Old 04-29-2002, 09:00 AM   #1
rap4th
Member#: 8970
2005 Legacy GT Ltd
2004 Forester XT - Silver
Default Suspension making creaking noise
Hello all!!
Just a quick question. I have noticed lately that my wife's 02 Outback Sport is making a creaking noise from the suspension when going over bumps or anything else that would make the car's suspension move (ie coming to a stop and the nose dips a bit or when starting from a stop when the nose rises and the rear dips it makes a creaking noise). Does anyone else know what I am talking about and if so, what can be done to resolve the creakieness
rap4th is offline   Reply With Quote
Old 04-29-2002, 09:11 AM   #2
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
same here
rupteur7000 is offline   Reply With Quote
Old 04-29-2002, 12:43 PM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
wrong forum..
But I am having this problem too but only on the drivers side and I am driving on version 5 struts and eibach prokit springs. Also my wing is a little loose back there too (only one bolt), Im going to tighten that tonight along with installing sti strut tops in the rear (already have em in the front). I will reply in this post if I find anything out.
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-29-2002, 12:52 PM   #4
rap4th
Member#: 8970
2005 Legacy GT Ltd
Default sorry....
Sorry,
I thought I was in the correct form. Which form should I be in?
Also, I don't have any suspension modifications...it is all stock.
Old 04-29-2002, 01:49 PM   #5
99OBSter
Member#: 14324
1999 OBS 4eat
I think Blindeye_03 means this should be in the "Service and Mainentance" forum...maybe not though.
Well, if it's under warranty, I say get it checked out by the dealer. I have a 99 OBS and my suspension doesn't make any noise, at least that I can hear over the road noise let in by my crappy sound insulation.
99OBSter is offline   Reply With Quote
Old 04-29-2002, 08:15 PM   #6
chri3
Member#: 16245
I have the same prob. I think its coming from the rear left side. Whats up with that???
chri3 is offline   Reply With Quote
Old 04-29-2002, 08:24 PM   #7
Blindeye_03
Member#: 4418
2016 Focus ST
i think it belongs in suspension forum..Im just offering that as a suggestion so more people see it.
I am not getting the strut tops installed tonight, puttin it off till Wednesday, I will post here the results if I find anything damaged (might help you out a little).
-justin
Old 04-30-2002, 09:30 AM   #8
ImpreziveRS
Member#: 6312
2001 Impreza 2.5 RS
Blue Ridge Pearl
Hey guys, I've had this problem for about 9 months now. The suspension "creaks" when i go over bumps or pull into driveways with those little concrete water run-off things in front of them. Good Luck Getting Subaru to Fix it . I've had my car at the dealer 3 times for the problem and they just tell me that they can't re-create my complaint. I've even also taken the district service manager for a ride, he heard it, and told me he'd check in with the engineers and get a hold of me in about a week. That was 3 months ago. I have noticed that when someone is sitting in the back seat, the noise either doesn't occur or isn't as loud as it is with some not in the back seat. Good luck with your experiences guys...
Kyle
ImpreziveRS is offline   Reply With Quote
Old 05-01-2002, 06:34 AM   #9
steppin16
Member#: 6010
mine happens when i get out of the car
steppin16 is offline   Reply With Quote
Old 05-01-2002, 09:20 PM   #10
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
Hello, I had a similar problem to this for a long time. Whenever I pulled away from a stop sign or something like that, I would get this strange creak. At first I thought it was the suspension, but when I would push on the car when parked, there was no noise. It really confused me. I finally went crazy one day and tightened everything that could possibly be loose under the car.
Turns out that, it was the heat shields over the exhuast pipes that were making noise for me. I've had the noise come back a few times, and once I tighten the heat shields, the noise goes away.
Anyhow, I don't know if this will help you guys, but doesn't hurt to give it a try.
~Alan
DoorKnob is offline   Reply With Quote
Old 05-01-2002, 09:24 PM   #11
michaelwrx
Member#: 12861
2001 Impreza WRX
WR Blue
I had a similiar problem with front passenger side of my MY02 (MY01 here in Aus). Subaru replaced shock and lower arm to no avail.
Turns out it was the fuel filter clips rubbing on the panelwork. Anytime there was engine movement (stop/takeoff) or body flex the parts would rub.
Not sure if the RS has the fuel filter in same stop but worth a look
Michael
michaelwrx is offline   Reply With Quote
Old 05-02-2002, 08:59 AM   #12
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
I didn't notice until I changed the springs on my car. The front springs do not have anything under the spring itself. It is just metal to metal. There was no rubber insert on there from the factory. The rear struts have a rubber pad that the spring rests on, this keeps it from making noise. I hear it out of the front, not the back. Every time I hit a bump, I get a click or bang from the front springs. It's a lot noisier now with the aftermarket springs.
Stealthbmbr is offline   Reply With Quote
Old 05-03-2002, 07:42 AM   #13
Blindeye_03
Member#: 4418
2016 Focus ST
my clunking (in the rear) disappeared with the install of my rear sti group n strut tops.
-justin
Old 05-03-2002, 10:42 AM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
grease your sway bars ...
The plastic casing surrounding my shifter makes creaking noises. macrwrx Interior & Exterior Modification 3 03-04-2004 01:37 PM
My shifter's platic casing seems to be making a creaking noise? macrwrx Interior & Exterior Modification 0 03-03-2004 10:51 PM
Suspension making clunking noise, Help! RebelINS Brakes, Steering & Suspension 5 07-17-2002 05:12 PM
Suspension making bd noise after acident. Help me to figure out what it might be. 25psi Brakes, Steering & Suspension 4 02-04-2002 02:41 PM
