Old 07-16-2009, 03:56 PM   #1
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
Default using 10mm spacers... will 35mm extended lugs be enough? 17x9 +44
going to run work kai 17x9 +44 on my 04 sti witch will require a extended stud. going to order 35mm 12x1.25 Ichiba wheel studs, will they be the correct length for the wheel and spacer im going to use? also will i have to run open ended lugs? thanks
Last edited by JDMmanny; 07-16-2009 at 04:00 PM. Reason: sorry ment 35mm studs!!!!!!!!!!!!!!!!!!! no lugs
JDMmanny is offline   Reply With Quote
Old 07-17-2009, 03:55 PM   #2
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
no one know...?
Old 07-17-2009, 04:50 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Do you need a spacer to clear the brakes? if not, why?
mav1c is offline   Reply With Quote
Old 07-17-2009, 08:05 PM   #4
mosc
Member#: 177401
2015 STi White
17x9 kai's need 10mm spacers to clear front brembos for 04 STi brakes. Not that I'd recommend that setup. It's on extra long studs with a thick spacer and +34mm for an extra .5" width or so you can't do much with.
mosc is offline   Reply With Quote
FS: 3 (possibly 4) work cr-kai 17x9 +44 gunmetal & Work RS Lug Nuts invidiaWRX218 Wheels/Tires 16 03-22-2010 06:23 PM
FS: Ichiba 10mm spacer with extended studs rok3479 Suspension/Brakes/Handling 1 01-04-2010 02:52 AM
10mm 5x100 Ichiba Spacers with studs and Buddy Club 1x1.25 extended lugs needforsleep TXIC Private Classifieds 8 09-01-2009 12:32 AM
Extended studs NEEDED? when using 10mm spacers? BuggeyEYED Interior & Exterior Modification 10 08-10-2009 01:55 PM
FS: Kics 10mm Spacers with ARP (new) extended Studs Prez Wheels/Tires 0 02-26-2009 01:12 PM
