Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 07-06-2009, 06:11 PM   #1
Zaffir
Member#: 67874
2003 WRX, Wagon!
Default Unable to Locate Coolant Leak
The other day I had white smoke coming out from under my hood. It smelled sweet: obviously coolant. It had sprayed all over the front of my timing belt cover and there were small drops of coolant on the top of the accessory belt cover and alternator.
The next morning I went out and let the car warm up. Sure enough, drops of coolant on the top of the engine and coolant was starting to pool on the top edge of the timing belt cover. Even a good steady drip under the car. But I couldn't find the leak. No pinhole, no cracks in the radiator or any hoses, nothing.
Armed with more info from NASIOC - for coolant to be getting where it is the issue is probably my radiator - I tried to find the issue again today. Now all I have is some pooling on top of the timing belt cover just slightly to the passenger side of the crank pulley. Nothing anywhere else.
I'm having a shop look at it tomorrow, but any ideas in the meantime?
Zaffir is offline   Reply With Quote
Old 07-06-2009, 07:10 PM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Wipe off coolant.
From a cold start, pop the hood and as the car comes up to temp you should be able to see where it's coming from.
Spenk is offline   Reply With Quote
Old 07-06-2009, 07:27 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
or pressure test the cooling system, you can buy a coolant pressure tester from the auto parts store.
then you can look for you leak while pressurizing.
coolant leak from passenge side. Can't locate Rallyfreak202 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-03-2010 02:35 PM
small coolant leak radiator how much to fix? nightmoves001 Service & Maintenance 22 01-11-2010 09:50 AM
Leaking coolant - best way to locate? Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-16-2007 01:56 PM
how to locate oil leak, HELP!! xblaze1one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-09-2007 12:39 AM
Coolant leak, car overheated, what damage to look for? DoorKnob Normally Aspirated Powertrain 1 06-20-2004 07:44 PM
