Mid Atlantic Impreza Club
Closed Thread
Old 09-30-2009, 06:30 PM   #351
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
I feel gay for not going to the track, but s2k at track ftl
LeeC is offline
Old 09-30-2009, 06:40 PM   #352
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
95 Coupe lightweight proj
Just got here, beautiful weather tonight
carnz-pj-410 is offline
Old 09-30-2009, 06:42 PM   #353
carnz-pj-410
Member#: 110994
I'm sure you feel gay for other reasons and are just covering it up with not going to the track
Old 09-30-2009, 10:02 PM   #354
LeeC
Member#: 97843
lol homo..
good time tonight
LeeC is offline
Old 09-30-2009, 10:30 PM   #355
carnz-pj-410
Member#: 110994
was a good turnout and good time tonight
Old 10-01-2009, 08:59 AM   #356
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Good to meet/talk to you guys!
Remember...Autocrosser's Inc. event at Fed Ex on October 10th. Sign up at www.dlbracing.com and select "Autocrosser's Inc.".
piknockout is offline
Old 10-01-2009, 10:21 AM   #357
LeeC
Member#: 97843
Just registered!, going to get my A6's switched from my rx7 rims to my ss2k rims this evening
LeeC is offline
Old 10-01-2009, 01:04 PM   #358
piknockout
Member#: 192173
Shaweet! See you out there!
Old 10-02-2009, 09:33 AM   #359
Rexican
Member#: 156229
Tranny question: So why does everyone that does the 6 speed swaps seem to go for the 07's? What are the major advantages of this year over previoius? I'm sure its gearing but I dont compeletly understand it.
How much can stock WRX 5 speeds sell for? I'm trying to figure out how much I need to save for this.
If I want for the 07 6speed swap, how much extra is it to hookup a DCCD controller? Am I also going to have to get new wheel hubs and wheels? Sounds like this is tons O'money.
Rexican is offline
Old 10-02-2009, 02:54 PM   #360
Member#: 88758
2000 Civic
2010 Xterra
The 07 STI has better gearing meaning with the 07 STI tranny and gear ratio you are not shifting into the extra gear at the 1/4 mark.
With the 3.70 rear gear I'm not exactly how that changes in the WRX.
Factory DCCD is rather hard...there is an aftermarket Spyder Controller I believe that most use.
You will have to change axles from my understanding. 05+ STI wheels will work.
302@12psi is offline
Old 10-02-2009, 09:11 PM   #361
carnz-pj-410
Member#: 110994
The 2007 STi transmission is divided into 2 generations. The first(and best) generation has the improved 2nd-4th gears like everyone knows. But it also has the included oil pump in the transmission, this generation is $1100 more brand new than the second generation.
The 2nd generation shares all the same characteristics of the 1st gen except the oil pump has been deleted and oil splash guides are installed throughout the case. This tranny brand new can be had for about $3700.
The 06 and 07 STi trannies can be swapped into a 02-05 WRX relatively easy since they use a 1.1:1 transfer ratio like the 02-05 WRXs so the rear diff 3.54 is compatible, all you need is the trans itself, a driveshaft from a 4EAT impreza(98 and newer), STi shifter, and if you have female axles(early 04 and lower) you also need 2 axle stubs and oil seals. To make the DCCD work get a Spiider DCCD controller from www.dccdpro.com
Installation? Ask me
The best possible 6MT you could build(not counting PPG) would be:
Start with 05 6MT(so you get oil pump and 35/65 native split)
05 STi 1st gear
07 STi 2nd 3rd and 4th gears
06~07 STi Carbon Synchros
08 Legacy GT Spec B 5th and 6th Gears
JDM STi 4.11 Final Drive Ratio Ring and Pinion
04 STi APTRAC Front Differential
^this is the 6MT that I am going to build
Old 10-02-2009, 09:16 PM   #362
carnz-pj-410
Member#: 110994
Update on Ron's build, got the block back from the machine shop thursday, they did an excellent job on boring and honing the engine. I will definately go to them in the future (JB's Auto Machine Shop on Route 7).
Fresh Bores
Crank and Rods Installed, block bolted together
Pistons Installed
Oil Pump Installed
Oil Cooler Installed, coming together nicely
Due to a delay I'm hoping to have his motor ready by mid next week, I have something I have to do so I cant finish assembly tomorrow like I planned to.
Specs on Ron's Engine:
Bored and Honed to 92.5mm
OEM 92.5mm( .5mm overbore) Pistons
OEM Piston Rings
STi Forged Rods
OEM STi Rod Bearings
OEM Main Bearings
ARP Rod Bolts
WRX Intake Cams/ STi Exhaust Cams more duration and overlap ftw, the difference in duration between the 2 cams helps as well
Gimmick Motorsports Turbo Inlet Hose
All new gaskets
New PCV System
New timing belt and tensioners
New waterpump.
If anyone is curious, I went with OEM pistons over Forged because he is only shooting for 300~350whp, the weak link in the WRX is the rods(which I upgraded to STi forged which are known to handle 500whp). The tighter clearances with the oem cast pistons will greatly help the longevity over loose forged piston clearances.
-mike
Old 10-02-2009, 10:02 PM   #363
TheStigg
Member#: 215003
2004 WRX
JBP
Everything looks great so far! Can't wait till its all done. Thanks Mike!
TheStigg is offline
Old 10-03-2009, 10:32 PM   #364
LeeC
Member#: 97843
good **** mike!
LeeC is offline
Old 10-03-2009, 11:11 PM   #365
carnz-pj-410
Member#: 110994
A few more pictures...
hoping to have time to get it finished soon!
Old 10-05-2009, 06:34 PM   #366
carnz-pj-410
Member#: 110994
this thread sucks
Old 10-05-2009, 06:36 PM   #367
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
Originally Posted by carnz-pj-410 View Post
this thread sucks
No it doesn't. This thread owns ALL.
peglegsteve is offline
Old 10-05-2009, 06:42 PM   #368
carnz-pj-410
Member#: 110994
this thread sucks.
Old 10-05-2009, 06:46 PM   #369
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
this thread sucks.
Bring some life to it then!
Old 10-05-2009, 07:00 PM   #370
carnz-pj-410
Member#: 110994
i dont have any new pictures to add and nothing to talk about
Old 10-05-2009, 07:18 PM   #371
LeeC
Member#: 97843
this thread does sucks
assembling my axles tonight
LeeC is offline
Old 10-05-2009, 07:21 PM   #372
carnz-pj-410
Member#: 110994
FTW
Old 10-05-2009, 07:22 PM   #373
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
Who dat?
Old 10-05-2009, 07:23 PM   #374
carnz-pj-410
Member#: 110994
saw it on another thread, and thought it was badass
Old 10-05-2009, 11:22 PM   #375
Rexican
Member#: 156229
Rexican is offline
Closed Thread
