Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 02-18-2010, 02:47 AM   #1
swarka
Member#: 45837
Default help !read ECU Fault Codes 26!
my car is impreza rs 4eat my00.
check engine start lighting when accelerating the car hard. after that stop lighting.
i do read the ECU Fault Codes by connecting The black (1 pin) connectors .
the code are 26. what this code mean??
swarka is offline   Reply With Quote
Old 02-18-2010, 09:01 AM   #2
quazimoto
Member#: 70395
You need to use a true OBDII scanner/reader.
Old 02-18-2010, 01:20 PM   #3
swarka
Member#: 45837
ok thanks man
Old 02-18-2010, 04:27 PM   #4
adhawk76
Member#: 238778
obdII scanner
adhawk76 is offline   Reply With Quote
Old 02-18-2010, 06:01 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
swarka, are you outside the US or North America? All of our cars here since 1996 have been OBDII and do not have the option of reading codes by the method you describe (that only applies here to OBDI vehicles '95 and older).
If you are in fact in another country with a non-OBDII vehicle, you will get more accurate assistance on one of the international forums where others have similar vehicles.
Old 02-22-2010, 05:01 AM   #6
swarka
Member#: 45837
THANKS EVERY ONE ! IT WAS THE MAP SENSOR AFTER OBD II SCANNER. THE PROBLEM RESOLVE.
THANK MUDLER I AM outside the US or North America .......
04 Sti ABS Problem Fault Code Please Help tolishel Brakes, Steering & Suspension 7 02-28-2010 03:08 AM
NEED help with ecu trouble codes please... wont rev over 1500rpm Bcoolsti Service & Maintenance 14 08-16-2009 09:55 PM
CEL Fault code 546 Please help Unreal Graphix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-06-2006 05:42 PM
Help with Fault code (P0447) JeremyRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-14-2005 08:34 PM
Help reading transmission codes serious Transmission (AT/MT) & Driveline 3 04-01-2003 04:18 PM
