Alaskan Impreza Club
Old 07-09-2009, 06:45 PM   #1
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Default P0244
i was tuning a datalogging last night and threw this one P0244 (Wastegate solenoid A range performance)
Im using cobb's Access Tuner Race software and just installed a 3 port solenoid. prior to the 3 port i had a stock 2 port and maxed out its duty cycles at 16-17psi on a VF-34, and solenoid max pressure was set at 19.5 (this is where my problem lies i think). Now with 3 port it was easily hitting those targets with 50-60% duty cycle so i decided to turn up the boost alittle.
targets are now at 19-20.5 with duty cycles around 70-75% and i dont think i changed solenoid max pressure so during a few of my pulls i was cutting and throwing the code.
Am i on the right track here or not? tell me what you all have experienced with this code.
Alaskan EJ20 is offline   Reply With Quote
Old 07-09-2009, 06:46 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Boost cut. you were over boosting.
Mavrik is offline   Reply With Quote
CEL P0244 - Wastegate out of range? Big Turkey Engine Management & Tuning 2 09-04-2003 12:33 AM
P0244 Code.... karazyman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-27-2003 12:12 AM
cel code p0244 '555' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-22-2002 08:38 PM
P0244 error code? scoobin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-11-2002 10:01 PM
CEL P0244, can someone explain? bdowell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-22-2001 12:47 PM
