Old 07-11-2009, 11:15 PM   #1
NMZ_WRX
Member#: 198280
2007 BLACK MONSTER
WINGLESS
Default correct torque settings?
Just wondering what a correct torque setting[lbs] is correct for our cars. TO be more specific, im running the sti bbs wheels on an 07 wrx with tires. Is 90 lbs overkill?
NMZ_WRX is offline   Reply With Quote
Old 07-11-2009, 11:39 PM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Um, yes.
66 lb/ft is the correct setting.
Old 07-12-2009, 01:08 AM   #3
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
90 is high, but won't do any damage. You're fine. I usually put them at 70 with my snap-on torque wrench.
irascible is offline   Reply With Quote
Old 07-12-2009, 01:29 AM   #4
Slide_Cycle
Member#: 216277
70lbs is the general Subaru setting for all wheels. The only problem with over-torque is the "possibility" of cross threading the studs or damaging the lug ends.
Slide_Cycle is offline   Reply With Quote
Old 07-12-2009, 09:14 AM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
70 lb/ft is acceptable.
By overtorquing you risk the possibility of effectively stretching the studs and having them shear on you.
I had this happen on another car of mine. Not fun, but luckily it happened while torquing the nuts and not while driving the car.
Correct bov setting 05BLEUwrx Newbies & FAQs 5 03-21-2005 02:52 AM
questions about correct torque on oil drain bolt and tranny fluid bolt... IMPRZME Newbies & FAQs 7 11-14-2004 11:00 PM
What's the CORRECT torque sequence for uppipe install? T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-27-2003 11:12 PM
Correct Alignment Settings With Eibach Springs? WRXURV8 Brakes, Steering & Suspension 23 04-06-2003 01:56 PM
Correct off set for 15 inch steel rims Koyo Brakes, Steering & Suspension 2 07-29-2002 02:24 PM
