Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-05-2009, 12:15 AM   #1
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default What happens when a 42 year old gets a 09 WRX?
Well when that person just happens to run a small enthusiast driven suspension products company it means for once in 6 years our focus will ALSO include the WRX owners and NOT just STI owners !!
Mods how is this relevant to this forum and why not put it in a project thread?..well because I plan to show new things here and various options for the 08/09 WRX and update from time to time. These updates will be more grassroots and main stream than in the past.
What do we have in the works?
Shocks, sways, rack bushings, coilovers, camber plates and more.
Any way, here is the car. I got the more conservative color too.
RaceComp Engineering is offline   Reply With Quote
Old 07-05-2009, 12:16 AM   #2
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
heh heh.. will some of these carry over to the LGT?
Th3Franz is offline   Reply With Quote
Old 07-05-2009, 12:30 AM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
First thing I did was brake pads,lines and fluid. I was very upset to discover that SOA instead of giving us LEGACY brakes, they gave us WRX brakes. I know this car weighs less, but it has ALOT more power than the Legacy.
While we have backed away from "JDM" brands in recent years, The number of viable options were limited for pads. In this case, Hawk only has HPS and HP-plus pads and those were not available when I ordered the same day I brought the car home. I called Ken from KNS brakes and he ordered me some Hawk pads. I checked with PFC...nothing. I checked with Ferodo,...nothing. I checked with Pagid....nothing. So I called Endless USA and of course since these calipers are used in Japan on something...they already had the application. So I ordered the SSS pads which are 1 level down from the SSM ( which we ran on Project Grocery Getter). Overnighted the Endless pads and installed the next day. No worries, when the Hawks come in I will install and do some comparisons.
Old 07-05-2009, 12:31 AM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 07-05-2009, 12:32 AM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 07-05-2009, 12:39 AM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The first thing I noticed was for a car with ALOT of power, the brakes were "ok" during normal braking but when hauling down from say 100mph, the the pedal gets mushy and there isnt alot of feedback as to if you will be able to stop.
The addition of the pads and lines eliminated this. These SSS pads are for "some track" and spirited street driving. These have already passed the wife test and barely sqeal from time to time. She says she heard some sqeal on monday and then again on Friday. Totally acceptable she says compared to my Pagid Yellows on the STI a few years back !!
So far so good. I did a few 130mph to 45 stops( same as Summit Point leading into turn 1) and there was no fade. Normally without heat this creates a nasty mashed potatoes and gravy pedal but it didnt. I look forward to a track day soon.
Myles
Old 07-05-2009, 12:46 AM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
by default yes, but probably moreso for the new Legacy which I have zero feelings for so far because it has no personality(IMO). But I felt that way 18 months ago about the 08 WRX !! So who knows.
One thing I am going to do is install Spec-B front alloy control arms on the 09 WRX. I am going to measure and see if it works. Alloy control arms would be nice on this car.
Myles
Old 07-05-2009, 11:21 AM   #8
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
So, here is the obvious question: What would it take to put LGT brakes on the new WRX? Lots of people (myself included) would take the LGT calipers/rotors over Brembos for a number of reasons.
cucamelsmd15 is offline   Reply With Quote
Old 07-05-2009, 03:13 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Thats easy. Install LGT rotors and calipers. I am trying to source some used calps already and try this to see if it works. I also want to try the 4 pot FHI calipers with some special rotors. Some of this is new untried so thats why this thread i felt would be helpful.
For track use I am going to want a non oem caliper, but for street I think the LGT calps will work great ,.,....IF the end user buys GOOD pads.
Myles
Old 07-05-2009, 03:20 PM   #10
MasterKwan
Member#: 98961
2003 WRX
LGT calipers work great for track usage. Carbotech sells good track pads for them. Honestly, I was as happy with the LGT's as with my brembo's, the LGT's are just heavier. If I hadn't done the STI swap, I'd still be running my LGTs.
Old 07-05-2009, 04:00 PM   #11
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Interesting Myles, I wouldn't have thought to change the pads that way. I've always taken the whole caliper off. I guess that's why you're smarter than I am?
semaj is offline   Reply With Quote
Old 07-05-2009, 04:11 PM   #12
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
Thats pretty much the standard way since it allows you to grease the slides like you should do, and much easier to push the piston(s) back. Then, just set the caliper back on the bracket, and voila. Just dont let the caliper hang by the brake line.
~T.J.
02CWRX is offline   Reply With Quote
Old 07-05-2009, 04:29 PM   #13
MasterKwan
Member#: 98961
2003 WRX
Wow. Talk about doing things the hard way...
Old 07-05-2009, 04:37 PM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
Myles has touted the LGT units for years himself but (and no offense intended with the following comment) I'm pretty sure he's quite a bit faster around track and they just wouldn't be up to the duties he'd need, plus always the issue with pad selection.
I gotta get down to the shop here in the near future and take the 09 for a drive. You can then make fun of the power (lack thereof) in my car
Daishi00 is offline   Reply With Quote
Old 07-05-2009, 07:14 PM   #15
J.biz
Member#: 191825
2009 WRX Hatch
this is great news to hear!!! btw great color choice!
J.biz is offline   Reply With Quote
Old 07-05-2009, 07:40 PM   #16
Cinna696
Member#: 185769
2008 WRX
Grey
matches my car, can't wait to see what you plan to do
Cinna696 is offline   Reply With Quote
Old 07-05-2009, 08:44 PM   #17
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Yeah I ran the LGT calps on the GC wagon with Endles SSM pads and I got that 104whp , 2850 lb wagon down to a 1.32 at Summit Point main course. I never ran the Kool brake kit either and the calipers held up well. But keep in mind I only got 110 on the straight and was braking at the first marker !! lol.
I think the LGT calps(calipers) work well for about a year worth of track use and heat.Beyond that they have issues and thats one of the things Keefe Lee(Xenok) used to run into with his Legacy. But his car would get about 140 on the straights and weighs 400 lbs more so surely there is more work for the calipers.
I have karted with MasterKwan and I he is fast, so his findings are certainly validated. I think the issue is with how long the LGT calps can be effective and over what period of time.
Myles
Old 07-05-2009, 09:17 PM   #18
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Myles....there ya went and did it AGAIN
Old 07-05-2009, 11:15 PM   #19
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Actually, now that I think about it...I was changing rotors too, so Myles' way wouldn't work anyways
Old 07-06-2009, 09:19 AM   #20
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Great Myles Keep up the great work...
rexworx is offline   Reply With Quote
Old 07-06-2009, 07:35 PM   #21
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Eric from Stoptech is sending me some new pads and rotors to play with, so stand by for that.
Cant wait.
Myles
Old 07-08-2009, 02:39 PM   #22
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
18x9 Rota G force
Myles
Old 07-08-2009, 03:53 PM   #23
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Hellaflush boyyeeee.
boost junkie is offline   Reply With Quote
Old 07-08-2009, 03:56 PM   #24
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You're 42?!!
Old 07-08-2009, 03:58 PM   #25
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by Turn in Concepts View Post
You're 42?!!
next month yeah.
As my son calls me.." ole and crusty "..lol.
Mw
What happens to dealerships previous years new cars when the new models arrive? affinity1 Off-Topic 43 02-08-2010 04:41 PM
This Fish Is Older Then Me He Is Going To Be 42 Years Old This Year Born In 1967 tekfoc Off-Topic 26 10-01-2009 04:21 PM
42-Year-Old Woman Fatally Mauled By Her Own Pit Bulls rogue Off-Topic 82 10-06-2007 11:56 AM
HAHAH! video: 42 year old chuck norris wannabe (similar to the star wars kid) Protege Menace Off-Topic 36 08-10-2004 07:01 PM
What happens when you push an entire blocks worth of power through a 25 year old can? Sean New England Impreza Club Forum -- NESIC 3 06-30-2003 08:50 AM
