Old 07-05-2009, 03:40 AM   #1
budman5201
Member#: 149572
Default Turbo 2.0 in porsche 914 Temperature problems
I have had a ej25 NA engine in my porsche 914 and loved it. No temperature problems whatsoever. Ran nice, etc. I now tossed that one, and upgraded to a 2.0 turbo JDM and i am getting it tuned in with my Link STORM ECU and the temperature keeps on popping up, but the more i rev it and if i drive on the freeway, the temp comes down to 90 Celcius. (think thats 194 F). I assumed i had an air bubble somewhere, but i burped it and it will not burp anymore. (level of water stays the same in resevior) if i idle for a while the temp pops up to 100-110 celcius. (then i rev it and it comes right back down to 90)
My coolant route on the engine. I eliminated ALL extra hoses, etc. The coolant now runs when its cool (thermostat closed) from thermostat through the block and out the back of the head to the turbo and then through a single coolant line back to the water pump. (i put a new water pump in with only one outlet. (i have no heater,etc i live in arizona)
When warm it sucks both radiator coolant and the turbo coolant through the water pump, up the block and out to the turbo and out the radiator and back from both to the pump again.
Is my route wrong, and why?? (no coolant throttle bypass or coolant for idle valve bypass anymore)
thanks guys i need help
budman5201 is offline   Reply With Quote
Old 07-05-2009, 03:53 AM   #2
hondaeater69
Member#: 60324
this might not belong in the newb section
Old 07-05-2009, 04:03 AM   #3
budman5201
Member#: 149572
Default thanks
i cant post yet in the other sections, so this is where i had to ask my question , sorry
Old 07-05-2009, 10:29 AM   #4
quazimoto
Member#: 70395
Have you tried changing the thermostat?Maybe the fans are not working?
quazimoto is offline   Reply With Quote
Old 07-05-2009, 12:58 PM   #5
budman5201
Member#: 149572
nope not yet, i did test the old one before putting the engine in. I boiled water and it opened like it should in a pot on the stove. I measured the temp too of the water with my laser temp gauge.
Old 07-05-2009, 01:20 PM   #6
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Makes me think the same way as below
Did you change the size of any piping or hoses when you modified it over the NA set up?
Did you run your NA in AZ last year during the summer? I'm assuming its hot as hell there right now, how'd it do? Both of my VWs with water cooled conversions hover around 100C at idle with the fans running even when its 75F. These set ups are tricky to burp, with the long coolant lines from front to back of the car its tough to get all the air out, hopefully you have a cap up front too to monitor coolant level there.
Hopefully Matt Monson or some of the other 914 guys see your post. Might be worth shooting him a pm if you can.
theotherguy is offline   Reply With Quote
BOOST table ej20 Turbo in Porsche 914 budman5201 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-18-2009 09:00 AM
Want to replace my 2.0 in my Bugeye and put in a 2.5 Legacy GT driveline... B-Kerr Subaru Conversions 6 03-14-2009 05:14 PM
wanted turbo 2.0 or 2.5 with computer and wiring JDArmstrong Private 'Wanted' Classifieds 3 11-18-2006 09:02 PM
Just bought new Subaru Legacy Turbo 2.0 996vtwin Brakes, Steering & Suspension 2 05-18-2004 11:28 AM
Why I hate our 2.5 engines vs. the turbo 2.0 Ryouga Mid West Subaru Owners Club Forum -- MWSOC 6 01-21-2001 09:05 PM
