Old 07-10-2009, 09:24 AM   #1
carveman
Member#: 160363
2006 09 WRX & 06 TR
Default Overfill from the factory
I checked the oil on my brand new 09 WRX and the oil level was above the "notch" I'm doing the first oil change right now. I was wondering has anyone else seen this situation. It seems it was overfilled at the factory.
carveman is offline   Reply With Quote
Old 07-10-2009, 10:08 AM   #2
silvia-junkie
Member#: 103497
97 nissan 240sx
black
Yah it happens. When I was doing PDI's (pre delevery inspections) when I was still working at a dealership I ran across a number of cars over filled. Its usually only about half a quart or so. I never worried about it, run it at the proper level from now on and chalk it up to a asembly line quirk.
silvia-junkie is offline   Reply With Quote
Old 07-10-2009, 06:42 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
1/2qt is no problem at all
Old 07-11-2009, 04:23 PM   #4
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
My 09 WRX is the same way. The tires are also at 40psi or more.
09rexwagon is offline   Reply With Quote
What is the VF39 wastegate actuator PSI set at stock from the factory? SixSick6 Factory 2.5L Turbo Powertrain 50 03-09-2007 10:00 PM
is the automatic really this bad from the factory? jeisen Transmission (AT/MT) & Driveline 15 08-17-2004 01:18 AM
2002 WRX from the factory Beanboy General Community 1 01-04-2002 02:32 PM
help with choosing mods from the factory, when buying thewrx fufanu Member's Car Gallery 4 06-04-2001 11:04 AM
Anyone have opinions about the WRX suspension upgrade from the factory? brainofjjj Brakes, Steering & Suspension 25 05-22-2001 08:36 PM
Message Board Statistics All times are GMT -4. The time now is 02:57 PM.
