Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-06-2009, 07:09 AM   #1
col5555
Member#: 142017
Default Stock 2.0 and 2.5 pistons and offset
Do stock 2.0 and 2.5 pistons come with offset pin.
If No could the use of forged pistons with offset in a 2.5 which has a less than ideal rod ratio allready result in increased bore/piston wear and could this increase in bore loading be the cause of may split bores and failures in the 2.5.??
col5555 is offline   Reply With Quote
Old 07-06-2009, 12:24 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
They both do ,Not sure about that causing the splits in the bores though?
I would think w/ out the offset wrist pin some increase in sidewall loading but prolly not enough to split the cylinder , usually that's from having it bored & reducing the thickness of it IMO.
sense of nature is online now   Reply With Quote
WTT: 2.0 or 2.5 heads for CP STI pistons upjeeper Private 'Wanted' Classifieds 2 12-04-2007 10:54 AM
2.0 shortblock, New Wisco pistons and ACL bearings reddevil Engine/Power/Exhaust 8 08-21-2007 09:46 PM
2.0 shortblock, New Wisco pistons and ACL bearings SE Portland reddevil NWIC Private Classifieds 11 08-21-2007 09:46 PM
2.0 vs 2.5 guinsu Subaru Conversions 21 02-03-2005 08:52 PM
