Old 07-08-2009, 09:03 PM   #1
kakarotoni
Member#: 156240
02 WRX
06 Impreza
Default Built heads BC springs/retainers & sti cams
Ive tried to search this but its a hard question to find out. Im looking to get built 2.0 wrx heads for a 2.5 hybrid build. I am wondering if I can get away with using STI cams (of course avcs plugged) and using them on built 2.0 heads with brian crower springs, retainers, with racing valves and shimless buckets. I have the option of using stage 3 cams but feel that is overkill on a simple 18g set up for now (stock tranny).
If anyone knows or runs with that set up let me know.
kakarotoni is offline   Reply With Quote
Old 07-08-2009, 09:07 PM   #2
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***breaking in***
i would personally do the "stage 3" cams, i'm guessing BC280s? if you PNP your head, and build it, then your sti cams are gonna be the restriction.
do it once not twice =)
penusai is offline   Reply With Quote
Old 07-08-2009, 11:26 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You can run whatever cams you want it there but one of you choices is better than the other and it ain't the STi choice.
Old 07-08-2009, 11:28 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you can use an AVCS cam with the setup...use the non avcs cam seals and you have it right with plugging them.
I would suggest a little bigger than factory if you can. I'd run BC 272's, which the BC cams really are NOT aggressive.
Old 07-09-2009, 04:41 PM   #5
kakarotoni
Member#: 156240
02 WRX
06 Impreza
Thanks guys, well after researching the cams, I definately think Im going to buy stage 2 cams that have a duration of 272 and run those instead.
Old 07-09-2009, 07:41 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Yeah 272's are what you need.
godforbid67 is offline   Reply With Quote
Built WRX heads BC272's Springs retainers ETC. perrin247 Engine/Power/Exhaust 8 05-16-2010 12:25 PM
fs: sti bc springs+retainers, ported 20g, jdm sti manifold..and more spooling impreza Engine/Power/Exhaust 18 03-12-2010 11:24 AM
FS/FT Ported 04 wrx heads, NEW BC springs/retainers+STI valves 5hif73r Engine/Power/Exhaust 3 09-12-2008 09:47 PM
FS: AVO wastegate actuator, BC springs/retainers, boost solenoid, oil pump takeshi999 Engine/Power/Exhaust 18 08-07-2008 02:39 AM
F.S Wade Cams, ARP head stud & Sti Cams, blackbeast Engine/Power/Exhaust 4 05-09-2007 10:08 AM
