed (although I don't believe so). Any suggestions or ideas? or am I just not using enough brute force?
5hif73r is offline   Reply With Quote
Old 07-05-2009, 12:15 AM   #2
Member#: 37146
2005 Legacy GT
Stage tree fitty
Do your rotors have threaded holes to turn 2 bolts to pry the rotor off the hub? That's the technique I use. I think I use something like a pair of M8x1.25 (40mm length) bolt. You'll see the holes near the center of the rotor hat.
Th3Franz is offline   Reply With Quote
Old 07-05-2009, 10:13 AM   #3
Member#: 115154
2005 Outback XT
White on grey
yeah there's 2 threaded holes in the hat, use that to back the rotors off the hub. The bolts holding the top radiator brackets will fit into them...ask me how I know
rougeben83 is offline   Reply With Quote
Old 07-05-2009, 11:26 AM   #4
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
PB Blaster, used conservatively and the two bolts.
Spray PB Blaster between rotor and studs and between rotor and hub, use sparingly. Use bolts, both, to effectively "walk" the rotor off the hub.
Old 07-05-2009, 12:38 PM   #5
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The fronts should come right off using the two bolts in the hat method.
The rears, however, may not be so easy. You'll need to release the parking brake, then use the parking brake adjusters in each knuckle to fully retract the brake. Even then, depending on the wear pattern, the parking brake may not let the rotor come off. At that point, you'll need to go buy M8 threaded rod and use it like super-long bolts to force the rear rotor off the parking brake shoes.
Old 07-05-2009, 06:04 PM   #6
Member#: 103405
These things can be a pain with rust, like others have said if you have threaded holes on your rotors find bolts that fit them and run them in evenly; this will pull it off. If not make sure the parking brake is not set (if on the back) and you can use a rubber dead blow to get them off. If they are not getting reused then just any old hammer will do.
TrackReady is offline   Reply With Quote
Old 07-06-2009, 10:38 AM   #7
Member#: 111067
2002 Old and
I personally used the "5lb sledge hammer, hammering away like a mad man...even using a weight lifting belt for support" method. The fronts came off after like 30 mins of work and the rears with 20 mins of work. They were destroyed afterwards though and these rotors had 50k miles of stuck on.
mattxander12 is online now   Reply With Quote
Old 07-06-2009, 11:07 AM   #8
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....or the bolt that holds the brake line to the strut.
Kean is offline   Reply With Quote
Old 07-06-2009, 08:43 PM   #9
Member#: 62182
2005 STI
I wouldn't use any bolt that you can't afford to stretch / mess up the threads on. Find one that fits, then go to the hardware store and get some with the same thread, grade 10.9, and use those.
grippgoat is offline   Reply With Quote
Old 07-07-2009, 01:39 AM   #10
Member#: 107964
2004 WRX Wagon
Platinum Silver Metallic
i just did this yesterday and it worked perfectly for me on both front brakes with just the "Magic 8 Bolt" (M8x1.25).. as soon as you get a good thread in.. start ratcheting it on slowly and you'll feel the rotor start to come off.. then viola!
if you're really in a pinch (and have a wrx).. the leftmost bolt that holds on the stock intercooler would work here.. but i'd suggest just buying a M8x1.25
jace2k5 is offline   Reply With Quote
best way to get water stains off STI seats sc00ter Car Care & Detailing 4 11-13-2008 08:10 AM
best way to get bird crap off Hedbergsuby07 Car Care & Detailing 22 09-20-2008 01:31 AM
Best way to get tree sap off the paint? wrxsubaru Car Care & Detailing 15 12-26-2004 05:02 AM
Best way to get the car off the ground??? The_Triton Service & Maintenance 35 08-13-2003 09:09 PM
('93-'01) Quick. Best way to get shoe polish off. the_gille Impreza Forum 11 05-29-2001 02:37 PM
