Old 07-05-2009, 01:16 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default how much work needs to be done to fit 18x8.5 +31mm
Like what the title said.
Im driving a 06 rex. 5x100 and got a deal for the new Advan RSD. There isnt much offset to play with for 5x100. So, im trying to see if i can do a spacer that converts my 100 to 114.3 for the new wheels.
Apart from that, do i need to run alot of neg camber to fit 8.5s +31mm? I'll prolly run 235/40 rubbers on them. Thanks!
jacky599r is offline   Reply With Quote
Old 07-05-2009, 09:26 AM   #2
marecki777
Member#: 192630
2005 WRX
you can run that setup on stock suspension. if any thing you might want to roll your fenders but that can be done after you throw them on if needed. im runnin 18x9.5 on 235/40s on stock suspension and i have a little rub but besides that no issues.
marecki777 is offline   Reply With Quote
Old 07-05-2009, 12:05 PM   #3
mosc
Member#: 177401
2015 STi White
There's about 20mm between +53 225s and the rear fender well from my experience. You're at 22mm less offset and 5mm further tire so I'd say you have to roll the rear fenders about 7mm which is borderline for requiring a pull too. Fronts may need minor work but shouldn't be that bad.
31 offset is really not a good idea for these cars btw...
mosc is offline   Reply With Quote
Old 07-05-2009, 10:33 PM   #4
atvracer111
Member#: 112179
2015 0RS,15STI,16wrx
Red, Black, Black
I have 18x8.5 with 245/40/18 and I had to roll my finders in the rear. Mine are +35 offset.
atvracer111 is offline   Reply With Quote
Old 07-06-2009, 03:40 AM   #5
jacky599r
Member#: 137631
2006 WRX
Red
camber?
Old 07-07-2009, 11:02 AM   #6
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I run 18x8.5, +30 and it took a lot of work to make them fit.
Roll in the front, cut in the rear, and a bit of camber. The biggest issue though was the conflict between the wheels, ALK, and APS intake and fmic. You can't fit it all.
As for the guy running stock suspension and 18x9.5, why bother?
Looks like it's half complete, and you'll never be able to drop it without the massive effort to make it all fit.
Then again, you're running 235 on a 9.5" rim, so you're obviously not in it for the performance...
steve is offline   Reply With Quote
Old 07-07-2009, 12:54 PM   #7
mosc
Member#: 177401
2015 STi White
When it comes down to it, you can get lots of 8.5" wide options with plenty of offset and run 255 wide tires with relatively little headache. 265 on the GD is a real headache regardless of rim and 8.5" wide is sufficient for 255 wide. Thus, if you're getting 255 wide, any wider than 8.5" rim, especially with a lower offset, is really just shooting yourself in the foot for fitment just to look cooler.
Old 07-11-2009, 07:27 AM   #8
jacky599r
Member#: 137631
2006 WRX
Red
i actually plan on running 235s.
Else, what camber am i looking at? I dont slam my car though. Following the rule of thumb of 14/13.5 inch from the centre hub for a balance between performance and looks.
What needs to be done to fit brembos on 07 WRX wheels? gopsu Newbies & FAQs 1 08-22-2007 11:04 PM
Anyone know what need to be done to export a car to the States? H5N1 Vancouver Impreza Club Forum -- VIC 0 01-08-2006 03:23 AM
FMIC; what kinds of mods need to be done to fit GC8?? alex85 Subaru Conversions 97 08-10-2005 02:39 PM
what all needs to be done to upgrade to vf22 godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2004 11:02 PM
How much work have you actually done today? Teh Legacy Off-Topic 37 12-04-2003 09:23 PM
