Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-07-2009, 02:47 PM   #1
boostedballs
Member#: 164977
1991 Legacy SS
black
Default 4EAT Torque Bind, Fuse does not activate FWD; where is solenoid?
The car: 1997 Legacy GT, 4EAT 177K miles.
Torque bind big time (I've had torque bind in other Subies but nothing like this) this is severe.
I installed the fuse over the right front fender but it does nothing. I am guessing that the solenoid that controls the AWD has burnt open. I checked the wire harness to the trans for pulled pins and corrosion. Looks fine.
I want to replace the solenoid myself. I won't even let another "mechanic" change my oil; I'm just anal like that.
Does anyone have a photo or just a good description of where this solenoid is? I assume it will be attached to the valve body but do I need to remove the valve body or did Subaru locate it in an easily accessible location?
Also, I have a 4EAT that works perfectly from a 91 Legacy SS, I think the final drive ratio for both is 3.9; can I swap that one into the 97 GT?
Also (again) If I were to go with the "GM limited slip additive route", how much should I add?
Thanks!!!!
boostedballs is offline   Reply With Quote
Old 07-07-2009, 11:58 PM   #2
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
[email protected] Subarus-R-Us
That'd be the transfer clutch solenoid in the tailshaft of the tranny. Ive seen them so bad that the fuse dosnt do anything kinda like whats going on with yours right now. If you pull the tailshaft off there will be one connector. Disconnect that and the solenoids on the tailshaft held on by a couple 10mm bolts.
Subieformance_Guy is offline   Reply With Quote
Old 07-08-2009, 02:00 AM   #3
boostedballs
Member#: 164977
1991 Legacy SS
black
Cool
Sweet, I'll give that a shot!
Old 08-23-2009, 08:13 PM   #4
87GL
Member#: 103350
Hey guys, I've got the same problem: torque bind and the FWD fuse doesn't change the situation. On a sidenote, I couldn't get the "handshake" to work either(to show a trouble code). On another sidenote, I haven't checked the tires for equal circumference.
But in the mean time, can anyone give me more details on changing out the C solenoid? E.g. how do I take off the tailshaft and what does the C solenoid look like?
Thanks,
Andy
87GL is offline   Reply With Quote
Old 08-24-2009, 08:19 PM   #5
87GL
Member#: 103350
Based on some more research, I need to:
1. Remove rear driveshaft
2. Remove exhaust system after catytic converter
3. Remove "tail" of transmission
4. Change solenoid...is there a way to test it? I assume I just need to test for an "open" condition which would confirm it's faulty.
Thanks,
Andy
Someone does not believe carbon fiber is hard to damage SenorFartman Off-Topic 5 06-01-2005 12:59 PM
Is a '04 WRX 4EAT torque converter compatible with a 2002 WRX 4EAT? scooterforever Transmission (AT/MT) & Driveline 6 03-05-2005 08:25 AM
Does anyone here live where there is NOT a Wal-Mart? -=C=- Off-Topic 44 11-17-2004 05:07 PM
Keyless entry does not work when WRX is running?? burton13 Car Audio, Video & Security 9 10-28-2002 11:51 AM
Is this torque bind? BJamerican Transmission (AT/MT) & Driveline 4 05-02-2002 01:03 AM
