Old 07-13-2009, 02:48 AM   #1
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Default 3/8" fuel lines and factory hard lines?
I've heard that 5/16 fuel line hose works with the factory hard lines, but has anyone tried 3/8? Will a fuel injection hose clamp make a tight enough seal to stay safe, or should I just not go there?
Thanks!
Old 07-13-2009, 03:14 AM   #2
Rod702
Member#: 132978
2004 Mike angel tund
efr 7670 1.05 Twiscroll
I wouldn't. clamps won't seal it good enough. I used a conversion 5/16 nipple to 3/8 an fitting on push lock hose rated up to 200 psi and 300 degrees temp. I'm running the injector dynamics intank walbro with inline Bosch 044.
Rod702 is offline   Reply With Quote
Old 07-13-2009, 03:39 AM   #3
NSFW
Member#: 140444
05 Stage Free LGT
Where did you find those conversion bits? I need a half-dozen...
Thanks!
Old 07-13-2009, 04:11 AM   #4
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Aeroquip adaptors HERE and fittings HERE or Mocal fittings HERE.
Leslie
wrxsti.l is offline   Reply With Quote
Old 07-13-2009, 04:27 AM   #5
NSFW
Member#: 140444
05 Stage Free LGT
I see only three 5/16 barb adaptors at that site and none of them have AN fittings... All three have "jiffy-tite" fittings on the other end, which looks neat, and I'm tempted to get a set anyway... but I still need a 5/16-to-AN adaptors.
Am I missing something? Is there a part number or some keyword I should search for? I tried "5/16" and "barb" with no luck.
Thanks!
Old 07-13-2009, 04:48 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
Closest thing so far. Was hoping for a female AN fitting though...
http://www.shopatron.com/product/par...er=15635/415.0
Old 07-13-2009, 08:36 AM   #7
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I've had some success stretching 5/16 hose over 3/8 barbs. Just warm it a bit and use some WD-40 and a lot of elbow gease.
gumby647 is offline   Reply With Quote
Old 07-13-2009, 10:19 AM   #8
SubeTek
Member#: 1714
1999 RS-T COUPE
SubeTek is offline   Reply With Quote
Old 07-13-2009, 12:17 PM   #9
Rod702
Member#: 132978
check ur local hose store. I'm pretty sure they have fuel safe fittings and adaptors. that's where I got mine.
Old 07-14-2009, 12:28 AM   #10
NSFW
Member#: 140444
05 Stage Free LGT
Originally Posted by SubeTek View Post
That's intriguing. Can you, or someone, confirm that the stock hard lines are 8mm?
Old 07-14-2009, 05:22 AM   #11
NSFW
Member#: 140444
05 Stage Free LGT
I just measured them myself, seems like 8mm to me.
Thanks for the suggestion!
Old 07-14-2009, 06:26 AM   #12
NSFW
Member#: 140444
05 Stage Free LGT
Anyone know of an online shop in the US that carries that part?
I found a dozens of Aeroquip retailers that carry every part except that one.
Old 07-14-2009, 10:09 AM   #13
SubeTek
Member#: 1714
1999 RS-T COUPE
no dealers i've talked to can get it. looks like roger clark is the only place.
Old 07-14-2009, 11:12 AM   #14
not8player
Member#: 92852
5/16 inches = 7.9375 mm
http://www.summitracing.com/parts/EAR-165056ERL/
I used EAR-165056ERL on the stock hard lines in the engine bay. I had to use some sand paper to get the OD of the hard lines down a bit and also heated up the compression olive a tad bit to expand it over the hard line. Easier than it sounds. tested the fuels system at 110 psi with no leaks.
not8player is offline   Reply With Quote
Old 07-14-2009, 11:20 AM   #15
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
+12345
Same thing I used to hook up a feed line from the factory fuel tank to my surge tank.
ec2k1gt is offline   Reply With Quote
WTB: 3/4" and 5/8" fuel/oil safe hose tundra Private 'Wanted' Classifieds 3 03-31-2008 09:11 PM
Help... can't get brake line off the hard line chimchimm5 Brakes, Steering & Suspension 3 10-21-2007 12:43 AM
WTB: Oil return line, and power steering lines....HELP! RS_to_WRX_swap North West Impreza Club Forum -- NWIC 6 09-01-2005 02:55 AM
Hard factory oil lines suck... postban Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-24-2003 09:28 PM
SS lines - leak from hard line after install - help! NotFast Brakes, Steering & Suspension 23 05-06-2003 08:38 PM
