Alaskan Impreza Club
Old 07-09-2009, 12:53 PM   #1
spike589
Member#: 122837
2008 speed3
red
Cool So new motor
Well I blew my motor and getting new one put in. My question is their is alot of info floating on how to break in a new motor. I heard to drive it hard and also baby it. I personally never broke in a motor before. S o im looking to see who has done this and what they recommend
spike589 is offline   Reply With Quote
Old 07-09-2009, 12:58 PM   #2
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
baby it for the first 1000 miles. Change your oil.
Then drive it like you're going to, which since you have an STi...will probably be hard.
QwikEVO is offline   Reply With Quote
Old 07-09-2009, 01:05 PM   #3
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Here's how I break my engines in...
http://www.mototuneusa.com/break_in_secrets.htm
yamahaSHO is offline   Reply With Quote
Old 07-09-2009, 01:09 PM   #4
spike589
Member#: 122837
2008 speed3
red
drive an STI hard i doubt it. I thought they were soccer mom cars
Old 07-09-2009, 01:10 PM   #5
spike589
Member#: 122837
2008 speed3
red
i have his info and it sounds sensible but i needed that feedback. how many you broken in
Old 07-09-2009, 01:18 PM   #6
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
I've done this on 5 motors now... Each one putting well over 400hp to the wheels (SHO motors). The motors run great and do not have excessive blow-by. If you want the rings to seat quickly before glazing over, you have to do it quick by putting some pressure behind them.
Old 07-09-2009, 01:19 PM   #7
QwikEVO
Member#: 44172
2006 Lancer Evo 9
He has a SHO, I'm sure he's done it once or twice. LOL
Old 07-09-2009, 01:35 PM   #8
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
hopefully not all for the same car.
seascooby is offline   Reply With Quote
Old 07-09-2009, 01:51 PM   #9
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
No, 4 different cars (a cam sprocket broke on one and melted some pistons on a buddies car - remote turbo'd), one of which is mine.
Old 07-09-2009, 02:44 PM   #10
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Omar the best advise i can give you is to listen to how Dale says to break in the motor, he's the one putting it together for you.
Mike
tribalwrx is offline   Reply With Quote
Old 07-09-2009, 02:50 PM   #11
Hi-Speed Solutions
Vendor
Member#: 143099
2008 AW STI
Rockin' the hatch!
I can say babying it and driving like a granny hasn't worked for me. but Dales seated the rings for me and I can tell you he was on the car hard, lots of revs, but not a lot in WOT. I drove out to Seward and cycled through the gears from 3-5 and sometimes 6, just to get the different Revs up without too much boost. I'm hoping this will work better than breaking my car in the first time. And thinking back, on my LGT, I broke that in fairly hard since it was my first turbo'd car and I had no idea I wasn't supposed to be going hard on the boost.. ok, maybe I did, but didn't care. LOL
Hi-Speed Solutions is offline   Reply With Quote
Old 07-09-2009, 03:18 PM   #12
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Dale seated my rings and after 500miles...It was on like Donkey Kong!
edit actually it was 743miles till I went full stg2 with other bs from stock
Marlons101 is offline   Reply With Quote
Old 07-09-2009, 03:24 PM   #13
spike589
Member#: 122837
2008 speed3
red
Mike
he was at first and now someone else is back their
Old 07-09-2009, 03:27 PM   #14
spike589
Member#: 122837
2008 speed3
red
you want to break in another one
Old 07-10-2009, 02:26 AM   #15
ScoobyTec
Member#: 138546
04 HD2500
Green....Loud
when i install a new engine or build a forged engine n/a or forced i always seat the rings. 20 pulls to 5000rpm @ 50%throttle go back to the shop and change the oil and filter hot. now the customer needs to drive it 500 miles before any high boost or long pulls or you will have oil consumption problems
ScoobyTec is offline   Reply With Quote
Old 07-10-2009, 03:22 PM   #16
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
If you're asking me to break it in... Bring it my way and I think I can manage.
I wouldn't use a 50% throttle as your only means. I watch boost when doing this. I try to give the motor a constan 3-5 PSI when doing this if it is boosted. For an NA motor, you can almost give it WOT to that point and in both cases, be sure to allow the motor to pull some vacuum by engine braking.
Old 07-10-2009, 03:42 PM   #17
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Is it because I'm new to the whole Subaru crowd, or do a lot of Subarus need rebuilt motors? Are the Boxer motors that weak when power is put to them???
Old 07-10-2009, 04:43 PM   #18
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
the internals are not the best in the 2.0L's they can take some power, tuning is what causes most to fail.
Alaskan EJ20 is offline   Reply With Quote
Old 07-10-2009, 04:55 PM   #19
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Tuning, or lack of?
Old 07-11-2009, 02:10 PM   #20
spike589
Member#: 122837
2008 speed3
red
everyone has diff. scenarios on why they blew up their motor. so its not likes its consistent issue or a trend for whatever reason one thing fails or another. Mine was i left mine outside all last wintewr cause couldnt drive it and only started it myabe once a day for 30 minutes or so cause i could not drive it. come summer i try to move it and their s a nice little tick in my motor.
Old 07-11-2009, 02:29 PM   #21
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
long idles tend to put a little combustion gasses in the oil and i can see how months of sitting would cause earlier fail.
Old 07-11-2009, 02:45 PM   #22
akeric
Member#: 122954
2006 Evo IX
My car is black not
As far as I know the boxer engine is a great platform once you take care of the crappy pistons and factory tune (on the later models).
akeric is offline   Reply With Quote
Old 07-11-2009, 03:18 PM   #23
WRXtract
Member#: 173927
2007 STi
i just got a new one put in my wrx, your going to want to change your oil at 100miles then just to make sure theres no metal shavings and what not, then change it at 300miles then you should be good buy i wouldnt have a led foot until after 1000miles.. good luck
WRXtract is offline   Reply With Quote
Old 07-11-2009, 03:39 PM   #24
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
I would make your first oil change immediately after the initial break-in runs.
FS : (CO) 2004 Sti W/New Motor Tuned For E85. $20,000 NAZSTI Private Vehicle 'For Sale' Classifieds 6 06-15-2010 06:53 PM
new motor...safe to use old tune for motor break in???tuner advice needed!! JT's06sti AccessPort 2 02-21-2009 05:15 PM
So I need a new motor... Konvict Alaskan Impreza Club Forum -- AKIC 52 07-02-2006 02:15 AM
Help! Brother has blown 1997 Legacy Outback motor - help me find a new motor? CirrusWRX Tri-State Area Forum 8 11-20-2004 08:48 PM
so my new motor wont start sick1.8t Normally Aspirated Powertrain 13 08-27-2003 10:13 PM
