Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-05-2009, 11:23 PM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default My GT3076R Bugeye Build...
Hello,
I have been working on this pile for a few months now. Collecting parts, making small mods. After having the motor out for 2 months, I've finally begun assembly of my "new setup" so I thought I may go ahead and document it for those who are interested. This is the first time I've pulled a motor from my own vehicle and done all the work, though I have helped others with their projects in the past.
The motor consists of:
  • --EDIT-- New short motor in the works...
  • ARP Head Studs
  • EJ205 Heads
    -Ported, Crower Valves: +1mm Intake, +1mm Exh, DPR 264 cams, Crower Springs, Crower Ti Retainers
  • Impreza 2.5i Intake Manifold
    -Modified for use of Cable TB and WRX Fuel Rails
  • Borla UEL Header
  • P&L Rotated Up-Pipe and downpipe
  • --EDIT-- New turbo coming soon...
    -0.82 A/R Turbine Housing
  • TiAL 44mm WG
  • Turbo XS Intercooler Modified for CC Flow
  • TiAL 50mm BOV
  • GS EBCS
  • Bosch 1000cc Injectors
  • Perrin Fuel Rails
  • Aeromotive FPR
  • Walbro Pump
  • UTEC running in SD
Other:
  • ACT Clutch
  • 2004 STi Drive-line
    -Transmission, DS, Rear Axles, R180, Rear Hubs/Brembo's
  • Stoptech Front Big Brake Kit
  • Group N Motor/Trans Mounts
  • Custom Coolant Tank Relocation Bracket/ EBCS Mount
  • Tein Hood Dampers
    -My favorite mod
  • Some Gauges
    -Greddy: Boost, EGT, Oil Pres., Oil Temp., Fuel Press.
    -AEM: WB02
  • Tein Super Street Coilovers
  • Rotas
  • Braided PS line
The old 18G managed a best of [email protected] pushing 306/296 on Turbo XS's Dyno. My goal now is 400whp on that same dyno or at least 11 second 1/4 mile passes.
I will be updating this thread as I go, and trying to add any useful information I pick up along the way. If you have any questions, let me know. I may even know the answer!
As it sits today, 7/5/09:
CKxx is offline   Reply With Quote
Old 07-05-2009, 11:33 PM   #2
JSarv
Member#: 163445
l33t *******
[email protected]
Its going to be teh slowest evar.
Did you go with a Tial V-band turbine housing?? If so please post pictures for my masturbating session!
Looks good man keep the pictures coming! Glad to see a 2.0 and big turbo done right!
-Jerod
JSarv is offline   Reply With Quote
Old 07-05-2009, 11:40 PM   #3
Midwestrider
Member#: 42955
2004 Bone Stock..
Nice... good luck in your build and goals!
Midwestrider is offline   Reply With Quote
Old 07-05-2009, 11:44 PM   #4
CKxx
Member#: 33458
93 RX7+09 Forester
Today I chased the threads on the block with my nifty chaser tool (see below), cleaned the old gasket remains off the deck, installed the ARP studs, installed the new gaskets (OEM) and torqued down the heads.
ARP Studs: Threaded into the block only "hand-tight." (I used the little end of an allen key.)
New OEM Head Gaskets:
Heads Torqued:
Old 07-05-2009, 11:49 PM   #5
CKxx
Member#: 33458
93 RX7+09 Forester
-Jerod
Sorry, no v-band housing. It is a newer GT housing (T3 inlet/GT outlet), though, and not the older T-31. I'll have pics of it posted by next weekend, hopefully. I plan to re-install the motor at that point.
Old 07-05-2009, 11:59 PM   #6
JSarv
Member#: 163445
l33t *******
[email protected]
Sweet - .82 housing should be bitchen' on the 2.0 - Nice flow and moderate lag!
I've always used a tap for chasing threads... But that looks to work just as good.
What heads are those?
-Jerod
Old 07-06-2009, 12:12 AM   #7
CKxx
Member#: 33458
93 RX7+09 Forester
I'm hoping for 20psi at around 4600rpm.
I didn't want the razor sharp tap to cut the "good parts" of the threads.
Regular EJ205 with porting from DPR, as well as the other parts mentioned. A gentleman in Puerto Rico had the same 264's in a 10-flat STi, so I figure they should work pretty well.
Old 07-06-2009, 12:28 AM   #8
jason miller
Member#: 158313
2003 WRX
This build looks awesome, and I'm betting you meet or exceed your spool expectations.
jason miller is offline   Reply With Quote
Old 07-06-2009, 12:54 AM   #9
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Looks Nice, another nice bugeye build... Keep it up
TDagen is offline   Reply With Quote
Old 07-06-2009, 01:28 AM   #10
zac5
Member#: 141702
06 apex silve Evo9
Wrong Fitment Crew #054
Sweet. Im patiently waiting for the next update. Good luck on the build
zac5 is offline   Reply With Quote
Old 07-06-2009, 11:26 PM   #11
CKxx
Member#: 33458
93 RX7+09 Forester
More fun today. Drilled and tapped my Borla Manifold for for the EGT gauge, then wrapped that beast, as well as the Perrin up-pipe.
Wrapped Mani:
Following that I installed my cams, and test fitted it all, along with my intake manifold. I was afraid that the turbo inlet would not clear my Old-School Perrin fuel rails, but that ended up not being an issue due to my 3" tapered turbo inlet. A full 4" inlet will NOT clear these rails, for the record. I also found out that with the 2.5I manifold I'll need to either 1) remove the intake manifold gasket alignment dowels, or 2) grind away some of the base of the manifold itself. I tried to yank the dowel, but that sucker was stuck, so it looks like I'll be grinding the manifold.
Old 07-07-2009, 11:22 AM   #12
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Make sure you paint the header wrap really well before you go putting the engine/exhaust piping in the car.
Mine just plain disintigrated form all the heat/cooling and moisture evaporation.
skimobile is offline   Reply With Quote
Old 07-07-2009, 11:35 AM   #13
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
I had the same problem with those rails, i was able to order another side from Perrin and run both in the front of the TGV's. Id look for new rails at this point.
Token-Negro is offline   Reply With Quote
Old 07-07-2009, 12:06 PM   #14
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
Nice build!
Too bad its not in a wagon
bigolrig is offline   Reply With Quote
Old 07-07-2009, 01:07 PM   #15
scprs
Member#: 172359
2005 STi
damn very nice build!
scprs is offline   Reply With Quote
Old 07-07-2009, 02:15 PM   #16
CKxx
Member#: 33458
93 RX7+09 Forester
Wirelessly posted (BlackBerry9530/4.7.0.148 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
Was that a custom order? My two rails are mirrors of one another.
Old 07-07-2009, 06:40 PM   #17
stamps31757
Member#: 189810
2002 WRX Sedan
subscribed
stamps31757 is offline   Reply With Quote
Old 07-07-2009, 06:51 PM   #18
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
wow, subscribed buddy.
blakkboxer is offline   Reply With Quote
Old 07-07-2009, 06:54 PM   #19
Kyle13
Member#: 214284
1993 Ford
Seafoam Green
Subscribed! This is gonna be awesome!
Kyle13 is offline   Reply With Quote
Old 07-07-2009, 07:06 PM   #20
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Looks good, but why the egt probe in the #4 cylinder instead of the #3?
scby rex is offline   Reply With Quote
Old 07-08-2009, 12:36 AM   #21
CKxx
Member#: 33458
93 RX7+09 Forester
I read a ton of posts, and even found a poll. It seemed that cyl4 was the most prone to failure.
Heck, I even purchased one or two of my parts from someone who blew cyl4 and was parting out the car.
EDIT: As far as work done today...not much. I did drop off my PS line at the hydraulic shop so they can make a braided stainless model for me. I also ordered a whole mess of these press-connect pneumatic fittings (2 can be seen on top of manifold, above). They are made to operate around 150psi, and won't blow off until over 300psi. I'm going to run them for my Wastegate, EBCS, BOV, and FPR.
Old 07-08-2009, 12:42 AM   #22
Ammata
Member#: 155819
2004 Impreza WRX
nice......
Ammata is offline   Reply With Quote
Old 07-08-2009, 01:06 AM   #23
SubeN'Siren
Member#: 151171
02 Subaru WRX
Subscribes....
SubeN'Siren is offline   Reply With Quote
Old 07-08-2009, 05:40 AM   #24
G-See
Member#: 66215
Nice and refreshing change vs the usual 2.5 builds. Bet it revs hard when done!
Subscribed.
G-See is offline   Reply With Quote
Old 07-08-2009, 09:29 AM   #25
Big_DeWeY
Member#: 37078
95 L
Blue-ish
I'm in! I'm doing a similar build myself but not quite as large of a turbo. This might be a peek into the future.
Big_DeWeY is offline   Reply With Quote
WI Bugeye build thread/my first 'motor build' CrashTest Mid West Subaru Owners Club Forum -- MWSOC 1 05-11-2010 11:00 PM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 08:02 PM
WTT: My GT3076r for your GT3582r CKxx Private 'Wanted' Classifieds 7 11-24-2009 01:00 AM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 06:07 PM
My GT3076R Came EARLY! Who wants to come help install... TONIGHT! Lazerus Rocky Mountains Impreza Club Forum -- RMIC 7 09-27-2008 10:45 PM
