![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 202925
I'm going to buy an 09 WRX to autocross in D Stock in our local street tire subclass. I've heard that the WRX is prone to serious understeer near the limit, so I've been throwing around the idea of running a wider tire in front than in the rear, to aid in bringing the rear end around a bit more. Just for background, the stock class rules say you have to use an OEM sized wheel with an offset within .25" of stock.
I've heard that if the overall diameter of the tire/wheel combo is different front to rear, it can play havoc with the electronic nannies (i.e. ABS, traction control, etc.). What I was considering is a 255/40 tire in front and a 225/45 tire in the rear. This works out to an overall diameter (theoretically) for the 225 of 634.23 mm and a circumference of 1992.3 mm. For the 255 it's 635.76 mm diameter and 1997.2 mm circumference. Here's my question: does anyone know if this difference in overall diameter and circumference is enough to make the electronic nannies wig out?
#2 |
Member#: 202925
Bump. Anyone? Bueller?
#3 |
Member#: 133597
SCIC
No, you will be fine. Plenty of people run wider/different offset in the front to help with understeer. Do you have any ACTUAL experience yet or is this just what you "heard"?
#4 |
Member#: 202925
Haven't bought the car yet, just "heard." I'm fantasizing about what I'm going to do to it once I sign the paperwork and drive off the lot. Just don't want to spend the $$$ for new rubber only to find out I've got the electronic gremlins breathing down my neck and have to spend more to fix the problem.
#5 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
sway bars would be cheaper than new rubber....
#6 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
#7 |
Member#: 202925
| Thread Tools | |
| Display Modes | |
| tire aspect ratio | nhmtns | Tire & Wheel | 5 | 11-25-2005 08:39 PM |
| Tire aspect ratio question | Legacy777 | Tire & Wheel | 2 | 01-10-2005 09:17 AM |
| changing tire aspect ratio? | orndog | Brakes, Steering & Suspension | 4 | 07-07-2003 12:52 AM |
| Need aspect ratio for Plus 1 upgrade | zabutter | Brakes, Steering & Suspension | 5 | 12-10-2001 02:21 PM |
| What's the correct aspect ratio? | Arnie | Brakes, Steering & Suspension | 5 | 02-13-2001 11:03 PM |
