Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 07-08-2009, 07:42 PM   #1
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
Default Help! Timing Belt Install, stuck on the... you know, install
Hey. Installing the timing belt right now. Here' where I'm at: I currently have the toothed pulley on the waterpump removed, as I changed that as well.
For the pulley, the marks on the cams and the crank all line up, and the belt seems fine. When I go to install the toothed pulley that goes on the waterpump, there is not enough slack on the belt to put it on. There is a pin in the tensioner to provide plenty of slack for the "upper" part of the belt, where the lines on the cams are.
Any advice? Need be, I can video conference with my webcam if that helps.
RS-Flyboy is offline   Reply With Quote
Old 07-08-2009, 07:45 PM   #2
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
SOHC, as well, not the DOHC.
Old 07-08-2009, 08:35 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
While keeping the timing marks correct turn the passenger side cam pulley counterclockwise while turning the driver side clockwise. This will cinch up the belt on top and give you slack.
BTW it sounds like you are doing it wrong. The water pump pulley is not the last to be installed. It is second to last! The lowest smooth pulley goes on last.
edit: See where it says "install it in the end" ?
Old 07-08-2009, 09:01 PM   #4
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
That picture is wrong. He has a SOHC. But ciper is right that the water pump goes on first. The pulley on the water pump doesn't have teeth either. Then you install the 2 tensioner pulleies. Finally you pull the tensioner pin. Although the above picture is for the DOHC, it shows which pulley goes on last before the pin is pulled. The pulley that has the pin should be the one right side to the "A" in the picture above.
Jerry Xu is offline   Reply With Quote
Old 07-08-2009, 09:14 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
The picture was for illustration purposes only. When he says "the toothed pulley that goes on the waterpump" he means the one that bolts to it which is the only idler with teeth.
BTW dont use the timing marks on the cover. You will almost always be off by a tooth. If your timing belt doesn't have marks (you didn't buy a factory one?!) you should count teeth and mark it yourself. Read this post http://forums.nasioc.com/forums/show...8&postcount=14
Old 07-08-2009, 10:07 PM   #6
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
Oy... thanks. Turns out that while everything was lined up (the belts to the cam), the right cam was NOT lined up accordingly. That slight 1/4" adjustment made all the difference.
I threw it on, and hand-cranked it about 15 times with the plugs out, just to make sure that I wasn't going to bend any valves. Ran smooth. Haven't fired it up yet, taking another beer break.
Old 07-08-2009, 10:15 PM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Originally Posted by RS-Flyboy View Post
Oy... thanks. taking another beer break.
How many of those did you have when aligning?
Old 07-08-2009, 10:19 PM   #8
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
No kidding, eh? It's a little embarrassing, really... I mean, I WROTE a DIY on RS25.com. I assumed it was because when I wrote it, I used a DOHC 98 RS, as opposed to my now 2004 SOHC Baja.
But, seeing as the warranty on it expired last year, I haven't had my hands dirtied with maintenance beyond changing oil for about 4 years or so. I guess knowing this kinda stuff is something that should be practiced now and then in order not to lose it.
*sigh*... time to change the oil now, and fill it up with coolant, then the final test (being the drive to fill up the tank).
Old 07-08-2009, 11:44 PM   #9
Jerry Xu
Member#: 36629
07 2.5i
did not see answer to the beer question...
Old 07-09-2009, 12:17 AM   #10
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
About 3 Sam Adam's Imperial White Ales. They're about 10.5%. Had another 2 when I finished up.
Just got back from gassing up. About 24 miles round trip, including some highway, and nothing is askew.
Old 07-09-2009, 07:20 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
RS-Flyboy.....in case you forgot.....the oilpan takes a 17mm boxwrench. Lefty-loosie!!!!
Jay
Old 07-09-2009, 01:03 PM   #12
Jerry Xu
Member#: 36629
07 2.5i
...man happy...
Timing belt cover and checking the timing belt Pinned Service & Maintenance 12 11-08-2010 10:17 AM
which timing belt is better than the other? GATES or OEM stock belts? 949 Built Motor Discussion 11 07-31-2009 10:21 AM
Timing belt experts - opinion on belt age from pics MYfirst00 Service & Maintenance 17 04-06-2007 11:47 AM
Stuck on the uppipe install neenjafus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-29-2005 09:02 PM
I need help- tranny install stuck on one thing BlackWagon Transmission (AT/MT) & Driveline 7 05-27-2003 01:24 AM
