Old 07-09-2009, 10:50 AM   #1
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Default Cannot turn off Valet Mode
I just took the car to get a new key and key fob on my '05 STi and those dum fux tried for about an hour to program the the key fob and I finally said, don't worry about it, I'll program it when I get home (they did successfully program a new key). While I was at the dealership, I used my Iphone to get the directions on this site and programmed the key fob in less than a minute after getting home.
Anyway, on the drive home from the stealership, my security light was blinking the whole way home (blink-blink-pause-blink-blink-pause). From this thread, that means it is in valet mode. I follow the directions found there and opened the drivers door and held the unlock button on my key fob for about 5 seconds (also tried 10 and 20 seconds) and the damn thing will not stop blinking. Is there something I missed in this thread? This is getting annoying and refuse to take the car to the dealership (I still have a warranty on the car and still wouldn't bring it in).
FWIW, I don't have a horn on my passenger strut tower (or I'm blind).
TIA,
yamahaSHO is offline   Reply With Quote
Old 07-10-2009, 01:01 AM   #2
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Looks like everyone is as stumped as me. I really hate to take it to the dealership, especially this one here.
Old 07-10-2009, 12:09 PM   #3
Micker72
Member#: 132820
2005 Impreza RS
It tells you how to change all the key fob settings including valet mode in the owners manual
Micker72 is offline   Reply With Quote
Old 07-10-2009, 12:14 PM   #4
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Agreed... I read that before starting this thread. I also read the page linked in my original post and noted that I have followed the directions stated to fix this issue and the problem still persists.
Did you read MY post?
Old 07-21-2009, 04:47 PM   #5
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
One last BUMP
Old 07-21-2009, 04:55 PM   #6
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
did you try resetting by unhooking the battery... if that doesn't work, suck it up and go to the stealership
ruckus racing is offline   Reply With Quote
Old 07-21-2009, 04:58 PM   #7
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Yeah, I tried that for about 20 minutes. I may disconnect it over-night this time.
Old 07-21-2009, 06:28 PM   #8
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
if 20min wont do it, then over night wont either... if i were you i'ld put the warrenty to use
Old 07-21-2009, 06:29 PM   #9
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
...how did valet mode get turned on? should be the same process to turn it off. just my $0.02
Old 07-21-2009, 07:16 PM   #10
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
That's more than warranty work... The dealership caused it trying to figure out how to program the damn thing.
Please read my original post. The dealership did it. They had a computer hooked up to it as well cycled the ignition like 80 million times as they had no patience.
Old 07-22-2009, 02:43 PM   #11
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
well, their work should be under some kind of warrenty. it they f'd up your car, they should fix it, free. why should you suffer because the shop you brought your car to get it fixed broke something in the process?
Old 07-22-2009, 02:50 PM   #12
punk
Member#: 169792
2005 STI
The security light always blinks, just the pattern changes. Valet is the blink-blink-pause and "armed" mode is blink-long pause-blink. My 2005 STI also did not have an extra horn, the alarm just triggered the stock horns (now Super Tones...).
Drivers door open, hold unlock until the blink-long pause-blink pattern is noticed. I've never really timed it, but it seems to be about 10-15 seconds when I switch between valet and armed mode.
punk is offline   Reply With Quote
Old 07-22-2009, 02:51 PM   #13
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
I don't think you're getting my point. I don't trust them. They're the ones who caused the problem in the first place while trying to reprogram a key and key fob. After about 15-20 minutes watching the morons trying to program the key fob to work with the car, I had to stop them and tell them I would do it. When I pulled into the garage at home, I sat in the car for about 30 seconds and programmed the remote on the first try.
Case in point, I don't trust that they'll fix it and they could possibly leave me with another problem. There is a reason why I do ALL the work on all four of my cars, and it's not to save money.
BTW, it's "warranty". I do agree, they should/will fix it for free... but that certainly doesn't mean it is within their knowledge/skill level to do so.
Old 07-22-2009, 02:53 PM   #14
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
As stated in the original post, I've done what you have described. Yes, it should blink when the car is off, but it didn't blink when the car was on when I took it in
I don't think you guys are reading my entire original post, but thanks anyway.
Old 07-22-2009, 03:02 PM   #15
punk
Member#: 169792
2005 STI
You didn't state if the pattern ever changed and if you are performing these steps with the car on/off. Hopefully you realize the steps need to be done with the car off, but I've learned not to assume anything...
I don't notice if mine blinks while the car is on and in "armed" mode, I'll have to look on my way home tonight.
Old 07-22-2009, 03:07 PM   #16
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
AAAAAAAAHHHHHHHHHHHHHHHHHHHHHH
Sorry. Anyways, I had this issue on MY05 RS and it took a few tries to get it to go out of Valet mode, but I did get it.
You did say you disconnected the battery? Did you disconnect the battery and then pump the brake pedal several times? That should reset ECU, but I don't know if that affects security features. Maybe D/c the fuse that controls secuirty features, if one exists.
Otherwise, warranty that sucker
ScubaruImpreza05 is offline   Reply With Quote
Old 07-22-2009, 03:12 PM   #17
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***in progress***
usually its the open driver door, and hold the unlock but that obviously doesn't work for you.
try the open driver door, and lock unlock lock....
penusai is offline   Reply With Quote
Old 07-22-2009, 03:51 PM   #18
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
I said more than what you quoted and you asked me questions that I made apparent in the first post.
Car on or off? You realize the key fob function is disabled when the car is on, right?
I'll try this again. I didn't use the brake pedal, but I turned on the lights and such trying to drain the residual charge out of it.
Old 09-30-2009, 07:10 PM   #19
rouckey21
Member#: 148207
02 WRX
PPG box'd
this issue just happened to my car after bein down for almost 3 months but i just did the drivers door open and hold the unlock button. it took no more than about 3 sec or so. make sure your drivers side door is completely open.
rouckey21 is offline   Reply With Quote
cannot get out of valet mode IvanFA20 Car Audio, Video & Security 12 07-24-2010 05:06 PM
help! limp mode and car turning off kaizoku_jeff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 10-26-2009 01:22 PM
how do i disengage the valet mode?? stache Newbies & FAQs 4 07-01-2002 06:47 PM
make sure its not in valet mode bahboy20 Car Audio, Video & Security 3 08-16-2001 01:46 PM
Security System stuck in Valet Mode??? cincyRS Technical Forum Archive 2 07-21-2000 09:24 AM
