Alaskan Impreza Club
Old 07-08-2009, 03:11 PM   #1
rack
Member#: 32908
2005 Impreza WRX STI
BLUE
Default Oil Catch Can Installed
**This is not a how to, simply information about Oil Catch Cans (and apparently an A/O Seperator by mistake).
Links to information.
FAQ
Oil Catch Can FAQ
Installs
PDF File: Perrin Install Instructions
Crawford Install with FMIC.
Cusco Oil Catch Can Install
Another Opinion on Installation
Building your own
DIY: Build an OIL Catch Can
Accurate Machine Works: DIY Type of install
Another DIY: Build your own Catch Can
Personal Experience
Stuff about my Install
Got and installed one. Wow, there is NO room in the 05 STi to put anything extra....I ended up running the hoses down along, and over the air box, then straight to just after the T and at the Turbo Inlet Hose. They provided a bunch of foam, I didn't use it yet, Gonna see how it works without it.
Got a Red Perrin one to match all the other Red Perrin parts I have.
Ordered it from Hi-Speed Solutions.
I'll upload a picture or two tonight.
Information To think about BEFORE installing/Buying:
If your going to mount it on the passenger side strut tower, figure out where you are going to relocate that horn peice to.
Make sure you are at least 3'' away from the Turbo Heat Shield (per Perrin's instructions)
The Perrin one is litterally just a soup looking can, encased with sylicone hose, with 2 end caps. $140 might not be worth it (now that I've seen it in person). Possibly look into those $30-$50 Ebay ones with the Alan Wrench screws. Or the Greddy $89-$101 ones. However, mine is red....
rack is offline   Reply With Quote
Old 07-08-2009, 04:07 PM   #2
AKLGT
Member#: 85199
2012 turbo rollersk8
EvolvedAK's hood ornament
wow. that was fast! and yes, it looks just like mine. but I painted mine black to match the rest of my interior.
AKLGT is offline   Reply With Quote
Old 07-08-2009, 11:40 PM   #3
Crawford Performance
Member#: 42075
Crawford Performance is offline   Reply With Quote
Old 07-09-2009, 02:48 AM   #4
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
Something about a private video?
Kiwi Fella is offline   Reply With Quote
Old 07-09-2009, 03:01 AM   #5
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
A catchcan and an air/oil separator are really two very different things.
A catchcan simple collects oil from the PCV system. Actually I had one and the oil vapor just went though it and into the intake anyway. It's best to get a catchcan with a breather filter and dead end the PCV hose at the filter. You really do not need vacuum to evacuate the crankcase of oil vapor. It does fine vented to atmosphere via a catchcan.
An oil separator will take the oil vapor, cool it, turn it back into liquid, and then automatically drain it into the engine. A catchcan has to be physically emptied then oil has to be added back to the engine. The harder the car is driven the more frequently the catchcan will have to be emptied.
Here's a pic of a modified Crawford air/oil separator on my '04 RS...
SubySal is offline   Reply With Quote
Old 07-09-2009, 03:37 PM   #6
rack
Member#: 32908
BLUE
I didn't investigate all the links fully, Was just providing information.
I installed an "oil catch can" from Perrin. If I don't end up with anything inside it, I'll put the "filter" pieces in. However they were not the shape I would have expected, so I didn't put them in.
I was helping a friend last night, so no pictures yet.
I'll try to upload them tonight after class.
Old 07-09-2009, 03:39 PM   #7
rack
Member#: 32908
BLUE
Originally Posted by Crawford Performance View Post
How about an install video -
He changed the link and now I cant find it! Sorry, I will fix it soon...
This thread isn't a how to, or a source, Was just providing information to some of the local AKIC members. If you see, most of the links go to other peoples FAQ, or Installs here on Nasioc. (again was just providing a source for information, so others could see what I was talking about)
Old 07-09-2009, 05:16 PM   #8
b16h22
Member#: 90824
2009 STI
Does the Perrin kit come with a filter? What do you mean they weren't the shape?
I'm waiting on my catch cans to come in and am thinking they may require some mods to better catch the oil vapor. Something like SubySal was saying about venting and ending the line at the can may be the best way to go.
b16h22 is offline   Reply With Quote
Old 07-09-2009, 05:46 PM   #9
rack
Member#: 32908
BLUE
They were basically large circular skinny peices of foam...
When I upload pictures, I'll take some of the foam.
Old 07-09-2009, 05:59 PM   #10
SubySal
Member#: 43011
2004 Impreza RS
It's a good thread. I was just adding to the information pool too with my own experiences. That's all. I very fond of my A/O separator so I will share info unsolicited at every opportunity.
Old 07-10-2009, 03:43 AM   #11
rack
Member#: 32908
BLUE
Images put in first post
Old 07-16-2009, 01:17 AM   #12
b16h22
Member#: 90824
2009 STI
So i just got my Perrin catch cans in and i'm concerned that the ports on these things are too small. The stock hose is 3/8" and the fittings for the catch cans are like 1/8". This seems like it would create back pressure. In the catch can FAQ and on DIY threads the recommended fittings say 3/8" which makes sense to match the stock hose lines. I guess I could modify the ports by re-tapping the threads and get larger fittings. Thoughts about the smaller ports?
My Greddy oil catch can install mattjk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 01-07-2007 07:59 PM
Definitive Tread for Oil Catch Can Install. Gil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-20-2002 05:07 PM
Oil Catch Can Installation? HpiRally Normally Aspirated Powertrain 21 08-20-2002 03:19 PM
Check out my oil catch can install jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 07-30-2002 11:50 AM
cant find the cusco oil catch can install WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-08-2002 09:40 PM
