07-09-2009, 12:32 PM | #1 |
Member#: 203253
Vehicle:2009 Forester XT Silver |
How much smoke for a turbo to be toast?
Well the Forester is smoking at idle when left to idle for more than a min, especially if a cold start. It is not steam from condensation either.
Any application of the throttle will cause a nice cloud of blueish white smoke when parked. If driven off a bigger cloud of blue smoke trails. It seems though to disappear on the highway although a friend said he though he could see a faint smoke when under boost. Considering my issues with the exhaust seal leaking externally and smoke rising from the hood scoop I am betting that inside it is starting to give way as well. The dealer never acknowledged it because they couldn't duplicate it even though it happened to me all the time. I was also informed that a 1qt. burned off out of a 4.2qt engine capacity isn't a lot for 2000 miles. So to you turbo gurus am I inline for turbo replacement under warranty? It is an '05 XT with right around 44,000 miles.
07-09-2009, 05:53 PM | #2 |
Member#: 203723
Vehicle:2005 Impreza STi OBP |
Take the intake off of it and see if there is any shaft play. Minimal is ok but if it moves freely it is a goner. Also, since it is smoking, check your coolant for oil and your oil for coolant. Just to make sure, but it sounds like the turbo took a ****.
07-09-2009, 06:15 PM | #3 |
Member#: 143522
SWIC
Vehicle:1987 Brat GL 4 Speed 98 Forester L (RIP) |
uhhhhhhhh
until it stops boosting or holding boost? |
07-10-2009, 10:22 AM | #4 | |
Member#: 103497
NESIC
Vehicle:97 nissan 240sx black |
Like what was said before check for shaft play back and forth and foward and back. Check for oil in the intercooler and in the charge pipe right off the turbo. Is the oil cloud worse when you first start it? And oil comsumption spec is still kicking around from the old days for most auto manufactures. So in the books 1 qt. per 2000 miles might be in spec, esp based on driving habbits. |
07-10-2009, 10:30 AM | #5 |
Member#: 203253
Update:
Thanks for all the info, dealer says turbo is shot. So it looks like a new one under factory warranty for me. Do you have to break in a new turbo before going full boost? |
How much would a car have to be worth to be too expensive to rattlecan paint? | Strider | Off-Topic | 32 | 06-06-2009 08:40 AM |
How bad does the snow have to be... for flights to be cancelled/delayed? | snvin | Off-Topic | 31 | 12-06-2005 02:20 PM |
how much smoke made??? | wrxpeed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 04-01-2005 12:08 AM |
when installing eibach prokit on a 02 wrx how much did the camber need to be adjusted | woodchuck02 | Brakes, Steering & Suspension | 4 | 08-12-2002 04:57 PM |
roughly how much $$ for entire turbo setup eith reliabilty | watcher in the sky | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 12-12-2001 01:22 PM |
