Old 07-09-2009, 12:22 PM   #1
02Stevo
Member#: 124957
Default Lower ball Joint Install Questions
i havent looked at my car yet i have a 02 WRX i just bought the parts but i figured i would start a thread on this because i didnt see one
lower ball joints are they pressed in ?
what tools will i need to replace one
how difficult is this job
will my front end need to be realigned
and finally dose any one have a tutorial on this ??
just thought id post this and see what you guys all say and maybe help some newer people out with simple questions and so they no what they would be in for
02Stevo is offline   Reply With Quote
Old 07-09-2009, 12:43 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
UkNuck is offline   Reply With Quote
Old 07-10-2009, 03:02 AM   #3
sleeperrex
Member#: 19466
2002 wrx/hybrid
This was a major pain to do on my car. It was mostly getting the ball joint popped out of the control arm.
Tried everything. Had bought one of those fork things that slips through the ball joint to pop it out. I couldn't do it.
One of my neighbors saw me struggling and he came over with a big hammer and waked the fork a few times and it popped out.
sleeperrex is offline   Reply With Quote
Old 03-03-2013, 10:30 PM   #4
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
I stuck a pick through the slot in the knuckle and tapped out the ball joint. I was fortunate in that mine was only slightly rusted.
Prying with a big screwdriver in the slot probably helps. It certainly did when reinstalling the new one. Not sure if covering the cup in the knuckle and the LBJ with antisieze made much difference on the install, but certainly counting on it making a difference a couple hundred K miles from now. Sure would have been nice if they had done this in the first place.
dagger108 is offline   Reply With Quote
Old 03-05-2013, 05:09 PM   #5
atomicfire
Member#: 136296
2005 STi
Mechanic's trick; don't bother with pickle forks. Saturate the connection between the ball joint and the arm with PB Blaster. Smack HARD with a large hammer (I use a 1.5lb mini-sledge / drilling hammer) 2-3 times and it will pop right out.
Professionals use an air-hammer which does more or less the same thing, but much quicker.
atomicfire is offline   Reply With Quote
Old 03-05-2013, 07:12 PM   #6
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
ManualOverAuto is offline   Reply With Quote
Old 03-05-2013, 08:38 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bfh every time
Old 03-05-2013, 08:40 PM   #8
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Two
Thousand
Nine
Psychoreo is offline   Reply With Quote
Old 03-05-2013, 09:14 PM   #9
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
The biggest problem with that stinkin ball joint is the pinch bolt.. apply PB or whatever pen oil you have and HEAT it with a torch (OXY/ACL)... have watwr on hand to cool the wheel bearing once you breake the bolt loose..
So many people pop the head off that bolt its silly..
I have an old railroad spike, works great to open the pinch once you have the bolt OUT, the ball joint wont come out without it all the way out..
Here
Lower ball joint bad 06SilverWRX Newbies & FAQs 2 06-15-2009 09:23 PM
Lower Ball Joint csugden Brakes, Steering & Suspension 3 01-28-2009 10:19 AM
Odd request - used lower ball joint AugustusMaximus Tri-State Area Private Classifieds 2 11-12-2007 09:44 PM
tore rubber on lower ball joint!! boltonak Brakes, Steering & Suspension 2 10-01-2007 07:53 PM
Removing Lower Ball Joint?? DanBelford Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-31-2006 02:56 PM
