![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 189180
SCIC
Vehicle:04 wrx jbp stg dos 03 Infiniti G35s |
ok i want to get some 225/50 for the rear but i have these two concerns.
1. I want to keep the 205's up front, can i run the 225's safely without effecting anything? (I will buy the 225/50's if i have to) 2. I have the cobb sport springs so the drop is about 2 inches the rear tires have negative camber (will post pics when i get of work), will the wider tires not be a good mix with the negative camber? Thanks
#2 |
Member#: 198633
NESIC
Vehicle:2004 WRX Black |
Why do you want that combo? What makes you think it will be better than 225's all around?
#3 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
You should run the same size tire on all 4 corners.
#4 |
Member#: 189180
SCIC
for one im a cheap bastard
and two the tires up front are almost new but thats fine ill buy 4 if concern number 2 isnt an issue . Thanks |
#5 |
Member#: 137398
E. Canada
Vehicle:2004 Impreza 2.5RS Platinum Silver Metallic |
#6 |
Hoodbridge!
Cobb springs are too low, so you get a lot of unwanted rear camber. I'd suggest getting at least some camber bolts to get back some positive camber in the rear.
#7 |
Hoodbridge!
Wht are the rear tires worn and not the fronts? Are you rotating your tires? Are the tires wearing abnormally in the rear?
| Thread Tools | |
| Display Modes | |
| will i get in trouble with 225/50 R16 blizzaks on stock rims? | littlebhatia | Tire & Wheel | 3 | 11-05-2009 12:03 AM |
| Tire pressures for 225 50 r16s | horf | Tire & Wheel | 0 | 02-19-2004 01:57 PM |
| E-Town: FS ==> 225/50/R16 Ecsta Tires - CHEAP | markus | Canada Region Forum | 1 | 07-30-2003 11:59 AM |
| 225 50 r16 on stock wrx rims? | harowerksxcr | Brakes, Steering & Suspension | 0 | 10-08-2002 09:48 PM |
| 225/50 R16 fit ok? | huey | Brakes, Steering & Suspension | 8 | 02-15-2001 01:19 PM |
