Old 07-14-2009, 12:41 PM   #1
Epic Motorsports
Member#: 198925
Default AR Fabrication- 42r bugeye
I was just up at AR fab yesterday tuning a car and Howard and Tommy had the shop drag car on the dyno.
730whpat 33 psi
it spun the tires at 40psi but made 730lbs of tq hp should have been over 800 he's going to try to bring the car down here to fatalville next weekend to run it on our dyno then hit the strip!
Car is insane. Oh BTW its a 2.0l wrx motor Woot!
I'll have him come in for some more info.
Epic Motorsports is offline   Reply With Quote
Old 07-14-2009, 12:58 PM   #2
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
God dam! No wonder it spins lol, all the weight is in front of the front wheels. That a MD?
Thats some dam good tq.
project_skyline is offline   Reply With Quote
Old 07-14-2009, 12:59 PM   #3
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
damn!!!!!
shadowmd is offline   Reply With Quote
Old 07-14-2009, 01:17 PM   #4
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
love to see what kind of bumper goes on that thing, there sure is alot going on there. Dual intakes, everything in the front. Good power though. 730 ftlbs is insane too. Good luck with it.
oneoverWRX is offline   Reply With Quote
Old 07-14-2009, 01:54 PM   #5
Mooneyes13
Member#: 113666
60' all over you
thats going to be one hell of a hood over that thing.
Mooneyes13 is offline   Reply With Quote
Old 07-14-2009, 02:06 PM   #6
Epic Motorsports
Member#: 198925
He is building a tube chassis sti drag car. So he put the motor in his bug eye drag car to break it in.
Old 07-14-2009, 02:14 PM   #7
3MI Racing
Member#: 200987
This should be quite impressive to see...as I've always been a bigger fan of the EJ20 and not so much the EJ25, glad to see it doing well.
-Micah
3MI Racing is offline   Reply With Quote
Old 07-14-2009, 05:08 PM   #8
RaceSleeves
Member#: 120257
02 WRX
Maroon
Here is a better pic of the setup for all to see...
~Brandi
RaceSleeves is offline   Reply With Quote
Old 07-14-2009, 06:14 PM   #9
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Sweet Jesus. Just look at the amount of condensation out of the BOV when it purges.
cucamelsmd15 is offline   Reply With Quote
Old 07-14-2009, 06:14 PM   #10
SubyWill
Member#: 166830
2003 WRX
siiiiiiick!!!!! that's my next setup! lol
SubyWill is offline   Reply With Quote
Old 07-14-2009, 06:15 PM   #11
bertune
Member#: 107290
Very nice!
bertune is offline   Reply With Quote
Old 07-14-2009, 06:24 PM   #12
Clark Turner
Member#: 178047
02 WRX STI Spec C
Sick bugeye guys! Love it!
Clark
Clark Turner is offline   Reply With Quote
Old 07-14-2009, 06:27 PM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Dam son, now thats how a bugeye should be built the air flying out of the BPV was pretty cool!
DoctorNick is offline   Reply With Quote
Old 07-14-2009, 06:40 PM   #14
Rayman21287
Member#: 105125
2005 WRX/ 2008
Stage Pi/MercedesC300 4MA
Rayman21287 is offline   Reply With Quote
Old 07-14-2009, 07:49 PM   #15
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Thanks Brandi.
I have a few pics I took of it yesterday and some rolling shots lol.
robbieshonda is offline   Reply With Quote
Old 07-14-2009, 07:57 PM   #16
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
****in epic
moosecakes is offline   Reply With Quote
Old 07-14-2009, 09:15 PM   #17
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
Can I has that for a daily driver?
awesome set up!
chlnOrSlpn? is offline   Reply With Quote
Old 07-14-2009, 09:26 PM   #18
r8r4life
Member#: 101464
Holy **** a 2.0.
r8r4life is offline   Reply With Quote
Old 07-14-2009, 09:39 PM   #19
shutupnshift04
Member#: 101710
BOSS
Can i have that motor
shutupnshift04 is offline   Reply With Quote
Old 07-14-2009, 09:55 PM   #20
josedwrx
Member#: 199988
2002 wrb bugeye
vf39 12.3 @113
Thats just awesome!
josedwrx is offline   Reply With Quote
Old 07-14-2009, 10:37 PM   #21
RaceSleeves
Member#: 120257
02 WRX
Maroon
This thing is actually a SOB to work on in a sheet metal chassis! It is not supposed to be this clustered nor is it supposed to have a FMIC / Radiator / couplers...LOL
In the Tube chassis there are nice mounting points for the coil packs, dry sump tank and an ICE CHEST IC...The main engine runs on Methanol so a radiator is not needed...and we are using the Hargett IC clamps but I did not want to waste the rest of my clamps on this setup.
The BOV also has too much spring pressure since the cams produce nearly no vacuum so you hear the turbo surging after the initial BOV opening then it stays shut.
This engine is actually a 2.0L block that is sleeved with our 100mm pistons, a stock 2.5L crank, stock ported heads with +.5mm valves, a very nasty set of cams and a set of EAGLE(ARP 2000 rod bolts...the standard bolts) rods FTW!!!
The main engine is a new 2.5L casting that is sleeved with a set of 4.0" bore custom flat top (11.6:1) pistons, Billet 79mm crank, a set of our Big port heads with STD Intakes and +2.5mm Exhaust Super alloy valves, another set of one off cams from Kevin @ Kelford, JUN cam gears and another set of EAGLE rods with CA625 bolts
Yea...almost forgot... I will never ever use an electric fuel pump ever again!!! On the back of the drysump pump is a Weldons mechanical fuel pump and this thing is the best! At 4000rpm pump shaft speed it puts out over 7GPM of fuel!
More to come!
Howard
Old 07-14-2009, 10:45 PM   #22
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
I have often wondered why no one has been more creative with thier turbo placement.
WELL DONE
Good luck getting it to hook
jmlaser is offline   Reply With Quote
Old 07-14-2009, 10:57 PM   #23
RaceSleeves
Member#: 120257
02 WRX
Maroon
WELL DONE
The hooking up is not the problem...its the destruction that happens after the launch. Regardless of how well we were able to make Eggums Civic(the Fastest FWD Honda) hook it still broke something in her gearbox every few passes or so.... but 1.1X-1.2X 60fts will do that to a gearbox without any kind of slippage.
This car uses the same boost control setup used in her car....multiple stages of timed boost increases and a launch control feature that helps with the initial boost hit on the launch.
Howard
Old 07-14-2009, 11:03 PM   #24
Russ45
Member#: 170237
Hey, don't be a
dick, bro..
That is sick!!! My god.
Stock tranny right?
Russ45 is offline   Reply With Quote
Old 07-14-2009, 11:10 PM   #25
RaceSleeves
Member#: 120257
02 WRX
Maroon
This is our second brand new 6mt/PPG gearset.... The first one broke the input shaft and a few of the gears on a 3-4 shift along with the rear end and left axle...I was dropping the car off to my wedding Venue the night before the ceremonies so the wife and I could leave in it after being wed... OOOPS! LOL
AndrewTech and PPG stepped up and replaced it for us!
Almost nothing on this car has been left stock except for sheetmetal and glass... even the suspension is fabricated which BTW unbolts and bolts onto the tube chassis.
Howard
AR Fabrication Short Blocks Epic Motorsports Engine/Power/Exhaust 1 11-20-2009 09:49 AM
FS: CT AR Fabrication Radiator Shroud vcapra Engine/Power/Exhaust 5 06-29-2009 12:38 PM
Tuning at Ar Fabrication May 16th and 17th Epic Motorsports MAIC Vendor Classifieds 0 05-06-2009 08:18 PM
Built motor by AR Fabrication 1/500yellowwrx Built Motor Discussion 10 01-21-2007 10:30 AM
AR Fabrications Local_Skater Mid Atlantic Impreza Club -- MAIC 1 01-07-2007 03:23 PM
