Old 07-07-2009, 12:21 AM   #1
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
Default Front tires worn on inside edge
Checked out my front tires tonight. The inside edge of is worn pretty good, you guys think I can get away with rotating them to the back or do I need a new set? Tire Rack has some rims I want on sale, but I really can't afford it right at this moment. I could always sell the rims/two good tires I have now to make up for it a bit (rims are 06/07 stockers).
What do you guys think?
DumbstixLars is offline   Reply With Quote
Old 07-07-2009, 01:09 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya need an alignment
'0' toe
them tires is fine
Old 07-07-2009, 01:18 AM   #3
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
'0' toe
them tires is fine
Think so? I mean, I know it needs an alignment, I'm finally going to have time to do it this week, any numbers I should know for camber?
Thanks!
Old 07-07-2009, 01:29 AM   #4
05-rsx
Member#: 101188
MY07 WRX Wagon
'0' toe
them tires is fine
+1 for getting rid of the toe.
Maybe some camber too (whatever the stock bits and bobs will give you) if you're cornering hard on them.
05-rsx is offline   Reply With Quote
Old 07-07-2009, 03:37 PM   #5
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
Total toe was set to -0.81 when I took it in this morning. It tracks a lot better now that its set to 0 degrees. Thanks for the help guys!
Inside front tires worn out from springs. sike43 Brakes, Steering & Suspension 13 09-20-2006 12:44 AM
tire rubbing on inside of fender josh...just josh Tire & Wheel 4 10-24-2005 01:35 AM
How does tire wear on the edges effect your ride/grip? PinnacleChronos Tire & Wheel 1 06-01-2005 08:58 PM
Why is the inside of my front tires worn? garmin Tire & Wheel 8 06-18-2003 01:01 PM
