07-07-2009, 11:32 AM | #1 |
Member#: 197744
E. Canada
Vehicle:2009 Impreza Sport Black |
2009 Impreza Sport clunk/poping noise from back of car when first taking off
2009 Impreza Sport
Hi I hear a quite clunk/poping noise from back of car when first moving forward after backing up out of the driveway, with in a few seconds of driving forward. Is this a normal sound for the impreza to make? it seems to do it every time the car sits for awhile like every morning. My dealership has never heard of this noise and it didn't make the noise when it was being checked out at the dealership. The dealer ship took a look underneath but did't see anythoing wrong.
07-07-2009, 11:46 AM | #2 |
Member#: 197937
E. Canada
Vehicle:2016 Golf R Under the radar silver |
I thought i was the only one with this problem!
I get the exact same thing, reverse out of the driveway, then a clunk from the rear as i start move forward. Only in the morning after sitting overnight, and it doesn't happen if the car is facing out and i don't have to use reverse. No idea what it is, and i haven't been under the car yet to take a look. I fitted a rear WRX sway bar and was wondering if the noise was related to that, but now, maybe not..... |
07-07-2009, 11:54 AM | #3 |
Member#: 165393
E. Canada
Vehicle:2009 WRX Satin White Pearl |
Stock 265 (WRX), also get this clunk, but even without reversing....i get it with every first forward motion from a cold start. Mind you I also usually have to turn both while backing out or when pulling out of a spot forwards (rarely pull out straight).
07-07-2009, 11:55 AM | #4 |
Member#: 128002
International
Vehicle:2023 Toyota 4Runner Silver |
My car does it too. I think it's something to do with the E-brake.
07-07-2009, 11:57 AM | #5 |
Member#: 112168
NESIC
Vehicle:2006 WRX Wagon WRB 2003 Honda 919 (WRB too) |
I have an 06 WRX, and when I transition from backwards to forwards or for to back, the pads in the calipers move slightly causing a knocking sound. This may be what you're hearing. This happened with OEM and Hawk pads, so it doesn't concern me.
07-07-2009, 12:13 PM | #6 |
Member#: 211961
Vehicle:09 WRX Blue |
I get it too in the morning after my ebrake has been on all night. I don't know for sure but I think it is the ebrake also.
07-07-2009, 12:19 PM | #7 |
Member#: 200321
South East
Vehicle:2009 Forester 2.5XP Armpit Green |
mine does it too and in the exact same situation. I wouldnt sweat it.
07-07-2009, 12:41 PM | #8 |
Member#: 61280
Vehicle:2001 1.8T |
07-07-2009, 12:46 PM | #9 |
Member#: 119397
NWIC
Vehicle:06 STI & 13XT WRB |
+1...I have it too but I think it is e-brake related as well.
07-07-2009, 01:02 PM | #10 |
Member#: 177794
W. Canada
Vehicle:2008 WRX SSM |
It's could be your vehicles ABS system self check which is normal.Or it may be the clunky center differential.They like to make noise as well.
07-07-2009, 01:19 PM | #11 |
Member#: 197744
E. Canada
I found out it has nothing to do with going backword ands then forwards, and I also have never used the ebreak so idon't think that is the problem. I'm going look into the ABS self test and see it thats the problem.
07-07-2009, 01:54 PM | #12 |
Member#: 142543
Vehicle:05 STi PSM |
I'm 99% sure that this has come up before and the verdict was that its the differential. Use the search function to try and find out more.
07-07-2009, 06:56 PM | #13 |
Member#: 178213
SCIC
Vehicle:2008 WRX WRB |
I heard it was the AWD doing a check. ABS is more likely though.
07-07-2009, 07:59 PM | #14 |
Member#: 198898
Vehicle:2012 wrx Silver |
Its the brakes setting themself. perfectly normal.
07-07-2009, 09:14 PM | #15 |
Member#: 40989
Vehicle:OT vag inspector |
it's michael jacksons body tumbling back and forth
07-07-2009, 09:21 PM | #16 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
its either the ABS self test, or the hill start assist if you back out onto an incline.
07-07-2009, 09:25 PM | #17 |
Member#: 207417
Vehicle:2009 WRX td06sl2-20gtx 413/423 |
haha im glad im not the only one. i thought i was starting to go crazy for a bit
07-07-2009, 09:39 PM | #18 |
Member#: 171948
Vehicle:19 Sti Crystal white |
its the brake system. mine has done it since new. no problem.
07-07-2009, 09:43 PM | #19 |
Member#: 209987
Vehicle:2009 Slow WRX Slower Prius |
Mine does it, too. My last car (07 TSX) also did it. It's just the brakes.
07-07-2009, 09:43 PM | #20 |
Member#: 205280
Vehicle:2012 Jeep Wrangler Bright Silver |
My 09 did this too. I've never had a car EVER that has made this noise.
07-08-2009, 12:44 AM | #21 | |
Member#: 174022
TXIC
Vehicle:2008 WRX Lightning Red |
Corret it the ABS self check. Had Subaru look at my vehicle for a week with the tech line and this is what they came up with. Your car is actually doing it when you pull off everytime. Reverse then forward brings out the noise very well for some reason. |
07-08-2009, 10:04 AM | #22 |
Member#: 59036
Vehicle:2016 Forester XT Venician Red |
Good to know, heard it also yesterday. ;-) Thought i ran over something. lol
07-08-2009, 12:02 PM | #23 |
Member#: 165576
Vehicle:1998 Legacy GT 5mt |
Your 2009 Impreza has Incline hill assist, first gear, and reverse. the brakes are activated untill it detects movement and releases them. That is more than likely what you are hearing and it is normal.
07-08-2009, 06:33 PM | #24 |
Member#: 216135
Vehicle:2011 |
Wow, I heard this the last two days pulling out of the driveway and going forward....was about to call Subaru!
07-09-2009, 08:45 PM | #25 |
Member#: 216135
Vehicle:2011 |
On 4 separate occasions, I had my scanner plugged in after a long sit with the live data reading. At 7mph on the dot, the clunk/sound occurs. The owners manual says the ABS self test occurs at 7mph. I think we are fine.
Clunking/binding noise from front of car | J_R_B | Brakes, Steering & Suspension | 6 | 05-17-2012 12:50 PM |
Help..... Odd noise from rear of car once I let off gas. | scurabus | Transmission (AT/MT) & Driveline | 0 | 01-11-2010 08:34 PM |
Noise Coming from Back of Car | snowdude | Newbies & FAQs | 13 | 05-04-2009 10:33 PM |
02 WRX Noise Coming From Back Of Car | killa996 | Newbies & FAQs | 11 | 12-04-2006 01:42 PM |
Thumping/Clunking noise from rear of car | imisplacedmine | Newbies & FAQs | 6 | 06-03-2006 01:33 PM |
