07-09-2009, 01:02 PM | #1 |
Member#: 166591
NWIC
Vehicle:02 wrx black but blue in the sun |
Overheating issues
I have a 98 out/legacy with 198k, just did timming and water pump plus thermostat, and it was installed correctly.
The problem is it is overheating I tried getting any air or bubbles out, I filled up the radiator then the block, I even tried Subaru's special conditioner. It stays at a good temperature as long as I run the heater full blast. any more suggestions would be helpful. Thanks
07-09-2009, 03:17 PM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
are the fans plugged in? try again with burping the system.
07-09-2009, 04:09 PM | #3 |
Member#: 166591
NWIC
fans are plugged in and this is the second time I have tried burping it... Thanks for the reply.
07-09-2009, 10:22 PM | #4 |
Member#: 80465
RMIC
without sounding too much like a dick, I'm gonna have to say do a search on overheating. There are many causes, maybe it's been covered.
07-09-2009, 10:31 PM | #5 |
Member#: 172501
is this a new to you car?
07-09-2009, 10:42 PM | #6 |
Member#: 184335
South East
Vehicle:2004 STI WRB |
did you time the car correctly?? some times when you don't time the car correctly it starts over heating... or it could be a defective thermostat that is not opening correctly...does the car overheat when running over 20 mph if it doesn't its probably the fan sensor that is not triggering the fans...
07-10-2009, 12:47 PM | #7 |
Member#: 166591
NWIC
It overheats after the thermostat kicks in so that tells me it is working, the timing belt is a possibility but i have done so many and turned it one rotation and all the lines matched up... thanks for the replies, no worries I did a search and came up with a few things to check but to no avail did they work. my next step is to replace the radiator I guess
Thermostat / overheating issues Sort of odd issue | psychoskip | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 12-15-2009 08:18 PM |
2002 wrx overheating issue | rotaman | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 09-19-2006 06:09 PM |
'97 2.5 GT with overheating issues | StarryNights | Legacy Forum | 10 | 04-01-2006 09:07 PM |
Overheating issue... | MekoNY | Legacy Forum | 5 | 10-04-2004 12:46 PM |
overheating issue | jr34596 | Legacy Forum | 8 | 08-19-2002 02:19 AM |
