Old 07-07-2009, 04:49 PM   #1
Fine Line Imports
Member#: 81166
2008 Forester
Default 07 WRX with a Blouch Dom 2.5
We finished up this customers car a while ago but forgot to post the dyno graph in here till today. This customer is a avid auto-X with his 07 WRX as well as this being his daily driver. All of the mods are pretty basic and we ended up with a nice power band that is a blast to drive on the street. This is by far one of the funnest daily driven cars we have built in a long time.
Engine:
06 STI long block
Cobb AP Ver2 with FLI protune 20.5 PSI boost and Meth injection
APS 3.5in TBE
APS Header
Blouch dom 2.5
STI TMIC
JDM Ver 5-6 big maf air box.
PE 850CC injectors
Aquamist HFS-5
Suspension
KW Variant 3 coilovers
Cobb front and rear sway bars
DMS camber plates
Whiteline ALK
Drivetrain:
ACT stage 1 clutch
ACT flywheel
Cobb SS with bushings
04 STI wheels
For more info on this car check out our block at http://fliblog.wordpress.com/2009/01...ca-competitor/
Ryan
Fine Line Imports
www.finelineimports.net
Fine Line Imports is offline   Reply With Quote
Old 07-07-2009, 06:12 PM   #2
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow that turbo comes on hard! Like stock vf-43 hard but lasts way better to redline.
Nice job!
Steve.804 is offline   Reply With Quote
Old 07-07-2009, 06:35 PM   #3
boxerfxt
Member#: 163728
My Dream Turbo!!!!!! Mmmmmmmmm
boxerfxt is offline   Reply With Quote
Old 07-07-2009, 06:57 PM   #4
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
one of the better spooling charts i've seen for the 2.5r, its hitting 300wtq close to 3100 rpms.
Illusive is offline   Reply With Quote
Old 07-07-2009, 06:58 PM   #5
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Nice powerband!
Dave D. is offline   Reply With Quote
Old 07-07-2009, 09:12 PM   #6
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
VERY nice!
shadowmd is offline   Reply With Quote
Old 07-07-2009, 09:45 PM   #7
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
damn nice
Su||y is offline   Reply With Quote
Old 07-08-2009, 04:29 AM   #8
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Nice #'s on that mustang dyno!
RonJitsu is offline   Reply With Quote
Old 07-08-2009, 08:24 AM   #9
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
great numbers and powerband!
Tomas26 is offline   Reply With Quote
Old 07-08-2009, 08:43 AM   #10
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
they are nice if it was indeed a mustang dyno
BlackJavaPearl04 is offline   Reply With Quote
Old 07-08-2009, 10:04 AM   #11
Chris_Lee
Member#: 110667
2006 WRX
Great numbers....this is one of my favorite turbo's.
Why did you stick with the STi TMIC?
Obviously the injectors where not maxed out but did you have to use a Big MAF with this set-up?
This is a 07 wrx right? What has been done to the gears to support all this added power?
Chris_Lee is offline   Reply With Quote
Old 07-08-2009, 10:29 AM   #12
sutter2k
Member#: 92467
08 STI
How the heck is this thing coming alive so early. I had this turbo on my legacy, though it took 800 rpms later to be fully kicking.
sutter2k is offline   Reply With Quote
Old 07-08-2009, 11:52 AM   #13
Fine Line Imports
Member#: 81166
2008 Forester
The Aqaumist kit has a lot to do with the turbo coming on so early. Without the meth injection it would be around 7-8 hundred RPM later like you stated.
Ryan
Fine Line Imports
Old 07-08-2009, 11:54 AM   #14
Fine Line Imports
Member#: 81166
2008 Forester
This is a 07 WRX the customer had hit 06 STI engine laying around so that was swapped in there. Currently after this last season of AutoX he finished the tranny is still holding together. How long it holds together is up for debate.
Ryan
Fine Line Imports
Old 07-08-2009, 12:41 PM   #15
Chris_Lee
Member#: 110667
2006 WRX
Did you run into any heat soak issues using the STi TMIC with the 2.5r?
Old 07-08-2009, 12:55 PM   #16
jason05wrx
Member#: 93398
2008 STI & FXT
Do you do a non meth tune as well? If so I would like to see that chart.
jason05wrx is offline   Reply With Quote
Old 07-08-2009, 01:30 PM   #17
Fine Line Imports
Member#: 81166
2008 Forester
A little but not to bad with the Meth injection. Things always get pretty hot in the dyno room. If you are planning on running this turbo hard or at the track I would recommend the better top mount intercooler.
Old 07-08-2009, 01:36 PM   #18
Fine Line Imports
Member#: 81166
2008 Forester
Yes we did use a Big maf in this setup Its a little hard to tell in the picture but it is the Airbox and maf tube from a version 5-6 JDM STI the maf housing on the stock piece is a little over 3 inches
Old 07-08-2009, 01:41 PM   #19
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Nice. And it makes me worry less about my APS TMIC/DomIII combo.
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 07-10-2009, 03:46 PM   #20
kawrx2002
Member#: 73957
2006 STi
This is an interesting turbo as Ive been researching this one and the 20g a long time now. For the most part, an 20g 8cm will outperform this spool wise, about equal hp on pump gas. But on meth is where this baby shines, much better spool and top end.
kawrx2002 is offline   Reply With Quote
Old 07-10-2009, 04:02 PM   #21
Fine Line Imports
Member#: 81166
2008 Forester
I would say that is a pretty fair statement. Considering on pump gas 20g's are about the same power. We are doing a One of these at the shop right now with a APS FMIC so it will be interesting to see how far we can push it.
Ryan
Fine Line Imports
Blouch Dom 2.5 meth/non meth 2.5L k04sti Proven Power Bragging 30 02-10-2010 01:12 PM
FLI 07 STI Blouch Dom 2.5 tune Fine Line Imports Proven Power Bragging 7 09-15-2009 05:53 PM
wtb:fp green or blouch dom 2.5 or 3.0 Derek C Private 'Wanted' Classifieds 0 04-01-2009 06:29 PM
wtb:fp green or blouch dom 2.5 or 3.0 Derek C NESIC Private Classifieds 0 04-01-2009 04:47 PM
