Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-11-2009, 11:05 PM   #1
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Default Pictures? 18x8.5 +45 w/245/40/18
I did alot of searching, and didn't find much. I know these are roughly .7" taller than stock and will show about 4mph slower on the speedo, but anything to raise the gear ratio is great.
My '06 WRX has a complete '06 STi drivetrain swap, and will be going on axis halo rims. I wanted to go with a 245/35/18 but the Sumitomo HTR Z III XL didn't have that size.
I have stock struts with prodrive springs. I don't want to roll the fenders, so if these rub i'll exchange them for 255/35/18's. If anyone has pictures of these size tires on their car that would be great too.
Any positive input is appreciated.
Thanks.
irascible is offline   Reply With Quote
Old 07-12-2009, 08:52 PM   #2
ZoneMaster
Member#: 215979
2006 WRX Limited
Hey irascible,
I'm probably not going to be much help, but it depends on how much camber you're willing to run. I'm on stock suspension and camber (06 wrx) still and was just fitting some new wheels/tires on mine - 255/40s on 17x8.5 +45. I'm having trouble with the tires hitting the rear fender lip, which isn't rolled yet. As far as inner fenders go, the tires should clear mostly under compression and turning, but it's close.
A 245/40/18 would probably hit the plastics at full lock especially under compression, being as tall as it is. As far as the fender goes, it might hit even being narrower than the 255, but this again depends how much camber you are running.
I'm by no means an expert on this, but hopefully I helped a little .
-Cory
ZoneMaster is offline   Reply With Quote
Old 07-13-2009, 12:26 AM   #3
mosc
Member#: 177401
2015 STi White
you'll have to roll the fenders in either case. Less I would think with 255/35/18 but still at +45 you're 23mm further out than stock. Your rear fenders ain't going to like you (mattering on suspension).
mosc is offline   Reply With Quote
Old 07-13-2009, 10:34 AM   #4
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
I would rather avoid rolling the fenders, but it sounds like I might if I keep these. I heard the Sumitumo's run wide too. According to tirerack's site, they are measured for 8.5" rims... but that's why I was hopeing to find pictures.
btw, +45 is only 8mm different than stock.
Old 07-13-2009, 10:36 AM   #5
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Originally Posted by ZoneMaster View Post
Hey irascible,
-Cory
Right now i'm running stock camber. I didn't think about full lock, that's a good point. If you're fender's are rubbing on stock suspension and 17's, then i'm definetely going to have trouble. lol
Old 07-13-2009, 12:24 PM   #6
Crawdads
Member#: 30907
SWP GDB-G
Kumho XS come in 245/35.
Crawdads is offline   Reply With Quote
Old 07-13-2009, 12:47 PM   #7
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Actually... MY02-09 Impreza/WRX/OBS come w/ +55mm offset.
Fendyman is offline   Reply With Quote
Old 07-13-2009, 12:50 PM   #8
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Actually, you guys need to read my first post in its entirety. Full STi drivetrain, so actually i'm correct
Old 07-13-2009, 12:56 PM   #9
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
I was torn between the Sumitomo and Federal's (which come in 245/35 too). I liked the better treadwear rating of the Sumitomo's and the price was excellent at $119/ea for 245/40/18's.
So, I didn't research anything else as the forum was raving about these two tires mostly... it caught my eye.
I'll look into the Kumho's, ty.
Old 07-13-2009, 01:07 PM   #10
mosc
Member#: 177401
2015 STi White
I said 23mm because it's 30mm more tire than stock (15 on each side) PLUS the 8mm less offset which, you guessed it, means your tire is 23mm closer to the fenders. Stock is +53 225 wide. Wow, math is so difficult! [/sarcasm]
245/35/18 doesn't guarantee you won't have rubbing anyway. Especially at 8mm less than stock offset. Even more likely if you have lowering springs.
Old 07-13-2009, 02:04 PM   #11
Badler
Member#: 133597
I would start looking in the 225/235 range if you don't want to roll your fenders. 245+ WILL rub. Prodrives aren't that stiff of a spring either...
Badler is offline   Reply With Quote
Old 07-13-2009, 02:06 PM   #12
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
That's what I was afraid of; yah, I bought the prodrives because I didn't want much stiffer than stock.
So i'm assuming the 255/35's are also out of the equation?
Old 07-13-2009, 02:11 PM   #13
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
You said further out, indicating one side, so I assumed you meant offset. You explained it alot better here where it makes sense.
It sounds like i'm going to end up exchanging these tires for a set of 235's But it's not like I really need 245's... just like the wide tire look.
Old 07-13-2009, 02:12 PM   #14
Badler
Member#: 133597
255 anythings are out of the question without modifications. Just pull/roll your fenders. It's not as expensive/hassle as people think. You will be much happier in the long run doing it right the first time. As an added bonus you can actually run a good size tire!
Old 07-13-2009, 02:38 PM   #15
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Those are very good points... If I do decide to roll the fenders, I want to make sure to do it right. I don't like the look of a tire that's stretched to the edge, or over the edge. I like it flush with the rim, that's why I purchased the 245's.
Old 07-14-2009, 12:04 AM   #16
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
18x8.5 +48 255/35/18
Not exactly what you were looking for, but its close.
retroXvertigo is offline   Reply With Quote
Old 07-14-2009, 11:27 AM   #17
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
That's exactly what I was looking for! Thanks. Does it rub ever? Ex. When in full left/right steering lock, and/or with a bunch of people in the car? Did you have to roll your fenders?
That looks very nice... those tires seem to match up perfectly.
Old 07-14-2009, 02:19 PM   #18
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
No rubbing. Rolled front and rear.
RCE blacks as far as suspension goes.
Old 07-14-2009, 03:03 PM   #19
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
That's the type of info I was looking for the entire time, thanks. Your setup turned out really nice, love the look.
Old 07-23-2009, 10:25 AM   #20
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Well, I ended up getting 18x8.5 +45 Gram Lights hooked up with 245/40/18 Sumitumo shoes!
With Prodrive springs, and no fender rolling... it doesn't rub, the tires are a perfect fit for 8.5", and no rubbing!
I'll post pictures soon so pictures are available for the next person searching.
Old 07-23-2009, 10:40 AM   #21
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
+1 for Prodrive Springs...
The Phenx is offline   Reply With Quote
Old 07-23-2009, 11:55 AM   #22
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
I can't see/post pics from work buy my old setup was just that 18x8.5 with 245/40/18. Search for some of my pics if you want.
jordanretro1223 is offline   Reply With Quote
Old 07-23-2009, 01:27 PM   #23
jazmak24
Member#: 171920
06 sti
aspen white
my old set up on swift springs 18x8.5 +45 245/40/18 no rubbing or fender mods
latest set up 18x9 +45 255/35/18 still on springs will probably need a minor rear fender roll.no rubbing yet,but havent had a chance to drive much yet.
jazmak24 is offline   Reply With Quote
Old 07-23-2009, 01:56 PM   #24
07subie
Member#: 148097
2007 2010 WW Evo X
Swp wrx gone...
I have a 07 wrx. Stock struts on h-tech. Have advans 18x8.5 with 45mm offset. Running 235/40/18 federals ss-595(run wider, so like 245) and they rub. Rolled the rear all gone. Expect on hard bumps going 70 and full car. I also had this question when I bought my new set up and I wanted to go as wide as I could without rolling the fenders. Ppl told the wrong this. If I knew I would of rubbed. I would gone 245 on the federals- that's 255. So just get the 255 and roll the rear.
07subie is offline   Reply With Quote
Old 07-23-2009, 02:28 PM   #25
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Cool, if In find them i'll add them to the thread.
NY/CT: 18x8 OZ Ultraleggera's & 245/40/18 Dunlop SP 600 Donzo Wheels/Tires 38 03-10-2010 05:33 PM
18x8 OZ Ultraleggera with 245/40/18 Dunlop SP 600 Donzo Tri-State Area Private Classifieds 16 01-12-2010 03:55 PM
FS: 18x8 rota torque w/245/40/18 Sunny tires new crpwrx SCIC Private Classifieds 46 07-30-2009 09:09 PM
18x8.5+48 on 245/40/18 05 sti xt-b Tire & Wheel 3 04-14-2008 04:24 PM
18x8.5 +48 with 245/40 or 225? it8ezbngrn Tire & Wheel 5 03-14-2005 02:28 AM
