Old 04-29-2002, 09:03 PM   #1
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
Unhappy car wont run/pressure sensor code
i hope someone can help, because my car decided not to work today when i cam out from work. it starts and everything seems normal, but it wont keep running, and pressing the gas only helps if i blip a lot. after a few minutes, i got a CEL. the code reads "Pressure sensor value/performance." the code is P1112 i think.
so does this mean i need a new mas sensor (my2000 RS), or is the voltage clamp skrewed up? i also have a j&s, but the car does start, so i dont think that that is the problem.
thanks to anyone who can help
tydon is offline   Reply With Quote
Old 04-29-2002, 09:26 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
P0119 is a Coolant Temp. Circuit Intermittent problem. Are you sure that was the code?
Anything change between running & dead?
Old 04-29-2002, 09:57 PM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
the code is P119 i think.
8, you might have the wrong code number, unless my eyes are really messed up.
Graham
Graham is offline   Reply With Quote
Old 04-29-2002, 10:30 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The DTC's are P and then 4 digits- you wouldn't have a P119 code .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.subaruwrxparts.com
Old 04-29-2002, 10:34 PM   #5
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
My bad.
Graham
Old 04-30-2002, 03:10 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hmmmm... well there is a Land Rover code :
P1190 - Oxygen Sensor Heater Type 2 Low Resistance Upstream
and a Caddilac code :
P1190 - Engine Vacuum Leak
though somehow I think neither are applicable.
Old 04-30-2002, 03:50 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
FWIW any 4 digit trouble code that starts with a P1 is a MANUFACTURER specific code and therefore can ONLY be read properly with the manufacturer books/diagnostic equipment.
jeremy
Old 04-30-2002, 10:27 AM   #8
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
oops, i checked the code again, and my memory was wrong. the code was "P1112 Pressure sensor Range/Performance" I changed it in my first post too. seems like i need a new pressure sensor . do you guys agree with that?
Old 04-30-2002, 11:57 AM   #9
proecm
Member#: 12081
Start by checking the voltage clamp. I hope you are not running the cheap zenerdiode, it is not a reliable way to achieve a voltage clamp.
/David
proecm is offline   Reply With Quote
Old 04-30-2002, 12:06 PM   #10
Jewbaru
Member#: 1994
2013 Impreza WRX
Check the clamp, it might be dead. I accidentlly hooked my old Zener up incorrectly, and the same thing you're describing happened to me.
Jewbaru is offline   Reply With Quote
Old 04-30-2002, 11:21 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
tell me you have a zener, because i have a ss vc1 and i dont want this to happen to me ;P
akcel is offline   Reply With Quote
Old 05-01-2002, 03:04 PM   #12
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
i do have the voltage clamp.
a wierd thing happened yesterday. i went out to check out my car at lunch, and it started up and drove fine. i went home, turned it off, ate, and drove back to work. at the end of the day it wasnt working again.
i think i may just have a bad connection somewhere, so that is what im going to check out first. if they seem ok, then im going to bypass the voltage clamp to see if it runs ok without it. just have to stay out of boost withthe vc disconnected, or BOOM.
Old 05-01-2002, 03:25 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, not necessarily boom, but fuel cut and a hell of a bog. It'll be like a low rev limiter, that isn't too good to bounce off of.
Old 05-01-2002, 05:36 PM   #14
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Sometimes weather can affect how a zener-diode performs, I wonder if its the same for the VC's?
Graham
Old 05-01-2002, 06:19 PM   #15
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I was told by Split Second that their clamp will not be effected by weather unless you have them mod it and add adjustability, then it will be effected.
tydon - What voltage clamp do you have?
Old 05-03-2002, 05:07 PM   #16
tydon
Member#: 12224
2000 RS;Spec Miata
Del Sol Si
8 - i have the vc1, non-adjustable.
i still havent found the problem absolutely, but i found that when suby sports installed the turbo kit and gauges, they used electrical tape and just tied some of the wires. im going to get some better wire connectors and redo the connections. im pretty sure that is the problem since the car started and ran well the last few times i tried. it seems like one connection is just a bit loose.
Old 05-03-2002, 05:30 PM   #17
akcel
Member#: 10268
gc8 I ride ride 24s
that sounds effing terrible
What the h*? My car won't start with P0335 code wrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-16-2012 12:55 PM
car won't run after intake manifold removal sti_vr4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 04-22-2007 12:41 PM
!HELP! changed clutch car won't run TecHniKa Transmission (AT/MT) & Driveline 4 11-05-2003 05:49 PM
Need help, car won't run Ethan Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-20-2001 12:30 AM
