Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 07-06-2009, 12:04 PM   #1
xtreme carbon
Member#: 208395
2003 wrx
black pearl
Default idle help!!
about 2 months ago I started noticing the cars idle start dipping when i stopped, then it went away. now it came back and it dips down to 200 300 rpms and then comes back. the car normally idles at 800. I tried the iacv gasket, cleaned and changed it out and still no luck. if anyone knows any other problems i might be having please share!
xtreme carbon is offline   Reply With Quote
Old 07-06-2009, 12:52 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Do you use the AC? Assuming it is the manual transmission and the AC is off, the idle speed should be 750 rpm.
Also, are you sure it dips to 200 - 300 rpm? Are you talking about below the first line on the tachometer?
z&cobb is offline   Reply With Quote
Old 07-06-2009, 04:21 PM   #3
xtreme carbon
Member#: 208395
2003 wrx
black pearl
yes its a 5 speed, no ac, and yes under the first dash mark
Unstable idle idle help.. WRXBob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-10-2008 08:55 AM
high idle!!!! now choppy idle help! Thran Newbies & FAQs 18 02-22-2007 10:12 PM
high idle, now low choppy idle?!?! help Thran Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-17-2007 12:44 PM
Very rough idle...HELP! bouse1 Normally Aspirated Powertrain 1 08-10-2001 03:15 PM
ruff idle.......HELP! NateDogg Normally Aspirated Powertrain 7 05-27-2001 12:59 AM
