Old 07-12-2009, 11:42 PM   #1
Gordo52
Member#: 146275
13 BRZ
Default Need AC help
Having some trouble with my AC. It works fine on a day to day basis, but on an extended road trip 2+ hours it will start to act weird.
The blower continues to blow at what ever speed you have it set at, 1-4, but slowly less and less air comes out of the vents until it basically just stops blowing air at all.
So if I have the blower set to its highest setting, you can hear it blowing really hard, but only a small amount of air will trickle out of the vents.
The air will also get warm like the AC is no longer working either. If I turn the AC off and continuing to run the blower it will slowly go back to the normal amount of air that should be coming out of the vents.
It is a really annoying problem and I think that it may have something to do with freezing, because the problem is usually accompanied by some mist or a small amount of fog coming from the vents as it happens.
Is humid air causing something to freeze shut?
Gordo52 is offline   Reply With Quote
Old 07-13-2009, 12:14 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The system is freezing up, it's a known issue with the 02/03's. See the TSB info in this thread and note if your VIN is within the affected range.
http://forums.nasioc.com/forums/show...postid=4179167
The fix as indicated is a replacement thermosensor and control module. I did this fix on my '02 a few years back and it works.
Old 07-13-2009, 12:15 AM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
sounds like freezing. Do you have a cabin air filter? maybe it's getting time to change and the lack of flow means that your evaporator is slowly freezing up.
Old 07-13-2009, 08:47 AM   #4
Gordo52
Member#: 146275
13 BRZ
that sounds exactly like what my problem is. Thank you so much.
anyone have a pioneer avic u310bt need some help cosanostra Car Audio, Video & Security 5 06-04-2010 01:20 PM
help! need AC line Sputnik 5 Private 'Wanted' Classifieds 5 04-07-2009 03:20 AM
Need some help with booking a room at the Borgata in AC for my wedding night. Mud Pig Off-Topic 5 03-17-2009 06:36 PM
Help! Need AC Condensor pronto jonnysubby North West Impreza Club Forum -- NWIC 11 07-21-2005 08:48 PM
Need a help on installing/taking off stock AC line... alvyman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-27-2004 11:03 PM
