Old 07-08-2009, 05:28 PM   #1
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
Default Spacers and wheel balance + other issues with spacers
I've had no luck getting a straight answer from the Mazda forums, so I'll rely on ol' NASIOC for some advice. I've haven't seen or heard much in regards to the effect that spacers have, mainly with throwing off the wheel balance and adding stress to the studs.
Now from what I gathered, "quality" spacers such as ones by Eibach and H&R are made to be very light, fairly balanced and hub centric, which would not cause any issues. I'm only looking to at a 3-5mm spacer, nothing aggressive, just enough to add clearance to the wheel/tire and strut/spring, with the wheel that I'm choosing to go with.
Any input and can anyone with the H&R, Eibach or other brand spacers give their experience.
Yoo Shin is offline   Reply With Quote
Old 07-09-2009, 09:17 AM   #2
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
both brands you mention are very good quality and keeping the thickness at 3-5 millimeters will still allow for the wheel to engage the center hub so, the "added stress" on the lug studs will not be an issue
Old 07-09-2009, 09:44 AM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Aluminum isn't heavy enough nor is the spacer big enough in diameter for balance to be an issue with the spacer itself.
As long as you torque your lugs carefully in a sensible pattern, you should be able to get the wheel plenty centered without any contact with the hub.
Just be sure you have enough thread engagement (generally 1x the diameter of the stud).
sniper1rfa is offline   Reply With Quote
Old 07-09-2009, 09:59 AM   #4
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
I'm running a 2mm steel spacer that is ~1mm off center on the rear wheels, and have zero balance issues. But maybe off-balance is more difficult to detect on the rears than the fronts.
Mind is offline   Reply With Quote
Old 07-09-2009, 10:15 AM   #5
Yoo Shin
Member#: 87327
Great input NASIOC I really appreciate it. It's going to make my wheel choice a lot easier.
Also it seems that the H&R kits come with extended studs which I feel safer doing.
Issue with spacer/hubcentric ring..thoughts? vision.dynamix Tire & Wheel 2 02-22-2010 10:21 PM
Wheel spacers and wheel bearing wear... seafajr. General Community 0 11-29-2009 04:13 AM
Possible wheel balance mismatch issues DJS1 General Community 5 03-03-2008 06:55 PM
My other issue with my car that Carter looked at today... HiFiWRX North West Impreza Club Forum -- NWIC 20 04-23-2003 07:07 PM
To Start: Alignment and Wheel Balance package. (hunter gsp 9700 balancer) munkis Tri-State Area Forum 29 05-12-2002 10:46 AM
Message Board Statistics All times are GMT -4. The time now is 05:21 PM.
