Old 07-07-2009, 05:30 PM   #1
SUBIE-STI
Member#: 209777
2005 STI
Default AP V1 Stage 2 93 map-How much PSI?
I just reflashed with the Stage 2 93 octane from Cobb with my AP1 and i dont think its reaching the correct amount of boost its supposed to be, i was just wondering how many PSI its supposed to hit, im going off my stock boost gauge that reads in MPa and its getting halfway between .05MPa and .1MPa and that almost seems like stock boost after being converted but i may be wrong, anybody have any ideas or anything?
SUBIE-STI is offline   Reply With Quote
Old 07-07-2009, 06:16 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
16.5+-0.7 Psi Oops.That's for the wrx don't know what it is for the STi...
EDIT; 17.5+-0.5 Psi for the STi.
wrxdrvr is offline   Reply With Quote
Old 07-07-2009, 08:30 PM   #3
SUBIE-STI
Member#: 209777
2005 STI
So would anybody know what the deal is of why mine isnt hitting anything but maybe 10-11psi of boost? I just got it back from Cobb because it was getting reset by them, should i try and reflash it again with the Stage 2 again? Im pretty sure im at stock boost, atleast thats what it seems like.
Old 07-07-2009, 08:48 PM   #4
b00stin
Member#: 212898
05 CGM STi
WFC #289
Cobb Stage 2 for STi is 19psi. Search google for a MPa - PSI converter if you want to know exactly what it is, or just use your AP! Log Log Log...
b00stin is offline   Reply With Quote
Old 07-07-2009, 08:49 PM   #5
b00stin
Member#: 212898
05 CGM STi
WFC #289
O and when you start up your car turn on your AP and go to Maps or tuning and then show current map and it will tell you. Just reflash STage 2 if it is stock.
Old 07-07-2009, 08:58 PM   #6
SUBIE-STI
Member#: 209777
2005 STI
So why am i only reaching 10-11psi of boost? Im sure 19psi is a huge difference from stock, should be able to tell a descent amount of difference.
Old 07-07-2009, 09:57 PM   #7
SUBIE-STI
Member#: 209777
2005 STI
I just reverted it back to stock a couple minutes ago so i will try reflashing to a stage 2 again in the morning and see if i can get 19psi of boost out of it on the way to work.
Old 07-07-2009, 10:42 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
http://www.cobbtuning.com/info/?ID=3061 17.5+-0.5 Psi is what I see here... Not 19.0 Psi.
Old 07-07-2009, 11:02 PM   #9
b00stin
Member#: 212898
05 CGM STi
WFC #289
If your AFR is still in spec (11.4 - 11.0) Than you should be fine.
Old 07-08-2009, 11:45 AM   #10
SUBIE-STI
Member#: 209777
2005 STI
I reflashed the car again first thing this morning, its fixed now and is reaching target boost. Thank god i dont have a problem with my car.
Old 07-21-2009, 08:13 PM   #11
route6mafia
Member#: 217928
2007 STi
Default Please Help Need Boost!!!
I reflashed and can only hit 17.1psi
route6mafia is offline   Reply With Quote
Stage 2 93 map needs tuning... WiRX AccessPort 1 04-11-2009 02:19 PM
v1 Cobb AP Stage 2 93 v130 Map Question tyc17afguy AccessPort 7 03-18-2007 11:14 PM
"Det " w/ the Cobb AP 91oct stage 2 lwg Map Mach5WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-19-2004 10:03 PM
cobb stg 2, 93 oct. how much is too much? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 07-01-2004 11:49 AM
Cobb Stage 2 93 map ECU swap $100 wrx_fun Rocky Mountains Impreza Club Forum -- RMIC 6 09-08-2003 10:27 AM
